NWP Torque Link question
For those that bought the nwp torque link, have you noticed any improvements at the track? Has it helped to reduce your et a little or perhaps your 60 ft? I'm just curious, because I'm thinking strongly of buying it. I read the other review thread, but it didn't mention anything about a track day review.
It is supposed to reduce wheel hop.
I do not like the design, as it is a solid link, and I don't want the full torque of my motor focused on that one location. If it was a shock, like the Ingalls Stiffy for the Civic SI, then maybe...
I went with the ES mount inserts instead.
It should reduce wheel HOP because the engine weight is no longer shifting as much.
Wheel SPIN is another matter entirely, having more to do with the quality of your tires and tread, driving behavior, and the materials of the road surface where you're losing traction.
That was the point of this thread, wasn't it?
The theory is that shifts are smoother because the engine/tranny is more stable, which means shifts can be faster... so, I would think that added confidence would translate as a tenth or 2 improvement. Or so goes the theory.
The theory is that shifts are smoother because the engine/tranny is more stable, which means shifts can be faster... so, I would think that added confidence would translate as a tenth or 2 improvement. Or so goes the theory.[/QUOTE]
Yes this is the point of this thread. What i asked for was any concrete evidence from the track...Such as a better 60FT time or a slight improvement in ET. The reduced wheel hop comments are nice, but i am more concerned with before and after improvement numbers if anybody has noticed any.
The theory is that shifts are smoother because the engine/tranny is more stable, which means shifts can be faster... so, I would think that added confidence would translate as a tenth or 2 improvement. Or so goes the theory.[/QUOTE]Yes this is the point of this thread. What i asked for was any concrete evidence from the track...Such as a better 60FT time or a slight improvement in ET. The reduced wheel hop comments are nice, but i am more concerned with before and after improvement numbers if anybody has noticed any.
I would think if you like what ES torque mount bushings do for your ride, then you'd like the Torque Link Connector. This rod has been on my list since he introduced it, scheduled for sometime this Summer. Unklejoe, if you don't like the mod, you could easily sell it here for 10 or 20 bucks under your cost. That's something to consider, no?
Expanding upon this thought, can anyone comments on the torque link's NVH effects?
I seem recall another thread were you were concerned with NVH transmitted from the engine to the chassis. If my memory is correct, it is very likely you will not enjoy this modification, but you seem prepared for that possibility.
You know, while all this is interesting, the OP was pretty explicit on his intent. He's going to get ticked off soon if we keep going OT. Then again, a bump is a bump.
Mar 12, 2020 12:06 AM
