MAF or Knock Sensor Diagnostics
A million related threads on these components, but here's one direct question I can't find answers to:
Can the MAF or Knock Sensor fail incrementally, or is their functionality in total, meaning either it works or it doesn't?
Well, when my MAF failed, it didnt do the usual 3k-3.5k rev limit thing all the time. It would do it very rarely and when it did, i'd just turn the car off and back on. The car reved out like normal though. It was just dead slow at WOT. The car actually felt stronger at half throttle than it did at full throttle. I just swapped it out with a free junkyard one just for the hell of it. The difference from the butt dyno was like if I were to spray a 50 shot.
Before I swapped it out the 3k rev limit would start to happen more frequently. So I guess it CAN fail incrementally. But It can also intermittently do it's job when on its way out like Nmex said.
essential's description is of off-again, on-again failure. And I understand that experience, having had the similar behavior with failing coil packs.
But what you're describing is full-on failure, then full-on functionality. What I'm asking is, can a MAF or Knock Sensor fail partially, like where it "mostly" works, but not 100%?
Well, yes and no. Remember that I said, even when it would rev out no problem, the car was considerably slower. Like there was no torque available. With the new one it felt like a new car.
Actually, would the lack of power be considered full on failure as is the 3k rpm limit?
However, I'm not understanding how the voltmeter is getting a connection to the 4 wires for the reading. Can you explain that? (Dammit, Jim, I'm a Doctor, not an Electrician!)
http://forums.maxima.org/1557964-post3.html <-- You might want to check an FSM for proper ranges for our (03) KS.
And this post explains how to check each wire (4).
http://forums.maxima.org/3798707-post12.html
Check each wire individually ... using the battery GND.
I'm not an electrician either, it's called comprehension.
Just to follow up on this thread. I replaced my MAF last week with a new 2001 MAF, and soldered on the IAT thermistor. The new MAF works just fine, and apparently my old one worked just fine, too...
So it seems all I did was some preventative maintenance for about $100.
So that leaves me to consider (obsess over) the Knock Sensor. To that point again, has anyone ever replaced their KS in an effort to address light, low-end pinging?
So it seems all I did was some preventative maintenance for about $100.So that leaves me to consider (obsess over) the Knock Sensor. To that point again, has anyone ever replaced their KS in an effort to address light, low-end pinging?
I had to replace my knock sensor about six months ago due to a SES light (actually the KS, camshaft, and crank position sensors all failed---or were on their way out). I had moderate low end pinging (around 1.5-2K rpms) year-round and it was drastically reduced when the knock sensor was changed. Now I rarely get any pinging, unless it's really hot outside. Also, according to the in-dash mileage calculator, I'm now getting a whopping 15.7mpg as opposed to the previous 14.6mpg.
ridinwitha35 took some great pictures of his KS replacement last Fall:
http://forums.maxima.org/5th-generat...ere-we-go.html
This is beginning to look like a few years ago when 4th gen KS's were going out, and a lot of members started replacing them and saw overall improvement in MPG/performance and less pinging. History does repeat itself.
Here's the specific answer.
http://forums.maxima.org/newreply.ph...eply&p=7579659
NmexMAX, you might want to fix that post. Your link loads a reply form to Spock. However, if you paste the link text in your quote into the address bar, you get your 7-year-old entry on testing the KS.
My favorite was your old Groucho quote: "A child of five could understand this. Fetch me a child of five." I feel like I'm channeling Groucho.
Ya who cares ... I don't ... point being, you know your resistance values now and that's that.
_______________
_______________
KS can be checked with a DMM. The resistance is supposed to be between 400-620 ohms.
As for MAF, you have to check for voltage between pins 2 & 4 and ground. 2 is supposed to be 5v and 4, 12V.
Both sensors play a very substantial role in power loss.
Does a dead MAF affect fuel economy much? Mine has been dead for a while now, but I am picking up a replacement from DAVEB soon. Car feels strong until 3500rpms, and I never really go beyond that, but still need to get it replaced.
My gen 5 Maxima was knocking even though I only use Sunoco Ultra. Went to 3 mechanics with no luck. Had the car carbon cleaned as a last resort. Then the car developed a stalling problem & I read in one of the posts here to clean the MAF sensor. It didn't fix the stalling problem, but no more knock. Go figure.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
On my 4th gen, I experienced the same thing, no pore pinging.
