Timing and High Idle
Hopefully someone knows the answer to this question. Last week, my car had a high idle due to the TB being cleaned. When I had a chance to check the timing with an OBD II, I found that the timing was retarded to 8 BTDC... Since then, I've done the pedal dance and the idle problem went away, and its idling back at around 625 ish (02 6 speed). I haven't had a chance to check it yet, but should all the relearns, resetting ecu, throttle position learning, IAVL, etc, reset the timing as well? I sorta feel like the car's running better, but haven't had a chance to check my timing. My SES light turned off now, so is it safe to assume everything's good?
CorollaULEV
30
Aug 9, 2021 08:11 PM
Finkle
Sep 27, 2015 09:53 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
