wiring question...need help please
Old Mar 29, 2010 | 08:40 PM
2 GO B4's Avatar
I am trying to wire an accessory LED light to be able to come on and off when I arm/disarm the alarm(factory) through the remote.....
I didn't want to go the route of the light coming on when the ignition was off and turning off when the ignition was on...
I thought of one way that should work...but wanted to get your opinion first...I think that if I can somehow wire the positive to the blinking red OEM LED in the dash (next to the digital clock in the 5.5 gens) that this should accomplish what I want to do...but not sure...want to get some opinions before i mess with the dash stuff ..
Has anyone tried this or knows of a different way to get this done
Thanks in advance for any input guys.
Old Mar 30, 2010 | 06:59 AM
jonnypax09's Avatar
well its a lot like trying to wire leds in your exterior door handles. really the only thing i can think of that corresponds with the remote is the dome light, which as you know goes on and off as you lock and unlock your car. your best bet would to tap those lines. try this thread it might answer some of your questions
http://forums.maxima.org/5th-generat...s-diy-how.html
Old Mar 30, 2010 | 07:16 AM
jonnypax09's Avatar
well its a lot like trying to wire leds in your exterior door handles. really the only thing i can think of the corresponds with the remote is the dome light which as you know goes on and off as you lock and unlock your car. your best bet would to tap those lines. try this thread it might answer some of your questions
Old Mar 30, 2010 | 07:22 AM
nissandrvr98's Avatar
just wire it to the alarm fuse-this grounds when alarm is armed. thats how i did my dancing LED's.
Old Mar 30, 2010 | 06:03 PM
2 GO B4's Avatar
the alarm fuse in the engine bay...box behind the battery...if this is the one...i tried it and it didn't seem to work....if not..which other fuse should i use?
Old Mar 31, 2010 | 12:08 PM
2 GO B4's Avatar
Bump.....any input guys???
Old Apr 16, 2010 | 06:50 PM
2 GO B4's Avatar
anybody????....wow...I can't believe none of you skilled cats out there know how to do this...or are willing to pass along the info....
Old Apr 16, 2010 | 07:23 PM
DennisMik's Avatar
on a 2001, fuse # 12 (10 amp) in the panel under the dash powers the led by the clock. Its probably the same on your 2002
Old Apr 17, 2010 | 06:09 AM
2 GO B4's Avatar
Hey Dennis. Thanks for the reply. Looked under the dash and I have no equivelant fuse as you stated. What is the name of the fuse on the label corresponding to fuse #12?
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
