Replacing O2 sensor (bank 1 sensor 2)
Old May 23, 2010 | 05:52 PM
wadamax's Avatar
I have been getting SES codes P0139 and P1147. After researching the forums, I have determined that the O2 sensor that I need to replace is under the car. I replaced an O2 sensor on my wife's car and it was fairly easy, however it was the one that I could reach from the engine bay. I got under the car and located the sensor but I could not see where the wiring led to.
My questions is can the O2 sensor under the car (bank 1 sensor 2) be done at home in the garage or is this something that needs to be left to a mechanic? For anyone that has done this, was it easy, semi-difficult, extremely difficult?
Old May 25, 2010 | 07:23 AM
PCTMAX's Avatar
It can be done at home assuming you have the tools (jack, jack stands, correct sockets). The wiring is very difficult to follow up into the engine. The hardest part is reaching the clips that secure the wiring.
Its a fairly time consuming job and semi difficult, but I'm not the most experienced car guy either.
Old May 25, 2010 | 07:33 AM
reminessin's Avatar
Hate that damn code I changed all 3 of mines the one on the left topside of engine and the two under the car. 1 year later now the same code is back bank 1 no.2 sensor im like wtf Mann. O I took it to the shop lol Guy had a Hard time getting it out due to corrosion he said
Old May 25, 2010 | 07:38 AM
wadamax's Avatar
I was afraid of that!!! Looks like I may have to spend a weekend doing this
Old May 25, 2010 | 10:12 AM
2damax's Avatar
ha I am about to do this in a couple weeks. Thought it was a quick, easy job. Guess I'll have to put a little more time aside.
Old May 25, 2010 | 12:02 PM
reminessin's Avatar
The hardest part was trying to pull the sensor out "bottom one that is" he had to use a birdbeak pillars to grip and pull the sensor out but as long as you have a clear view and a lot of arm clearance you should be ok
Old May 27, 2010 | 04:47 PM
2damax's Avatar
well I have the 02 sensor socket on the sensor right now but I can't fit my breaker bar over it. I took off a heat shield but I don't see how I can do this without unbolting a pipe. Any advice would be great.
Old May 27, 2010 | 06:17 PM
2damax's Avatar
anyone? I want to get it done tonight. Hope its possible lol
Old Oct 15, 2010 | 02:32 PM
i2icharcl's Avatar
Wow, how much did that cost you for the 3 sensors? I might have to change mines too because im getting p1148/p1168, p0037/p0057, 1031/1051. Crazy stuff... hope someone can help us out
Old Oct 15, 2010 | 03:09 PM
luvlexus101's Avatar
lol at all these posts, i used a pipe wrench and a 40 dollar universal walker sensor on my last o2 sensor past the cat and its been good for about a year
Old Oct 16, 2010 | 10:49 AM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
Spray it with penetrating oil and let it sit overnight. Tap it with a screwdriver and hammer to loosen it. Then come back and apply another liberal dousing and attempt removal. Mine came off easily enough. The clip for the rear is on the top by the intake manif9ld. Passenher side: it is a blue clip. You see it run down along some thermal tape protected wires. Good luck.
Old Oct 18, 2010 | 02:39 PM
Saadkhan07's Avatar
re
I also was looking for some information on this topic, i guess i have found it !
I am hoping this isnt TOO bad, But its pricey....and just curious, does it matter what O2 you get ? Are they not all the same model ?
Old Oct 18, 2010 | 07:10 PM
Chocolate_Boi_1Der
a narrow band is a narrow band far as im concerned. Just tell autozone, napa, or whoever what you need. for the one downstream i know with my headers on i take off the passenger tire and ive got a straight shot at it to where i can put the extensions on the 02 socket and get it free. no issues.
Old Oct 18, 2010 | 08:07 PM
Max_5gen's Avatar
Can't you heat it with a torch? I did this on both of my cars (93 & 00) and they came off fairly easy. Portable torch ain't that expensive either.
Old Oct 18, 2010 | 09:25 PM
Love_00_Max's Avatar
Penentrating oil and bring the vehicle to operating temp. This will heat up the exhaust and then use the special socket and it will break loose (w/ exhaust hot, be careful not to get burnt).
I got all O2s replaced in 4 hrs (www.ngk.com), it is a breeze if you get the socket for rent from autozone!!! Good luck.
Old Oct 29, 2010 | 02:45 PM
2010MaximaSV's Avatar
Bank 2 is after the cat correct? I just got a 0139 and 1147 code today and looks like it would be the o2 sensor right?
Old Oct 29, 2010 | 03:36 PM
Also is the part number bosch 15224?
Old Nov 6, 2010 | 01:02 AM
Saadkhan07's Avatar
this CEL is something that has pissed me off more than anything ! it wont go away even after you change it !
Old Dec 1, 2010 | 06:45 PM
hvacpros's Avatar
Why do these o2 sensors go????My 01 Maxima SE has the
p0139 code come up all the time, The car only has 35,000 miles on it and it been coming up since the car ahd 15,000 miles in it. All i do is erace the code and a few months later it comes back.
The car runs the same either way, otherwise it's a great car.
Old Dec 19, 2010 | 05:34 PM
Maxima1802's Avatar
I'm probably telling you what you already know, but this doesn't fix anything.
Old Dec 20, 2010 | 07:05 AM
ColdRain's Avatar
01 maxima with only 35k miles??? wow.
Old Dec 20, 2010 | 11:01 AM
trooplewis's Avatar
Try running a car or two of Seafoam through your gas tank. Sometimes that will clean up the sensors and your problem will go away. And run Shell Premium, our sensors seem to like it better than other gasoline brands.
Yours are probably just tripping codes because of lack of use! Sounds like you need to take it for a good 20-minute run at 65mph and keep your rpms up over 3000 the whole time, blow the cobwebs out.
Old Mar 9, 2020 | 07:03 PM
Glen Burns's Avatar
02 sensor
Originally Posted by 2damax
ha I am about to do this in a couple weeks. Thought it was a quick, easy job. Guess I'll have to put a little more time aside.definitely
it takes some time definitely get the sockets from auto zone and don't be afraid to put a torch to it.i used one and they all came right out with hand tools
Old Mar 9, 2020 | 08:25 PM
slvr2KSE5's Avatar
kjlouis
Nov 24, 2018 06:09 AM
iflexsteel
Sep 15, 2015 03:37 AM
Maxboy23
Aug 21, 2015 11:02 AM
wingnut2006
Aug 15, 2015 04:16 PM
1992maximase30
Aug 5, 2015 09:27 PM
