Removing Grill?
Old May 7, 2010 | 07:11 AM
viperboy's Avatar
Removing Grill?
Getting my body color painted grill today (hopefully) and I was wondering how to get the grill off. Checked the FSM, doesn't show that, just removing the whole bumper. I hope I don't have to do that, I was hoping there was an easier way. Thanks guys.
Old May 7, 2010 | 11:32 AM
crystalline's Avatar
There are 3 bolts that clip into the grill. In between the radiator and the grill mount there are 3 nuts which go on those bolts to hold the grill to the car. To remove the grill just unscrew the nuts and pull the grill off. The bottom is held in by some tabs. Be aware I busted 2 of the nuts off getting my grill off, they were super ridiculously rusty thanks to New England winters.
Old May 7, 2010 | 11:50 AM
viperboy's Avatar
So you don't need to pop the tabs that you see when you open the hood? I need to get a wrench or something in between the grill and the rad to remove those bolts?
Old May 7, 2010 | 12:33 PM
jspagna's Avatar
Yes, I think they are 10mm nuts. It's kind of tight but you will be able to get to them and then like crystalline said the bottom just pops out/off.
Old Oct 25, 2012 | 05:45 PM
AceNismo's Avatar
hey, im new to this, i was reading your thread and i know it's been a while since this thread but i was wondering if you had any troubles replacing the grill? i just ordered mine today.
Old Oct 25, 2012 | 06:25 PM
ranmas2004's Avatar
Replacing the grill is probably one of the easiest things you can do. I removed mine and painted it black and replaced it without removing the bumper. Super easy.
Old Oct 26, 2012 | 05:15 AM
Prophecy99's Avatar
yeah its easier than taking a wheel off
Old Oct 26, 2012 | 02:39 PM
AceNismo's Avatar
sorry for being such a bother but can you tell me specifically where the "bolts" are located between the radiator and grill? i just tried looking for them but nothing.
Old Oct 26, 2012 | 03:27 PM
ranmas2004's Avatar
From a previous post.....
"There are 3 bolts that clip into the grill. In between the radiator and the grill mount there are 3 nuts which go on those bolts to hold the grill to the car. To remove the grill just unscrew the nuts and pull the grill off. The bottom is held in by some tabs. Be aware I busted 2 of the nuts off getting my grill off, they were super ridiculously rusty thanks to New England winters."
Just see where the thing connects give it a slight pull and see what is holding it in. Look in between the grill there you should see the bolts holding it in. The explaination above is the best description and I can't explain it any better than that other than taking a pic. Perhaps you should look again.
Old Oct 26, 2012 | 03:35 PM
DOODOOCHIP's Avatar
there should be 1 on each side, cant remember top or bottom and 1 behind the emblem. you can remove the two plastic tabs on the top that hold the bumper that will give you enough space to get you hand in there and feel around.
Old Oct 26, 2012 | 04:29 PM
AceNismo's Avatar
thank you!
Old Oct 26, 2012 | 07:30 PM
MaxinO2's Avatar
Does this procedure apply if I were to remove the hamburger emblem or can that be removed without taking the whole grill out?
Old Oct 26, 2012 | 09:08 PM
DOODOOCHIP's Avatar
the hamburger is holding on plastic tabs which need to be squeezed together than it pops out. if you can feel it than you dont need to take the whole thing out, but its easier that way.
REDinLV
Aug 15, 2024 12:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
jaydot901
Sep 29, 2015 01:18 PM
ricky7780
Sep 24, 2015 06:50 PM
