What sensor is THIS?? 2000 maxima
Old Mar 15, 2010 | 08:34 PM
a33_ridah's Avatar
Just poking around under the hood of a 00 maxima i bought last week to start my gab mod...as i did on my 03.
I notice an extra sensor i dont recall on my 2003.
right behind the snorkel, before the filter housing there is a sensor stuck down into the black tubing. (long before the maf)
trying to wiggle it out..i pulled on plug too hard and next i know i got two loose wires...i just removed snorkel for now and went for a spin.
..now the service engine light is on..
got dark, didnt try wiring it back up.
what is this sensor?
Thanks in advance
Old Mar 15, 2010 | 08:44 PM
P. Samson's Avatar
It's the Absolute Pressure Sensor. Used to determine ambient air pressure. Relocated adjacent to the ECM on '01 and later cars.
Old Mar 15, 2010 | 09:00 PM
a33_ridah's Avatar
where can i stick that sensor once i plug it back in (actual plug is loose from two wires) to get rid of cel
Old Mar 15, 2010 | 09:43 PM
P. Samson's Avatar
Just tie-wrap it close to where it was and not close to anything hot.
Old Mar 15, 2010 | 10:23 PM
Feldman's Avatar
pretty sure that's the intake air temp sensor not the pressure sensor.
You can see it on page EC-21 of the FSM
If you get your codes pulled it should be a p0110
Old Mar 15, 2010 | 11:50 PM
P. Samson's Avatar
Yup, my mistake, it is the IAT sensor that is installed in the grommet in the inlet duct......I saw "removed snorkel", and assumed it was the APS. When you fix the harness connector the yellow/green wire goes to terminal 1 of the sensor, black to terminal 2, obviously.
Old Mar 15, 2010 | 11:59 PM
a33_ridah's Avatar
so can this sensor still be hanging once i wire it up?
and even tho its two wires, its not obvious to me what is terminal one or two of the two?
in the am tomorrow, ill play with it.
Old Mar 16, 2010 | 12:55 AM
knight_yyz's Avatar
Toolie
yes you can leave it hanging, preferable someplace close to the battery so it will get an accurate temperature of the air coming into the engine bay.
Old Mar 16, 2010 | 08:38 AM
mandyfig's Avatar
Pics would really help. Can you post?
Old Mar 16, 2010 | 10:38 AM
a33_ridah's Avatar
first image is of another sensor that was rested in the snorkel itself (using it as a mount) i relocated it lower in a #10 hole. loose wire is visible in here
second image is the actual sensor thats the issue
Old Mar 16, 2010 | 10:49 AM
a33_ridah's Avatar
so i got the top gray half separate from the bottom black pointy part..and in the black part are two metal pins the wire must pass through to contact...
thinking about getting rid of gray part and tapping straight into black part...as i cant see through gray to know if its pushed in enough or not???
makes sense?
mrc00l88
Jan 25, 2024 01:14 PM
kjlouis
Nov 24, 2018 06:09 AM
jholley
Aug 11, 2015 09:38 AM
niZ
Aug 7, 2015 10:18 PM
yat70458
Aug 3, 2015 01:16 PM
