Better response after tightening the pedal? WTF?!
Old Apr 12, 2010 | 02:29 PM
JiggaD369's Avatar
The other day while I was cleaning the car and was only poking around when for the first time ever, I saw that there was a bolt and nut going though the middle of the gas pedal assembly.
I checked to see if it was loose and indeed it was kind of loose. So I took a 10mm socket and tightened it up a couple notches. I then proceeded to do a pedal position relearn and the pedal response became so much better, I can't explain it.
I doubt that this is a real adjustment for the pedal. Maybe I'm having a placebo effect.
Old Apr 12, 2010 | 03:48 PM
PLACEBO.
Old Apr 13, 2010 | 02:52 PM
JiggaD369's Avatar
But I swear!
Old Apr 13, 2010 | 02:58 PM
Z-Powered's Avatar
If you had a 5th gen which has drive by cable, maybe. But the 5.5 gen has drive by wire.
Old Apr 13, 2010 | 03:56 PM
tcaughey's Avatar
^^ Please explain? I thought a cable was essentially a bundle of wires. Or of the sort.
Old Apr 13, 2010 | 04:17 PM
5 ltr. beater's Avatar
the DE-k's are the last of the cable operated TB's. the VQ's in the 5.5 have drive by wire. no more throttle cable.
Old Apr 13, 2010 | 04:41 PM
sascuderi's Avatar
I love good old throttle cable!
Old Apr 13, 2010 | 05:33 PM
JiggaD369's Avatar
I love my new placebo effect.
Old Apr 13, 2010 | 05:44 PM
Mr. Brett's Avatar
This. Toyota could have prevented their whole problem had they just stuck to cable-driven throttles.
Drive-by-wire is a PITA. I'd much prefer a cable-driven throttle body over our pathetic electronic TBs.
Old Apr 13, 2010 | 06:27 PM
Z-Powered's Avatar
^ x2. But one upside to DBW is no more IACV to short out the ECU.
Old Apr 13, 2010 | 08:08 PM
JiggaD369's Avatar
As for throttle cable, I know someone who just had the Toyota DBW problem happen to them and they have a 2000 Corolla. I thought the problem was only extensive to the DBW cars but I guess not. Even their throttle cables are failing now.
As for my excitement above, I think the tightening of the bolt didn't do anything to the actual response but I think the pedal is just harder now to push but somehow it feels I need to press on it less in order to get to the respective accleration.
Old Apr 13, 2010 | 09:20 PM
dewd's Avatar
you probably raised the pedal or angled it better so your foot hits it and pushes it lower slightly giving u more power...
sorta like when u adjust your seat all the way to the steering wheel and u cant help but floor it everytime. lolll
Old Apr 14, 2010 | 03:50 AM
Norm Peterson's Avatar
If you took a little "free play" out of the pedal assembly, initial tip-in at your foot will translate to more happening at the throttle plate.
Norm
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
