Fender roll with 350z rims?
Old Mar 9, 2010 | 03:04 PM
NismoCefiro's Avatar
I got a set of 18 350z rims. 18x8 30mm front and 18x8.5 33mm back. I mounted the back w/o tire for test fit and it comes close to the fender. Any 5th gens with 350z rims? Any rubbing? Should i roll my rear fenders?
Old Mar 9, 2010 | 03:16 PM
PulsarGTS's Avatar
You may need to roll the front section of the fender. The geometry of the suspension pulls the wheels forward just as much as vertically. BUT if you keep with a 245/40 or 235/40 you wont have to roll anything.
Gemner's Avatar
shouldnt have any problems. stock wheels are 7.5" +35 without even a mad chance of rubbing. Why are you putting 8.5" wheels in the back though? find some fronts and use those, youre only adding rolling resitance
Old Mar 9, 2010 | 06:58 PM
soto2635's Avatar
i just put on some 18in 350z wheels on my maxima it comes close but it clears im running 245-45-18 on the back and it only rubs if im go over speed bumps or dips in the road other that that its good to go. dont roll ur fenders
Old Mar 9, 2010 | 07:05 PM
igzy's Avatar
I Know Kwaliti
Had 350z track wheels on mine too... No rubbing issues....
Old Mar 9, 2010 | 07:30 PM
e-subliminal-2's Avatar
Nope, I got mine on with 245-40-18. Dropped on progress which is pretty low in the rear. ABout a finger length, no rubbing issues.
Old Mar 9, 2010 | 07:38 PM
Z-Powered's Avatar
Since the Maxima is FWD, wouldn't it be better to but the wider wheels in the front?
Old Mar 10, 2010 | 03:27 AM
Im afraid I might have to roll it =\
It comes awfully close
I only have 5-10 mm to the lip of fender. I plan to put 245 40 18 on rear and 235 40 18 on front. Pros of rolling would give maybe 5-10mm I don't have a rear sway so any hard turns may rub??!?!?!
I would put it on front but it would look funny and I do not want to lose my turning radius. Its already reduced.... Falken RT-615 should still give me the bite I need. I get good bite now with stock 16's 225 with yoko sdrives.
What are you rubbing on? Inside fender well or fender lip? You say bumps so it sounds like ur well.
Are you running 8 or 8.5 in rear?
Old Mar 10, 2010 | 04:50 AM
Shift_Max's Avatar
Maybe this will help or maybe not but I am running a 19x8.5 with a 35mm offset plus 5mm spacer so a 30mm offset with a 245/35/19 and i am fine. It was rubbing on that little tab in the rear fender which was part of the bumper. BTW i am on tein ss coilovers
Old Mar 10, 2010 | 06:37 AM
Chris Gregg's Avatar
Get Off My Lawn
I know there are many who do not have rubbing issues. However, I am running stock SE suspension with 18" 350z mags and 245x40x18's and have had ONE experience of rubbing. I was traveling and took a dip in the road too fast, result was the suspension dropped in the rear and rubbed the inside lip of the fender. Marked up about 18" of the tire on the outside portion of tread.
Didn't do any damage to the fender or tire, but I realized that if I ever choose to lower the car, I would have to be more mindful about clearance and rubbing under certain conditions.
If my tires were a little narrower, I don't think it would have rubbed. I just saying that in my experience, it is possible to rub. I would just consider getting a narrower tire.
Old Mar 10, 2010 | 11:22 AM
roggeezy's Avatar
Just roll them. It isn't that hard.
Old Mar 10, 2010 | 05:22 PM
soto2635's Avatar
im rubbing the fender well
Old Mar 10, 2010 | 08:35 PM
I have the 8.5 in the rear... No rub.. Rear is a finger length between tire and fender. I honestly don't think you'll need to worry. Get tires, but them on. and you'll be fine. I was riding around on blown struts with this setup and still didn't rub.
Old Mar 17, 2010 | 01:28 AM
8082KMAXSE's Avatar
I have 225/45/18 in front and 245/40/18 running on stock height and have no rubbing issues. When I had 245/45/18 in the rear I had a potential for rubbing but I bent up the area where the fender meets the bumper screw point. I barely could fit my finger between the tire and the edge of the fender. I also had to cut/shave off a little of the bumper in the wheel well. It didn't rub then ether. Other than that I plan to roll on Eibachs and Tokico Blues in the near future. So far so good. Just use your judgement.
Old Mar 17, 2010 | 05:17 AM
Deez00's Avatar
I have 350z touring18's and I don't rub at all. I'm not lowered yet but still it should be ok. My rears are 245/45/18's and it's just fine. I guess it will depend on how low youre gonna go.
Old Mar 17, 2010 | 11:25 PM
Ace06's Avatar
Fender Roll and 19's
Hey, I have 2006 M45 wheels with a 50mm off set, 8.5 inches wide on 245/45/19 tires with an H&R drop. The back tucks a little with no rubbing issues but barely clears. Fenders look untouched ( Metal Maxima's old car) You should be ok.
Old Mar 18, 2010 | 08:33 PM
HotMaxx02's Avatar
You wont rub the fender.
No need to roll it.
If you rub it will be on the inner wheel well.
Spacers will fix it.
I got same set up... 350z 8.5"s in the rear with 245/40's and only rub well on bumps
Old Mar 19, 2010 | 05:55 AM
sixteenXnine's Avatar
For what it's worth, the track of the Maxima is narrower in rear than front, so putting the wider rims on the rear helps even out the contact patches a little bit.
Old Mar 21, 2010 | 12:53 AM
Got my tires on. It rubbed =(. Had to roll the backs. Here are some pics with the new rims =)
Old Mar 31, 2010 | 03:12 PM
Will's Avatar
Hey guys, I managed to snag a rare set of 350Z 35th Anniversary Edition wheels too (they're even rarer up here in Canada).
One question: I can re-use my lug nuts and Nissan locking wheel nut with these Z wheels, or do I need to buy separate lugs from the stealership?
Hope to get your confirm before I slap them on tomm. I'm running P235/40R18 on my 2003.
Thanks!
Old May 8, 2010 | 01:28 PM
soto2635's Avatar
will 235/45/18 rub with the stock suspension?? i really dont want to have to put a 40 series b/c of the big gap
Old Jun 6, 2010 | 11:27 PM
tjmoney87's Avatar
Well I have 235/45/18 up front and 255/40/18 on the back and I don't rub at all on stock suspension.
Old Jun 7, 2010 | 05:32 AM
Shift_Max's Avatar
That is because your vehicle is not lowered.
Old Jun 7, 2010 | 06:22 AM
bob-lee's Avatar
All that's missing now is the center cap's..................
Old Jun 12, 2010 | 03:51 PM
Rods03Max619's Avatar
Rims looks G on the ride!!
Old Jun 13, 2010 | 03:16 AM
BLACKNESS MONSTA's Avatar
That looks sick NismoCefiro
Old Aug 11, 2010 | 12:50 PM
QnzMax's Avatar
Unfortunately I do rub with the 350z track wheels and rolled fenders. I'm running 245/40-18 all around and the back and front rub on big bumps.
Old Aug 11, 2010 | 01:10 PM
NmexMAX's Avatar
dot dot dot ...
Depends on the tire brand. I’ve used 2 different brand tires (same size) and one barely rubbed on one side (need to fix my beam) and the others were like riding on the fenders, every other pebble would rub.
This set-up is with 18x8.5 +33 all around and 5mm spacers in front and 15mm in back. That was fine for the ‘thinner’ tire. For the set of tires that rubbed most, I had to go to 10mm spacers in the rear, fronts were fine.
Semi old thread
Old Aug 11, 2010 | 05:33 PM
Gemner's Avatar
The tab that connects the bumper to the body is the biggest problem. Before I ground that down I would run sometimes with 2 passengers, now I only rub with 3 passengers if I take a big bump too fast.
Old Aug 11, 2010 | 08:59 PM
Rooney's Avatar
those rims look awesome on your car man.
Old Sep 13, 2010 | 01:14 AM
VQ'rInWLA's Avatar
Those wheels are the perfect compliment to what you got going with the whip bruh. Nooiiice!
Old Sep 22, 2010 | 07:04 PM
QueensMaxima83's Avatar
Rolled my Fenders today, world of a difference! No more rub with passengers. anyone on wide wheels and tires has to do it!
Old Dec 29, 2010 | 06:50 PM
Will's Avatar
These are some sweet wheels and they slowly grew on me this past summer. I also got a lot of compliments, and really love the OEM look.
I may like to do a drop next summer. Do you guys think H&R springs (1.6 F and 1.4 R) would work with these wheels. I don`t know of anyone on here who has our wheels with H&R springs.
Thanks!
Apr 16, 2020 05:15 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
Garrettz459
Sep 28, 2015 02:50 PM
