Saggy Door Fix
Old Mar 29, 2010 | 06:51 PM
NismoAce's Avatar
Saggy Door Fix
I did not find any threads on this besides buying new hinges and watching it happen again.
These hinges are just stupid. You can tell how it wears.
I am cheap so I went to home depot and got a pack of metal washers and loosened the bolts on the bottom hinge to door and slid two of them behind there and tightened it down. The results are a door that closes just fine and looks good as well. If it sags after the washers on my car after some time I will buy a new hinge and wait till it sags and then do the washers again. Hopefully there wont be a need for that.
Old Mar 29, 2010 | 06:53 PM
PulsarGTS's Avatar
I have saggy doors too, but @ 150,000miles I'm saying **** it to anything but essentials.
Old Mar 29, 2010 | 06:54 PM
NismoAce's Avatar
lol. It was like $2 at the depot and 5 min.
Old Mar 29, 2010 | 07:12 PM
mandyfig's Avatar
Mine has been holding up. Dropped a round washer, abiut 1/8" thick. Still looking good.
Old Mar 29, 2010 | 08:34 PM
arcueda's Avatar
ive been thinking about doing this, thanks for the heads up.
Old Mar 29, 2010 | 08:52 PM
Czerkas's Avatar
Hmm my doors seem fine right now but I remember how annoyed I was with my old Sentras doors. I will have to write this down somewhere for future reference.
Old Mar 30, 2010 | 07:03 AM
AnDyMaN's Avatar
No fender take off? 5 min is fAst...
Old Mar 30, 2010 | 07:15 AM
bigpopaj369's Avatar
there is a couple of threads out there that were posted in fairly recently but glad u got it fixed i did the same thing last summer, works perfectly!
Old Mar 30, 2010 | 08:28 AM
2slow's Avatar
Did you put the washers on the door or body side of the hinge?
Old Mar 30, 2010 | 09:05 AM
iirc i did the door
Old Mar 30, 2010 | 09:17 AM
nissandrvr98's Avatar
great fix...ill be re-doing the max this weekend actually.
this was the same fix i used on my old altima.
Old Mar 30, 2010 | 10:42 AM
mandyfig's Avatar
It will help if you have an extra set of hands. Otherwise use a jack to support the door, but yes, takes minutes. You will need an offset wrench to get to the bolt.
Old Mar 31, 2010 | 06:09 AM
NismoAce's Avatar
No fender take off.... Yes a second hand or a jack would be good. I used my knee.
Old Mar 31, 2010 | 09:09 AM
mandyfig's Avatar
The jack with a block of wood will serve you well.
Old Mar 31, 2010 | 10:00 AM
spydermonkey's Avatar
Any way you could post a picture of the washers in the hinge? I've got the same problem...it drives me crazy. I think this could possibly be the best $2 and 5 minutes I've ever spent.
Old Mar 31, 2010 | 02:15 PM
mandyfig's Avatar
I think I may have posted pics on another saggy door thread. Search it.
Old Mar 31, 2010 | 04:03 PM
MAXIMA_STYLE's Avatar
what size washers as there are many different sizes?
Old Mar 31, 2010 | 04:25 PM
mandyfig's Avatar
As long as the hole will fit your bolt, and it is 1/8" thick, you are good to go. I will take a pic and post. I bought a few and kept some.
Old Apr 1, 2010 | 09:43 AM
Sylcurt's Avatar
Got exact problem...was quoted $300 from the body shop, plus color matching (white in my case) I am glad a shim worked...I will try it....
Old Apr 30, 2010 | 09:52 PM
Rods03Max619's Avatar
Damn 300 is alot but good to know we can ghetto fix the doors
Old May 1, 2010 | 12:07 PM
ZGadson's Avatar
You didn't look hard enough.
See Sig or Here
Old May 4, 2010 | 03:48 PM
mjhuffer's Avatar
What size washers did you use?
Old Feb 20, 2011 | 02:34 PM
RR5's Avatar
RR5
This might help http://forums.maxima.org/7507022-post64.html
I'm off to pick up some metal washers and if I can, I'll throw them on in the parking lot.
Old Feb 21, 2011 | 03:41 PM
mandyfig's Avatar
1/8" washer will do the trick!
Old Jul 21, 2011 | 03:24 PM
skyruler87's Avatar
Last year I bought a 2000 maxima and took it for state inspection. It failed because of the door hinges. They wanted me to get it repaired so I went home and unbolted the door hinges slipped 2 thick washers in the lower hinge and bolted it back. Prob. solved took it back and it passed inspection without any prob. It worked so beautifully that I even forgot that my hing is wearing off until I read this thread. It is still working and no one can tell that there is any sag in the door. But if you grab the door and lift it up and down, then it moves and then you can tell that it is not solid and that there is something wrong with the hinges. but I dont ever do that so it doesnt bother me. So, yea its the best and the cheapest fix I have ever seen.
I am so glad that I know about this site. Now, tomorrow I am replacing my steering wheel pressure hose(another MAJOR and expensive prob with all the maximas). We'll see how it goes. So, all of you guys be ready because yours will leak one day too. It will happen to every maxima out there. Its just a matter of time. My maxima has 160K + miles.
Old Jul 21, 2011 | 04:17 PM
Eirik's Avatar
http://www.popularmechanics.com/cars...enance/4350218
[/thread]
Old Jul 24, 2011 | 06:17 PM
NismoAce's Avatar
My hinges as still perfect since the fix
Old Jul 24, 2011 | 07:28 PM
T_Behr904's Avatar
Glad I found this! My driver door is sagging just enough to be an annoyance.
Old Jul 25, 2011 | 04:25 AM
phatboislim's Avatar
i'm taking mine to the shop, eff it. i think i need to get my wheel bearings and ball joints done so ill just get it all done at once
Old Jul 25, 2011 | 12:09 PM
7speed's Avatar
Thanks for bringing this back to life.
I never realized how easy of a fix. My drivers doors needs a lift, so I'll try it this weekend.
Old Jul 25, 2011 | 04:19 PM
tothemax2003's Avatar
do you put the washers only on the bottom part of the door
Old Jul 25, 2011 | 07:41 PM
rigon28's Avatar
im gonna try this tuesday
Old Jul 25, 2011 | 08:15 PM
nsnrider's Avatar
yes, only on the bottom hinge to give it a boost up.
Old Jul 26, 2011 | 06:23 AM
jaysoldsx's Avatar
cant we buy new door pins and bushings or do we have to replace whole hinge
Old Jul 27, 2011 | 01:29 PM
mandyfig's Avatar
The washer works so why replace anything...
Old Jul 28, 2011 | 07:29 PM
LongoTE's Avatar
How much were all your doors sagging? I tried washers that looked exactly the same installed (as picture in other thread) but that just made my door bump on the latch like it was too high. So i got the joy of removing them too. I just hope when i install thinner washers, the doors wont sag even more and need the thicker ones.
And my door jams are nasty. Like someone just took a spraycan of grease and shot the entire area for me to clean up. So what shoulda been a clean job was very different. Sometimes i wanna take the previous owners and
Old Oct 9, 2011 | 08:15 PM
HastySpartacus's Avatar
the sag is so bad on my 2000.....i cant open the door
can u throw up the link to the install pics so i can try n bypass this hinge replace.....#COLLEGESTUDENT BUDGET
Old Oct 9, 2011 | 08:23 PM
Mr. Brett's Avatar
Hmmm...
Glad someone dug this thread up. My G has a little bit of a saggy door...guess I'll try this out.
Old Oct 9, 2011 | 09:02 PM
nelledge's Avatar
"I'm just sayin'..."
Take the time to read the thread and you may find what you're looking for. Post #21.
Where's John's spoonfeeding jpeg?
Old Oct 10, 2011 | 05:51 AM
Rochester's Avatar
I can't read every thread that comes back to life. The spoonfeeding baby is in my image gallery... go play.
However, good to know this simple trick. Better a 50 cent washer than an hour's labor at the dealership.
