Pulls hard to the right when accelerating partial throttle
Old Apr 17, 2010 | 07:29 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Some hoosier mounted my new tires in front today and apparently ****** something up.
Any accelerating or throttle above about 5% results in the car pulling hard to the right. When I let off the gas it immediately corrects itself. This NEVER happened before. My suspension is worn out, but I had no problems like this. When coasting it drives completely straight. Interestingly, at WOT it does not pull.
I did not have time to take it back and drove about 180 miles today. The issue never varies. Also, sometimes it feels like the tires are wobbling. I can feel it through the steering wheel.
I assume if the tires didn't balance they would tell me, so idk. He was an idiot b/c my rims are even more scarred now (didn't notice until this afternoon).
I know I'm gonna have to go back, but I need to know what I'm talking about in case it is their fault and not the tires. Any ideas will be greatly appreciated!
Old Apr 17, 2010 | 08:36 PM
DrunkieTheBear's Avatar
Turbo'd Saab
check to see if the lugs are all tightened.
Check the ball joint...someone one here had his just pop out recently for no reason (I know it sounds weird but I saw it first hand)
Check the axle (any leaking, breaks)
other then that....thats all that I can think of besides an alignment. An alignment is always a good idea with new tires.
Old Apr 18, 2010 | 07:55 AM
Bad *** Newb
Wouldn't the ball make a popping noise when turning sharp, though?
Old Apr 18, 2010 | 09:59 AM
Fresh96se's Avatar
I had a similar issue about 2 months ago car would pull unexpectedly to the right under acceleration. Jacked'er up and found my control arm bushing was done. New one cost me like 90 bucks.
Old Apr 22, 2010 | 03:25 PM
Bad *** Newb
Bump remounted rims, no change. Any other ideas?
Old Apr 22, 2010 | 04:24 PM
VQP0WER's Avatar
Just as a test only, swap the two front tires and see if the wants to go to the other side.
If it stays the same, sounds like the CV.
Old Apr 22, 2010 | 05:37 PM
Bad *** Newb
Sounds like I need to go kick some hoosier ***. There was nothing wrong with it before
Old Apr 23, 2010 | 06:58 PM
VQP0WER's Avatar
It may just be a defective tire, that's why I told you to swap them around. Let us know!
Old Apr 23, 2010 | 09:58 PM
Rods03Max619's Avatar
That's messed up you should go back to the shop who did the job.
Old Oct 21, 2015 | 02:11 PM
crazy97's Avatar
I love how these threads end with no solution. What was the problem? Im having this issue for the last year..
Old Oct 21, 2015 | 03:17 PM
foodmanry's Avatar
Da Roller Coaster!
Lower control arm.
Old Oct 21, 2015 | 06:04 PM
crazy97's Avatar
Originally Posted by foodmanry
Lower control arm.
That was Fresh96se's solution. I was hoping to see what the OP/Child_uv_KoRn found.
Old Oct 21, 2015 | 08:34 PM
DennisMik's Avatar
He is active here so hopefully he will.
But pulling to the side when you accelerate is classic worn LCA bushings.
Old Oct 21, 2015 | 10:07 PM
crazy97's Avatar
I put new ones on trying to troubleshoot this..
Old Oct 21, 2015 | 11:11 PM
Bad *** Newb
I wrecked it and bought one with HLSD. Problem solved
Old Oct 22, 2015 | 04:49 AM
losifanatic's Avatar
I had this issue too with my 2k. Power steering fluid leaked down on the lower control arm and ruined the bushings. Replaced bushings and fixed my issue
Old Dec 30, 2015 | 08:47 AM
swaayze's Avatar
Thanks. Think I'm in this boat. PS fluid has been leaking for quite some time and I've ignored it (except for the occasional fluid level check and top, which it rarely seems to need). A short time ago I noticed the steering feeling less solid and a bit jerky at times, and now noticing the pull under acceleration. Will start with examining the control arm bushings.
Love this forum!
Old Dec 30, 2015 | 09:35 AM
DennisMik's Avatar
ATF oil (which is what the power steering uses) will rot the lca bushings. This is well known to us old timers.
Replace the high pressure power steering hose, which is most likely the cause of the power steering leak.
Old Dec 30, 2015 | 07:52 PM
crazy97's Avatar
Turns out my new tires were crap. Switch them left to right and see if it changes direction of pull.
JoshG
51
Sep 21, 2015 10:41 PM
97_GXE
Sep 15, 2015 06:47 AM
Maxxx10
Sep 13, 2015 03:16 PM
jcvgn
Sep 10, 2015 08:03 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
