ball joint replacement What Brand?
I need to replace my passenger side ball joint.
Is moog better than duralast? Someone mentioned on a thread that Moog ball joints stretch the LCA's? Not sure what he meant by this.
Or should I go with a NAPA ball joint? NAPA has 3 to offer from cheap to expensive: Master Ride Chassis ($34), Altrom ($43) and NAPA($58).
I also came across Raybestos ball joints for around $43 shipped.
What do you all recommend?
i just replaced mine about a month ago, and i went with Napa brand ball joints, they are a direct fit...
Moog are good , but are more difficult to install because it " stretches " the hole the ball joint sits in.
which means you have to press them in ...i used Moog ball joints when i had my Sentra, and they were a pain to install
i just removed the snap ring holding in the old ball joint and used a big hammer to knock it out. Then i used the ball joint tool ( we have as a shop tool ) to press in the new ball joint. With the Moog ball joint i had to remove the whole control arm and use a shop press to pres them in, with the standard OEM replacement i used the ball joint tool.
I used our shops ball joint tool and the new ball joint went in , piece of cake. Then just install the snap ring and there it is.
soon2ownmax
Aug 13, 2015 02:19 PM
