Clunk ClUnK ClUnk-Top hat?
Old Mar 25, 2010 | 07:57 AM
e-subliminal-2's Avatar
Was driving home yesterday and all of a sudden I randomly start hearing clunks, the more I drive my car the more the driver front strut sounds like it's about to fall off. I worried it could be axle, checked, thought about wheel bearing, checked, steped on the core support and basically hoped and it looks like my center nut in the top hat (that holds the top hat on) was moving up and down. Iknow your shift boots and a few other things will cause it to squeek; No, this is no sqeek. It's a complete loud annoying Clunking sound. Anyone run into this before? Also cause of these going bad? I'm assuming the rubber components wear out.
Any help is appreciated. Thanks.
Old Mar 25, 2010 | 09:42 AM
1800bucks's Avatar
Don't have an answer for ya, but I too have the same clunk, from both the front and the back! I'm so annoyed with this car that I'm half tempted to look into that $199 a month deal on the 2010 Altimas. Hopefully it's just something simple and NOT expensive. If so, I'll go ahead and fix it.
Old Mar 25, 2010 | 10:45 AM
Figured it out, the top nut just needed tightening. Grab a pair a vis grips. Put them on the strut. And tighten the top bolt. Problem fixed.
Old Mar 25, 2010 | 01:27 PM
1800bucks's Avatar
As soon as the rain stops I'll go out and give that a try. Thanks for the heads up.
Old Mar 25, 2010 | 01:32 PM
vball_max's Avatar
You could try a torque wrench too......
It might be a little more accurate than a pair of vice grips.
Old Mar 25, 2010 | 06:19 PM
NismoAce's Avatar
Pretty sure the vice grip is to hold the strut. But yes a torque wrench is your best friend when it comes to suspension.
Old Mar 25, 2010 | 07:57 PM
As stated, I meant to hold the strut from spinning. I just used a 17+ breaking bar to tighten in.
Unclejunebug
Apr 2, 2016 05:42 AM
MaxLvr21
Oct 17, 2015 12:11 PM
msellas
Sep 23, 2015 09:16 PM
