transmission oil change
Old May 8, 2010 | 09:43 AM
tothemax2003's Avatar
i wanted to know when i should change the oil in my transmission, i bought the car with 29 thousand miles and it now has 31 thousand miles.Its an automatic transmission, thank you.
Old May 8, 2010 | 10:29 AM
NmexMAX's Avatar
dot dot dot ...
Couldn't hurt.
http://www.cardomain.com/ride/335521/3
Old May 9, 2010 | 07:46 AM
TheOldDude's Avatar
I do mine every 30K miles.
Old May 9, 2010 | 10:08 AM
Love_00_Max's Avatar
It is good to be aggressive in preventive maintainence when it comes to anything that is moving and many a times the tranny is left out.
15K for drain and fill and 30K for a complete flush. Choose OEM, Castrol Import MV ATF, Toyota T-IV, Mercon V (stay away from regular Dexron/Mercon), Amsoil, RL etc.
I hope you do a flush since that will get 80-90% of the old ATF out the first time.
Old May 9, 2010 | 12:31 PM
Child_uv_KoRn's Avatar
Bad *** Newb
I used mobil 1 and got all (nearly) of the fluid out without putting any back in to rinse it.
I followed a how-to on here and it was perfect. I disconnected the cooler line at the radiator after dropping the pan and shifted through the gears a few times real slow. It blew out the stuff remaining. Just make sure you use a good amount of RTV on the gasket and check the bolts after you drive awhile. If they're not tight enough they will loosen and blow the gasket. But don't over tighten or they could strip. A new "filter" is not necessary. It doesn't filter anything except large particles and mine was completely clean at 124k miles (yes, scary mileage to change, I know). If there's anything in it you're gonna need a new tranny anyway haha.
Old May 9, 2010 | 05:11 PM
thank you guys
Old May 9, 2010 | 08:31 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
follow my sig and save some $$$$
Old May 9, 2010 | 08:34 PM
TheOldDude's Avatar
I agree with you. I flush and fill every 30K.
Old May 9, 2010 | 10:36 PM
CraigSE's Avatar
Drain and refill is all you need
Old May 10, 2010 | 06:02 AM
NmexMAX's Avatar
dot dot dot ...
FTW!
sctludwig
Sep 1, 2022 01:32 PM
kjlouis
Oct 3, 2015 05:29 AM
97_GXE
20
Sep 17, 2015 08:12 PM
pjgreek
Sep 9, 2015 09:30 PM
sdotcarter
Sep 2, 2015 09:53 PM
