How do you remove rear door panel?
look in the black plastic door pull handle on the inside and take a flat head and pry up the little rubber circle plug. Take a philips and unscrew the screw. being very gentle then pry the plastic door pull handle out of the door. Make sure to do this because you can brake the piece if you try to keep it in their while removing the door.... and they are hard to find. Then remove the plastic trim bezel from around the door handle by using a screwdriver from the INSIDE. The clips for this piece sit on the outside of the door handle so you have to work it from the inside out. It's hard to explain without pictures. Now the door should just be retained by clips and you can work around and pop the clips...If you brake some you can get some more from you local car parts store.
http://forums.maxima.org/5th-generat...-pictures.html
This is for the front door but it is the same idea.....Just take your time and don't force anything. If you cannot get your door open i don't know if this will work but it is worth a try.
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
