Is is possibe to tell if a car has a limited Slip from the vin?
Old Mar 13, 2010 | 06:38 PM
Zack342's Avatar
I know the the vin plate on the firewall list the trans code but can you tell if the car has a HLSD from the VIN number?
Old Mar 13, 2010 | 09:21 PM
QNO_A32's Avatar
an HLSD will have an H at the end of the trans code and open diff will have an A if im not mistaken...
Old Mar 14, 2010 | 07:55 PM
nismoSEXIMA's Avatar
5.5 gens will have a H and 2001 AE's will have a V for VLSD IIRC....
Old Mar 14, 2010 | 08:09 PM
Maxfli's Avatar
No, it is not in the VIN...
but it is on the ID plate on the firewall...
Trans Axle code for 6sp HLSD is RS6F51H...and RS6F51A for non-HLSD.
Old Mar 14, 2010 | 09:13 PM
Zack342's Avatar
So what is a RS5F51A? My car has a RS6F51H as listed on the the VIN plate in the engine bay. Recently my car has started showing signs of excessive input shaft bearing wear.So I purchase a used tranny from an 04 to replace it.
I bought the tranny from this car
I called the local nissan parts department to find out what the part # for the trans in the car is and they told me the replacement part number for the 04 with the vin is posted is 32010-7Y076 which is a 04 6speed LSD tranny.
I am really confused by what i am getting. I am hoping it is a replacement HLSD tranny since my car came with a HLSD but at this point don't know what to think since everyone tells me to look at the id plate but the id plate list a tranny that i don't know of.
I was am hoping since the vin pulls up HLSD trans as a replacement it must mean that the car has one?
Old Mar 15, 2010 | 02:52 AM
DennisMik's Avatar
That is a 5 speed without limited slip. RS5 means 5 speed, RS6 means 6 speed. nismoSEXIMA explained the letter.
Old Mar 15, 2010 | 06:25 AM
knight_yyz's Avatar
Toolie
i didnt know 04's came with a 5spd. i thought the altimas came with 5's
Old Mar 15, 2010 | 06:59 AM
Rydicule's Avatar
Don't you know who I am?
04's have a 5 speed automatic tranny...
Old Mar 15, 2010 | 09:42 AM
Unklejoe's Avatar
It looks like you purchased an automatic transmission to replace your 6 speed manual.
Return it and ***** at who ever gave you that (unless it was your mistake).
Old Mar 15, 2010 | 10:02 AM
Zack342's Avatar
No the car is a 6speed. The junkyard checked. It had 3 pedals. My only guess now is the transcode they entered at the factory when they generated the id plate was wrong.
Old Mar 15, 2010 | 10:09 AM
Zack342's Avatar
The 6 gen maxima automatic transmisisons are
RE5F22A - 5 Speed auto
RE4F04B - 4 Speed auto
Old Mar 15, 2010 | 10:13 AM
HotshotVQ35's Avatar
its a non hlsd trans
Old Mar 15, 2010 | 11:38 AM
Zack342's Avatar
Well that sucks but as long as it fits either way it is going in my car since the HSLD in there now has some bearing issues I wonder why when they pull the vin to get the part number for the transmission it gives them 32010-7Y076?
Old Mar 15, 2010 | 11:13 PM
Maxfli's Avatar
RS5F51A is definitely an Altima 5sp manual trans code without HLSD. Now, what that code is doing on an '04 Maxima ID sticker is anybody's guess!
The FSM lists two 6sp man trannys for the '04 Maxima:
If the 6sp tranny is actually coming out of the pictured car, it will be one of those transmissions and should mate right up with your '03.
And to finally answer your question, after the tranny is in, you can do a burnout and you should be able to tell whether it's a HLSD tranny or not!
Good luck!
Old Mar 16, 2010 | 10:59 PM
Zack342's Avatar
Good luck!
Your guess is as good as mine. Maybe the person who greated the tag at nissan screwed it up? there is no way they would have installed a 5mt in a maxima and the owner of that car not notice.
I called dave b. and he looked up the options list on that car for me
Old Mar 17, 2010 | 04:25 AM
Rydicule's Avatar
Good luck!
I do believe it is also the code used in the 00-01 manual Maximas. I don't know about altimas...
Old Mar 17, 2010 | 08:17 AM
asianstyle's Avatar
Your are correct. I have an 01 AE and I have the V at the end of my trans code. Also I have to get some bearings in my transmission replaced probably next week. Car making weird rubbing noise when in gear. Tranny mechanic showed me how bad my drivers side axle had to much movement in it. And said that my bearings were shot. Not gonna be pretty on the pocket $$$
Old Mar 17, 2010 | 10:22 AM
Maxfli's Avatar
Actually, the trans codes for the '00-'01 5 sp Maximas are RS5F50A and RS5F50V according to the FSM...but that's neither here nor there.
If Dave B pulled from the Nissan system and it says that VIN had HLSD, it probably does...
Lakersallday24
Jun 16, 2019 01:35 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
Team STILLEN
Aug 10, 2015 04:29 PM
Tanvirkamal
Aug 5, 2015 01:32 AM
