MAF sensor problem , its frustrating
Old Mar 14, 2010 | 11:37 PM
mohsinkhan35's Avatar
SO i bought a 2003 Maxima with an apexi air intake installed. Few days ago my SES light came on and the code returned pointed to MAF sensor. I took it out cleaned it still no go. I am looking online to buy sensor since dealer told me its gonna cost $600. So when i searched online, my defective sensor looks like the one from Sentra. And when i look at 03 maxima, it seems that it wont fit (screw positions are different than holes on intake).
Also there is no part number engraved on the current defective sensor.
Which one do you guys recommend, i have read online that AM600 are long lasting ones, but will it fit my after market Apexi intake?
Bring in any comments suggestions that would help me since i need my car up and running soon.
These are pictures from my defective MAF sensor
Old Mar 14, 2010 | 11:56 PM
NIGHTMAREuki's Avatar
you can get the 5 gen one and swap the thermistor or get used one from local junk yard
Old Mar 15, 2010 | 07:13 AM
mandyfig's Avatar
Do a search, there's tons of info on MAF. You will regret it if you do not read the info.
Old Mar 15, 2010 | 09:22 AM
LongIslandMax's Avatar
In case you haven't already noticed, what you want to do is contact DAVEB and let him know you need a replacement 2001 maf sensor. IIRC its right around $85 shipped. Then do the thermistor swap, and you'll be good to go.
Old Mar 15, 2010 | 09:46 AM
Ghost_54's Avatar
Read through this thread, fix your problem and save money.
http://forums.maxima.org/5th-generat...-pictures.html
Old Mar 15, 2010 | 10:52 AM
e-subliminal-2's Avatar
Are you noticing any other problems that are pointing to your maf? Rough idle? laggy rpm, any hesitation at wot? If not it doesn't have to be your maf.. I'd let it sit for a few days or a week or two and see if the light goes away on it's own. Happened to me. ses light for maf, however no symptons. Left it alone and a week later it went away. 7 months and clean so far.
Old Mar 15, 2010 | 02:02 PM
mandyfig's Avatar
^+2. Need to observe and note them down. Then post here so we can help.
Old Mar 26, 2010 | 09:44 AM
Yes i have all the problems mentioned above, laggy rpm, car won't go past 2500 rpm, rough idle and not to forget, gas needle went down unreal.
Old Mar 26, 2010 | 12:31 PM
nismopc's Avatar
Have you attempted to reset ECU and perform all of the relearn procedures? Sounds like your ECU is in limp mode. Might not actually be your MAF...
...food for thought.
First time that happened to me, I thought my freaking engine blew. Had no clue what happened...
...that was almost 90k miles ago. ;-)
ballerchris510
Sep 10, 2015 09:35 PM
lux97Max
Sep 4, 2015 05:42 PM
dcardello
Sep 3, 2015 11:44 PM
