Going to do the TS reflash!!
I was thinking about sending it out tomorrow, but I don't know that I will have time. Just a few quick questions... Anything recommended that I should tell them to do? I was gonna tell them to do the Z33 timing map, give them my mods, and tell them I want a 7500rpm redline. Anything else I should tell them?
Secondly, how do you remove the ECU? Not 100% sure, but definitely something I don't wanna mess up!! Any recommendations on how to send it? Just wanna do this right!! Thanks!
make sure you get the z33 vtc map since you have an ssim. Also, why 7500? planning cams and ARP rod bolts or what? even with the ssim you wont be making any power that high, not to mention you would be risking your engine
I don't plan to rev that high, it's for later once the motor is built.
Edit: sorry I misread what you said.
I wouldn't go further than 7200 with stock rod bolts. Rod bolt install isn't that difficult, and they're not that expensive, and 7500 is very reasonable with them.
When you tell them the F-Spec, they will do all that automatically, so no need to really tell them all that(z map, etc).
It's self explanatory once you get on your knees and look behind the console.
So f-spec means I give them my mods and stuff as well?
Also with the rod bolts, how much of a job would that be with parts and labor somewhere? Any idea? I wouldn't do it myself, don't have the tools or the know how lol
They (TS) ask for a mod list, typically, so sure, give it to them.
I thought the reflash let's it rev to 7200? From what I have read, revving to 7500 without the motor built is asking for trouble, but I don't think shifting that high once in a while would hurt anything, would it?
Dude, read the website.
Essentially just the rev limiter. Throttle stuff too, but, that's in the noise.
Standard is 7100.
Here's info on the L-Spec
http://www.technosquareinc.com/limited.htm
Standard is 7100.
I did find it via google already. Should have looked before posting. Found some info on the differences on the 350z forums. They said that they can do injector and maf scaling for the tune. What does that mean and would that do me any good? I do have larger injectors, if that matters.
You may want to mention you have larger injectors, but it’s sorta blind on their end since they don’t have your true AFR readout. I would just ask for the F-Spec, get a wideband, and see where you are, maybe some dynotime to see if making any adjustments work.
After my F-Spec, I was @ 13.0 FLAT across, even w/ Z33 injectors.
Their ECU’s have say another layer of complexity, which adds to their versatility. Most namely in their MAF/ECU ‘language’. So, our MAF’s are different than theirs, as well as our ECU’s.
That's sorta of the nice (lazy) thing with AFC's and TS tune, TS gives you a flat AFR, so the AFC doesn't need much resolution to make it go flat somewhere else, (12.5, 13.0, 12.5, etc.) Just takes a few notches.
Here's what the F-Spec does:
CVTC Curve vs typical A33/34
My timing curve a while back.
I'll have to look, but I have a timing plot that shows the timing effects of (-) correction on the SAFCII.
TS ECU info:
Unless otherwise noted, all data is verified via Cipher/OBDII/Consult Interface
CVTC data logs mimic that of a Z33
AFR is 13.0 +/- 0.2 from 2400 - 7100RPM (Verified by an upstream WBO2 sensor prior to any catalytic converters)
Timing is + 3-4º from stock (Comparing other stock A33B/A34's vs mine)
Rev limiter is verified @ 7100 (Sometimes it bounces to 7130 etc, but you get the point)
Car has seen ~ 138 MPH on the dyno, (Verified using DJ software.
Originally Posted by MaxJay
Not to thread jack here but what kind of gains did you see with the full reflash?
One of the funnier things I've read lately, NmexMAX.
But seriously, Viper, I'm interested in where your head is at with this. I'm pretty much at the extents of my comfort zone with the current bolt-ons for this FWD sedan. So if I were do do anything more by way of added power, it would be this TS flash. (Flywheel or SSIM aren't in my sights, and I don't have HLSD to even out the HP laydown.)
But seriously, Viper, I'm interested in where your head is at with this. I'm pretty much at the extents of my comfort zone with the current bolt-ons for this FWD sedan. So if I were do do anything more by way of added power, it would be this TS flash. (Flywheel or SSIM aren't in my sights.)
Under the curve .. under the curve: under the curve: under the curve: under the curve: under the curve:
Numbers smumbers. Let's wait until Viper comes back and weighs in on why he's doing this and what his expectations are. Honestly, my interest is in what the TS flash will do for his overall driving experience. I'm looking at mods from a more holistic perspective.
"Emphasizing the importance of the whole and the interdependence of its parts."
Viper might be chasing HP bragging rights, or is focused on the dragstrip and improving his times.
Let's see.
Let's see.
The TS will definitely help add driveablility with the enhanced CVTC curve, more area under the curve, and help exploit the SSIM, etc.
Mustang Dyno's will read however you want them too.
They work off of input for your vehicle parameters (coefficient of drag, weight, etc,
I don't have LSD either but I am doing this because I want something a little faster and I would one day want to get into the 12s NA. After a tune, I would love to see 280whp, but I think that's asking too much. My 260whp was on a mustang dyno too. Ive heard it reads lower, but hell, everyone says their dyno is low reading
Pushing all that HP to a single front drive wheel without limited slip... that seems a dubious objective.
I went back and looked at your sig and noticed the Apexi Neo. See, I'm trying to weigh the value and efficiency of getting the full TS flash and not tweaking anything afterwords with a piggyback. So... I guess I'll just lurk for a while.
There's a lot of proof on here as well as on other FWD forums that never saw any difference in 1/4 mile times before and after LSD's. No matter if it's an H or V. So, unless you autox, drive in a lot of snow/ice, I wouldn't worry much if you don't have an LSD.
Also, my AFR should be proof that you don't need any tweaking if you don't have any plans for the car after the TS F-Spec. TS makes everything nice and flat at an HP friendly ratio.
The only reason I have the AFC is because I like to mess with things, see what happens when I mess with things, and of course I have a larger than normal MAF housing so I need the SAFCII IN/OUT settings modified.
Snow & Ice is best handled by snow tires, IMO. So many people here think HLSD is God's gift to the Maxima... Hello, Hotshot!
Anyway, it's comforting to read a grounded opinion.
NmexMAX, that was well written, speaks directly to my thinking, and contributes to my planning. Thank you.
Viper, g'luck with TS. Looking forward to reading more about your experience with the company and the flash.
Or unless someone is high, I suppose.
ive heard many auto drivers stating that they refuse to reflash them now.. but i'm not even close to getting a reflash but i will look more into it once i'm ready
And he has intakes, HFCs, and an axleback now. So I'm pretty thrilled I can even keep up. Those things are heavy as hell though!
Haha the only time I ever went, I was terrible lol almost bald deflated AS tires and an almost dead MAF... Ran a 14.6. It was horrible. But that was just with intake and exhaust really.
Yeah I'm excited. I will be sending it out next week probably. I gotta get the car ready for the Infiniti/Nissan event in NJ. Gotta make sure I run faster than my buddy in his modded G37. It's a drivers race at this point, but I wanna beat him even more lol
Yes sir, and sometimes beating him if I get traction. After about 120 he starts walking away. But that's far past a 1/4 mile. I would post a video but I only have a Droid to record with haha I will try to get a video sometime though but the quality is going to suck ***.
I just have a quick question, the TS flash is something I want to do but I can't let my car sit for three days....so, would it work if I bought an ECU, sent that one to TS and then just swapped them?
The last time I drove a G37S 6MT, I walked away thinking my bolt-on Maxima had pretty much the same straight line power, although executed in a far less elegant manner. That's why I'm thinking a modded G37 would be an impressive performer.
