Tar on rims
Old Mar 27, 2010 | 06:51 PM
Country24's Avatar
Tar on rims
Went to go wash the max today and i noticed i had a bunch of old tar on the rims. I tried to use a tar remover at auto-zone kinda worked but not really. Is there something else i can do to get it off? If so just dont want to hurt the clear coat. Thanks
Old Mar 27, 2010 | 07:14 PM
Mr. Brett's Avatar
Rain-X Bug and Tar remover works wonders. It's a gel, and it's supposedly clear-coat safe.
Spray it on, let it set for about two minutes, hit it with a sponge and hose it off.
Do this BEFORE you wash your car, though. And make sure the stuff is completely washed off. If it gets mixed in with your soap, it'll neutralize the soap and leave you with a bucket of dirty water.
Check out the Detailing forum for more stuff you can use.
Old Mar 27, 2010 | 07:44 PM
jasonmax's Avatar
proper wheel cleaner also can take that off
Old Mar 28, 2010 | 08:41 AM
J-Rod's Avatar
WD40 will also. Its cheaper than others. Just make sure rim is cool, and do it before the wash.
Old Mar 28, 2010 | 08:53 AM
afy4u's Avatar
Tar on rims
I had the same problem and used Goof Off. It stinks, takes time but it WORKS!
Old Mar 28, 2010 | 09:19 AM
ricerocket336's Avatar
you can also try gasoline on a rag rub it lightly and it will come off guranteed.. ( we use this method at the detail shop i work at, it works wonders).
Old Mar 28, 2010 | 01:07 PM
phatboislim's Avatar
acetone as well
Old Mar 29, 2010 | 11:26 AM
mandyfig's Avatar
Rain-X should work. Try the industrial de-greaser 1st. Spray on, wait then scrub and hose off.
Old Mar 29, 2010 | 11:52 AM
CMax03's Avatar
acetone as well
Don't use this it will compromise your clear coat! WD40 wll remove it and if it's super stubborn a plastic scraper will work wonders
Old Mar 29, 2010 | 12:00 PM
Rochester's Avatar
After you get your wheels clean of tar, keep the wheel surfaces waxed properly. I've been using Wheel Wax for the last 8 years, applied twice a year. Except for a few stone scratches, they look brand new, and they wash up just as easily as a well-waxed car surface does. Granted, I don't drive on them in the winter, but it's still good advice, I think.
http://www.wheelwax.com/
Old Mar 29, 2010 | 12:11 PM
Gollum67's Avatar
acetone as well
Ooooh, Careful with this one. You can say goodbye to your clearcoat if you use it.
Old Mar 29, 2010 | 12:15 PM
bigleman's Avatar
Advocatus Diaboli
as with all asphalt products, "Tar" can be removed with any solvent or other petrol bast product
its just up to you to know if that will mess up your wheel finish
Old Mar 29, 2010 | 01:58 PM
mandyfig's Avatar
Acetone, that's nasty stuff. Those are for manicures only.
Old Mar 29, 2010 | 01:59 PM
Craig_0530's Avatar
I choose not to comment.
Old Mar 29, 2010 | 06:39 PM
mandyfig's Avatar
Goop Off will do the trick all the time.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Luigi623
Sep 21, 2015 01:42 PM
mikeymouse1995
Sep 18, 2015 06:42 AM
0m3nc0w
Sep 11, 2015 05:21 PM
