uneven drop wtf??
Old Apr 17, 2010 | 09:58 PM
soto2635's Avatar
uneven drop wtf??
i swapped the suspension in on my maxima and all corners are good except the front passenger side it sits a little lower than the driver side it barely has any clearance and it rubs like a **** when i hit bump and dips, i checked to see if the nut was on to tight but nothing?? what could it be a bad strut??
its sitting on staggs sruts and maxspeed springs
Old Apr 17, 2010 | 10:16 PM
00o30's Avatar
i have the same problem, but my passenger side sits about 1/2 inch higher than the driver side. i have maxspeed as well.
Old Apr 17, 2010 | 10:21 PM
soto2635's Avatar
mines just the oppsite of yours, what did u do to fix it? im thinking of running a smaller tire i currently have 245/45/18 on there. thinking of going 225/40/18 to see if that will fix it
Old Apr 17, 2010 | 10:24 PM
00o30's Avatar
i did not fix it, been driving like that for 20,000miles.
Old Apr 17, 2010 | 10:27 PM
e-subliminal-2's Avatar
Damn dude, I got worried at first thinking it was the driver one, Didn't want you thinking I sold you something faulty. Only thing I can think of would be struts.. They sat flush on my car..
Old Apr 17, 2010 | 10:57 PM
soto2635's Avatar
no its not the cut one its the other one weird huh??
Old Apr 17, 2010 | 11:18 PM
I wanna say struts, did you check to see if it's blown? Mine sat fine. I've heard some people claim new struts lowered their car 1/2" or so which is kinda weird but idk... It can't be THAT much off? 1/4"? 1/2"??
Old Apr 17, 2010 | 11:27 PM
Unklejoe's Avatar
Struts have nothing to do with how high the car sits.
Check to see if the spring is aligned properly on the spring perch.
DO NOT run two different size tires on the same "axle" (different driver side than passenger side).
Old Apr 17, 2010 | 11:35 PM
a33_ridah's Avatar
i have the same issue in the rear, pass. side being lower than driver rear.
on illuminas and vogtland spring...another member said it had something to do with rear "beam"
try re-seating your springs.
Old Apr 17, 2010 | 11:48 PM
Gemner's Avatar
are the springs aligned correctly on the perches?
Old Apr 17, 2010 | 11:51 PM
BIG C's Avatar
yea my car is the same way sittin about a 1/2 inch higher on the driver side.
Old Apr 18, 2010 | 08:22 AM
soto2635's Avatar
yea its sitting fine, as for the tires im not going to run 2 different size tires jusr movw the front to the back
Old Apr 18, 2010 | 09:07 AM
2slow's Avatar
That's the wrong answer.
Damper gas pressure will effect ride height, where less pressure will reduced ride height. Also, if the spring perch was attached (welded) in the wrong position, manufacturing defect, the ride height will be effected.
Old Apr 18, 2010 | 09:30 AM
soto2635's Avatar
i see so most likely its a bad strut then??
Old Apr 18, 2010 | 10:38 AM
soto2635's Avatar
problem solved, i moved the 225/40/18 to the front and moved the 245/45/18 to the rear. im just going to get another set of 225/40/18 or 235/40/18
Old May 7, 2010 | 11:36 AM
soto2635's Avatar
its gotten worse the passenger side is really low now, and the tire is tucked it asll good if im in the car by myself but if i have passengers it rubs like crazy
passenger side
driver side
Old May 7, 2010 | 12:20 PM
ZGadson's Avatar
Maybe swap the front springs? Body weight might even out the car when you're driving it at least. Just a thought.
Old May 7, 2010 | 02:40 PM
a33_ridah's Avatar
someone else chime in.
in the rears the problem has something to do with the rear beam not being centered after spring swap.
iv been told this, but not sure who re-centers the beam.
Old May 7, 2010 | 06:55 PM
junglee Z's Avatar
keep fat chicks out of your car mayn and that suspension won't get saggy
time to upgrade struts
Old May 7, 2010 | 07:43 PM
00o30's Avatar
I am wondering if it has to do with the rear lateral link bushing because the bushing on mine is cracked just like a worn motor mount bushing.
Old May 7, 2010 | 10:46 PM
soto2635's Avatar
wat would this have to do with the front though??
Old May 7, 2010 | 11:04 PM
caseyvr6's Avatar
that has to be one of the most dangerous things Ive ever heard! i would cut springs before that
Old May 7, 2010 | 11:11 PM
soto2635's Avatar
wat u mean??? hows this dangerous??
Old May 8, 2010 | 02:46 PM
caseyvr6's Avatar
its going to pull like hell and your going to destroy front end parts, most lowering springs have coils that are not used, cut as many as you need to level it out.
Mar 12, 2020 12:06 AM
jonreidhead
Jan 6, 2016 09:38 AM
maxima-junky
Oct 7, 2015 06:13 PM
Redfox
Sep 28, 2015 10:41 AM
thenewguyy
Sep 12, 2015 11:12 AM
