Installed turbo timer and can't find VSS signal...
Old Apr 8, 2010 | 12:51 PM
rroderiques77's Avatar
Demodded and Forgotten
I figured I would get more responses in here. I just installed a Greddy Auto Turbo Timer and cannot find a VSS signal due to the fact that my A33B does not have a VSS (manual). Greddy is telling me I am pretty much SOL with that feature of the device. The turbo timer still works if I set a time for it to run after ignition is turned off, but I would like the Auto function to be enabled (hence the fact that I purchased this particular model) and it won't with a speed signal.
Is there another SAFE place to get the VSS signal?
Old Apr 8, 2010 | 12:53 PM
kzoosho's Avatar
cant you pick up the signal from the ecu to the cluster?
Old Apr 8, 2010 | 01:23 PM
No VSS wire at PCM. It is probably a bynary signal.
Old Apr 8, 2010 | 01:34 PM
VSS from Quest may work. I will buy one and wire it in. Will see what happens.
Old Apr 8, 2010 | 02:58 PM
kzoosho's Avatar
The 4th gen vss sensor will fit in if thats what you need. I know. Im using the 4th gen vss in my 6sp.
Old Apr 8, 2010 | 03:45 PM
What year 4th gen is it and auto or manual?
Old Apr 8, 2010 | 03:50 PM
kzoosho's Avatar
same sensor for both but mine came out of a 97 auto.
Old Apr 9, 2010 | 05:19 AM
burnurass's Avatar
vss wire is behind the cluster behind the speedometer. I forgot the color but if you search in the audio forum they will have the answer there because a lot of Navigation units need the VSS wire. Good luck
Old Apr 9, 2010 | 06:44 AM
SurraTT's Avatar
HR Swap Pioneer
Wire 68 on the ECU plug is the speed signal.
at 6mph its 2.5 v
at 19 mph its 2.0 v
page EC-148
im a 6spd too and i have this wire, its to tell the ECU how fast the car is going for cruise functions and i think speed limiter.
Old Apr 9, 2010 | 07:14 AM
vastmax's Avatar
pretty sure its a pink wire behind the cluster.
Old Apr 9, 2010 | 11:17 AM
Wire 68 on the ECU is VSS, which is in fact the pink wire behind the cluster.
Thanks everyone for your help!!
Cotozic
Jun 28, 2017 08:01 PM
max_speed97
Aug 26, 2015 07:46 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
kirkhilles
Aug 8, 2015 10:53 AM
