Finally got a VIAS block plate....the verdict is...
Old Apr 26, 2010 | 01:36 PM
  #81
tedo007's Avatar
faster than you think
I installed BOP today and was not happy with result. I can feel the torque loss. Some how engine runs more smoother. I didn't feel any gain up top.
  #82
crazy97's Avatar
Originally Posted by sparks03max
I can't report on the vias specifically, but I can compare gas mileage completely stock with full boltons + tune.
Stock I was getting 16-19 city and 24-26 highway**** My normal commute with 75% highway 25% city would be 22-23mpg
Intake, spacers, vias delete, headers/ypipe, test pipe, 3" catback, UTEC tuned and I now see around 19-22 city and 26-29 on the higyway. My normal commute with 75% highway 25% city is 25-26mpg
I don't know which of those mods added/lost, but in total I've gained 3-4mpg overall.
Edited for trip computer accuracy.
Old Apr 26, 2010 | 02:03 PM
  #83
Grand_hustle17's Avatar
maybe its cause it comes with so much hype... really people it does its job but its nothing your going to feel
Old Apr 26, 2010 | 02:06 PM
  #84
Originally Posted by essential1
Sparks, does a bunch of oil drip out of the breather filter for you?
A friend of mine down here just uses a peice of hose there slightly angled up but not connected back to the intake. So i guess if it spits out any oil it will just drain back into the valve cover. It doesn't look as nifty as the filter but it might end up being a little less messy. Do you see anything wrong with this setup?
thats one the reasons i dont use em... i have seen where they get filled with oil after a while, plus the ones at advance and pepboys nver fit for me for some reason
Old Apr 26, 2010 | 02:16 PM
  #85
jeff5347's Avatar
Rochester, if you're planning on doing this mod in May, why dont you make it yourself and save the money for something else. i did just that with 1/16th inch steel, used a saws-all, bench grinder and got mine to fit. All i did was clean the mani to get it clean, used RTV and bolted on it is leak free. i think it took me all of and hour or less to do. I agree with Sparks and Grand on this too. I can feel a slight difference and def fell it left some on the table at the low end and gain or feels like it gained like sparks says in the top end. Im just glad i didn't spend 40 bucks for it.
Old Apr 26, 2010 | 02:24 PM
  #86
multiple ppl made there own, but some rather not even going through making it and the cool NWP emblem, thats all (reason i bought mines)
Old Apr 26, 2010 | 02:35 PM
  #87
essential1's Avatar
My axles cry for mercy...
It takes a couple minutes to cut it off the original one. I'm not knocking NWP in anyway, but I personally wouldnt pay for it. But that's because I currently am jobless..
Now the spacers I'd get in a heartbeat.
Old Apr 26, 2010 | 03:01 PM
  #88
Rochester's Avatar
I understand, I do. It's a valid point of view. For myself, I want Aaron's $60 over a DIY or even his $40 plate, purely because it's so freaking attractive. Shameless, I know. But worth the extra $20 for me...
...as soon as he get em back in stock.
Old Apr 26, 2010 | 04:03 PM
  #89
Scottwax's Avatar
That's Mr. Detail to you
Drive it a few days, takes time for the ECU to adjust to it, just like with any mod that affect airflow through the engine.
Old Apr 26, 2010 | 04:16 PM
  #90
tedo007's Avatar
May be you are right. I should give it a little time. I'm going next Friday to track to see if it helps any. Also order the cattman 3" cat-back. After I receive that I will be doing dyno.
Old Apr 26, 2010 | 05:27 PM
  #91
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
Originally Posted by fitness stain
what kind of RX-7 do you have?
(off topic i know, but i'm a fan and couldnt resist)
i used to own a turbo FC and loved it .. had a decent amount of work into it, before i sold it
It's a 87 (FC). It's sitting stripped in the driveway waiting for me to invest in a 5-lug swap, LSX mount kit, and a LQ4/TH350 + tons of electronics/accessories. It's going to be a long project but won't cost too much and should be stupid fast at the drag strip. Ultimate plan is to turbo the LQ4 and go with a solid rear end but that will be years down the line.
Old Apr 26, 2010 | 06:39 PM
  #92
ayo_i35's Avatar
I remember when i was wanting to do this. I definitely did not want to pay the 60 bucks for the plate so i took the stock one and cut the butterfly plate part off the back and grinded it smooth. Threaded the hole left behind in the middle and stuck a short stud into it. Very easy to make one for those who are creative and have a tight budget. Removal to see what you would be up against is extremely easy as it only takes a minute or two to take out.
Anyway, after modifying the plate i noticed a slightly better topend pull. Also the bottom end felt the same pretty much so that was good. I felt more positive feelings about it than negative, not to mention getting rid of the vacuums and that ugly black canister really cleans things up. I would definitely recommend it whether it be custom or the real deal, ugly or shiny new whatever one's tastes may be.
Old Apr 26, 2010 | 07:03 PM
  #93
i agree with both sides, i will admit i bought mines just for the NWP imprint and i was to lazy to do otherwise.... but i can see why ppl make there own... its just really simple
Old Apr 26, 2010 | 07:12 PM
  #94
2 GO B4's Avatar
ditto......I had disconnected my negative while I was doing the delete.....then started car and let idle for 5 mins or so to relearn air flow at idle.....seemed to work I guess.
Old Apr 26, 2010 | 07:21 PM
  #95
Unklejoe's Avatar
It doesn't take as long for the ECU to adjust to mods as you all think. It does it on the fly via the o2 feedback loop (while in closed loop)...
Your short term fuel trims adjust almost instantly, and the long terms will take a little longer, but the long term fuel trims wont change the way the car runs, they are just there to absorb some of the offset so the short terms don't have to change as much.
If you don't notice any difference by the time you get down to the end of your street, you wont notice one at all.
Old Apr 26, 2010 | 07:24 PM
  #96
Yep this is very true. When I do a major change that skews the AF, I can literally watch it adjust in just seconds on the wideband display for closed loop to get that 14.7.
Old Apr 26, 2010 | 07:45 PM
  #97
Unklejoe's Avatar
Same here. When I switched to an open y, it ran lean at idle for like 6 seconds then went back down.
Btw, does your wideband read around 13.9-14.2 when cruising? Mine does and I'm thinking that it's a little too rich for just cruising.
Old Apr 26, 2010 | 08:00 PM
  #98
Mine pretty consistently sits between 14.4 and 14.8 when cruising. If I go above about 10% throttle, it'll start to richen out a little.
Old Apr 26, 2010 | 08:38 PM
  #99
n3985's Avatar
大陆弟弟
For all the people who have the BOP and felt no difference, what speeds did you take it up to? I felt the car definitely pulled harder after 80MPH to ..... and can understand how driving around town or going WOT till ~60-70MPH you felt no difference.
Old Apr 28, 2010 | 08:09 PM
  #100
caseyvr6's Avatar
what a waste, car pulls harder after 4000rpm but before that its a toilet, the gains on the big end are not enough to compensate for the loss
Old Apr 28, 2010 | 08:18 PM
  #101
Unklejoe's Avatar
Maybe Nissan's next engine will have a continuously variable VIAS (I know the wording doesn't make sense)...
Instead of just two positions, it can be everywhere in between, optimized for each RPM and load.
Just thinking.
Old Apr 28, 2010 | 08:26 PM
  #102
caseyvr6's Avatar
Just thinking.
you make a good point, i have no clue how vias even works, all i know is my car made alot more low end torque before. would porting the stock manifold make a difference??
Old Apr 28, 2010 | 08:35 PM
  #103
Unklejoe's Avatar
VIAS is a system that changes the intake manifold geometry when it is activated. It is a butterfly valve that opens at a specified rpm ( I think 4300 or something).
It basically changes the effective length of the intake runners, thus "tuning" the manifold for different RPM ranges.
http://en.wikipedia.org/wiki/Variabl...ntake_manifold
And porting is always good, assuming you know what you're doing.
Old Apr 29, 2010 | 05:21 AM
  #104
essential1's Avatar
The new plastic 3.5 IM have 2 VIAS now. One is in the same location as our previous 3.5 IM and the other is on the driver side in the same area as the 2000 VI's actuator.
Old Apr 29, 2010 | 10:07 AM
  #105
Rods03Max619's Avatar
Seems pretty good for the price, think it great I might get that soon always good to have that top end power since alot of people like to be pushing between 80 to 100 plus messing around on freeway late nights!!
Old Apr 29, 2010 | 10:18 AM
  #106
You don't have to be going 80+ mph to make use of top end power... Maybe you'll get lucky and get caught before you kill yourself.
Old Apr 29, 2010 | 03:08 PM
  #107
spock's Avatar
And/or somebody else. You don't have to be going fast for top end power. It's about R.P.M's not M.P.H!
Old Apr 29, 2010 | 08:26 PM
  #108
CMax03's Avatar
See I wasn't even in here and It broke out in to a cluster F*#%! LMAO....I wonder why?????
Old Apr 30, 2010 | 02:44 PM
  #109
caseyvr6's Avatar
if your into top speed runs like a bozo this is for you other than that it sucks dont waste your money
Old Apr 30, 2010 | 03:16 PM
  #110
2 GO B4's Avatar
Well THANKYOU for insulting me and everyone else on the org that has the plate installed.....
It is not about the speed....it is about the RPM range....therefore...the benefits are realized in every gear at the top end....furthermore....once the car is in motion and AT highway speeds...horsepower is more beneficial than torque.
I swear...some of you guys make it sound like the car loses 100 lb/ft of torque with this....and turns into a Smart for Two...
We are all adults here (I hope!)....one can render their opinion without the insults.
Old Apr 30, 2010 | 03:27 PM
  #111
Rochester's Avatar
If [capitalized] you're [contraction] into top speed runs, [comma] like a bozo, [comma] this is for you. [period] Other [capitalized] than that, [comma] it sucks. [period] Don't [capitalized and contracted] waste your money. [period]
Who's the bozo?
Old Apr 30, 2010 | 03:41 PM
  #112
2 GO B4's Avatar
Who's the bozo?
Old Apr 30, 2010 | 04:28 PM
  #113
spock's Avatar
I love this site. You can learn about things to help improve the perfomance of your car and grammer all at the same time!
Old Apr 30, 2010 | 04:40 PM
  #114
brucerap's Avatar
We'll work on spelling next.
performance
grammar
Old Apr 30, 2010 | 06:47 PM
  #115
Rochester's Avatar
performance
grammar
Ouch!
Old Apr 30, 2010 | 07:05 PM
  #116
spock's Avatar
It's more my lack of typing skills than spelling. Wise ****.
Old Apr 30, 2010 | 07:40 PM
  #117
So what are you guys saying with the RPMs cause when I cruise on the freeway about 75 or 80 I'm about 3000rpms so are you just talking about what exactly? just asking you or Sparks and not being a a$$ just would like to know. And damn you never hit a 100 on a freeway?
Old May 1, 2010 | 04:38 AM
  #118
Rochester's Avatar
In this case, "top end" is in reference to engine speed, not car speed. The shift in HP, from removing your VIAS, provides small HP gains when the engine speed is over 3800 rpm (or thereabouts). So if you're doing 80 mph in 6th gear and 3000 rpm, the improved air flow does not come into play.
In the last 10 years, I can count those events on one hand. When I was a kid, nightly. I don't say that with pride.
Old May 1, 2010 | 06:44 AM
  #119
spock's Avatar
Up here, if your caught doing more than 50 Km over the limit it's considered racing and the cops take your car. I don't like that law, but it's a pretty good deterant.
Old May 1, 2010 | 07:04 AM
  #120
Yeah check out how slow the block off plate made this bozo off the line. What an idiot, doesn't he know the BOP is only good for top speed runs!?!?!?
Yeah... I learned my lesson the hard way. Needless to say, I don't ever exceed 10-15 over the limit and even then for only short periods on a highway on-ramp.
Harsh, but that's a good law. I've personally watched one of my friends get out of going 110 in a 65... He just talked his way out of it and even if he had gotten the ticket (without reckless driving) he could have gotten it dropped to an insignificant charge with a lawyer. I'd rather it be harsh like yours than a joke like it is here.
