Knock sensor location on a 5.5 gen???
Old Mar 29, 2010 | 05:34 PM
19max95's Avatar
I need to know how hard it is to change one, already have a brand new one from ebay. Thanx
Old Mar 30, 2010 | 03:39 PM
wyche89's Avatar
not hard at all.. you're gonna need a 10 or 12mm socket and a ratchet.. the knock sensor is located between the 2 sides of the lower intake manifold.. if your intake is stock, you might need to remove it.. if you're standing on the driver side of the car facing the engine bay, look down between the 2 sides of the lower intake manifold, and you should see it attached to a clip, which is attached to a wire.. unscrew the bolt with the ratchet, un-clip the old sensor, clip the new one in, bolt it up, and you're good to go
Old Mar 31, 2010 | 02:26 AM
19max95's Avatar
thanx man, will try that
Old Apr 18, 2010 | 12:31 AM
Rods03Max619's Avatar
Damn that good!!
kjlouis
Nov 24, 2018 06:09 AM
Finkle
Sep 27, 2015 09:53 PM
tcb_02_max
Sep 11, 2015 12:23 PM
maxinout93
Aug 20, 2015 02:17 AM
MaxStock
Aug 12, 2015 08:33 AM
