Keyless entry problem
Old May 25, 2010 | 06:07 PM
AUTOmobilePHILE's Avatar
Okay, long story short, after I was either rewiring my fogs, or installing my mirror turn signals, when I lock my car with the keypad, it only churps, but doesn't flash the lights.
When I was rewiring my fogs to come on with the parking lights, I hooked up the wrong part of the fog wire (part going into the car, not into the relay) to the brake wire, and alot of stuff happened, including my battery went completely dead and my left headlight would not come on when I switched to parking lights. Could this have had something to do with it, or is it because when installing my mirror signals, one of the two wires coming out of the mirror signal was touching the car, melting the wire and I blew alot of fuses for the turn signals and hazards?
Any ideas, because I have know clue!!!
Old May 27, 2010 | 01:44 PM
Anyone?
Old May 28, 2010 | 01:47 PM
Noone? Please help!!
Old May 28, 2010 | 01:56 PM
ZGadson's Avatar
You likely shorted out your system - which would blow fuses before doing harm to the electrical system itself.
I'd double check all of your fuses. If you've got HIDs (or maybe even if not - I don't know) there's two larger fuses under the hood in fusebox on the left side of the engine bay - one for the left headlight, one for the right. Check those as well as everything under the dash.
Old May 28, 2010 | 01:58 PM
Thanks for the advice. I have checked the majority of the fuses, but not all of them. Plan on checking all of them eventually, just in case that is the problem. The hazards and signals fuse are good. But why check the headlights fuses when it's the signals that light up? Also, my headlights work fine.
Old May 28, 2010 | 02:10 PM
ZGadson's Avatar
As far as parking light flash with the remote goes, you may have reset the Smart Entrance module. You can turn the chirp on/off by holding the lock and unlock buttons on the remote at the same time. This also changes the parking light flash.
Old May 28, 2010 | 02:17 PM
I also tried that and it did what it was supposed to do, but no lights. I held the buttons down, horn chirped w/ no lights. Again, but no chirp and no lights. Again, chirp w/ no lights. So, Idk. Any ideas?
Old May 28, 2010 | 02:33 PM
ZGadson's Avatar
I'd say try a total reset. Unhook the battery for an hour or so and see if it helps. Our cars are known for their sporadic fixes to problems.
Old May 28, 2010 | 02:37 PM
Okay, I'll give that a try and let you know what happens. Thanks alot!
Old Jun 1, 2010 | 03:53 PM
roggeezy's Avatar
I have the same problem, did you figure out the solution?
Old Jun 1, 2010 | 05:39 PM
The resetting did not fix the problem. I unhooked it for a long time, but it still won't flash. Any other ideas?
Nope, how did it happen to you?
Old Jun 4, 2010 | 10:16 AM
Help is still needed, Idk what to do with it.
Old Jun 4, 2010 | 01:54 PM
ZGadson's Avatar
My suggestoin would be to see if you can find a used Smart Entrance Control Module on ebay or car-part.com. (This is the white box under the steering wheel with eleventy billion wires coming in and out of it.) Chances are you fried something inside it. All wires for windows, locks, lights, security, remote functions, etc run through this module so they may be controled from the remote. If your parking lights work when the headlights are on under normal driving, but don't flash when locked from the remote, I'd start with the module.
EDIT: Was curious and checked on ebay - they have a few for around $15-$30 for an 01. Should be a cheap fix if the module is your culprit.
Old Jun 4, 2010 | 02:03 PM
Thanks bro, I'll give that a look. I was thinking about running by a auto shop that might be able to give me some clarity on my problem. The module seems like a logical fix, but I have NO idea how to replace that thing, lol. But I can give that a whirl.
Now that I think about it, I did unplug 1 or 2 of the harnesses from that box, when I was trying to find the right wire to connect my mirror signals too. Maybe I pulled some of the pins out and one is the signal flash? Just a thought.
Old Jun 4, 2010 | 05:57 PM
ZGadson's Avatar
There is a pin for the signal flash. I put in a Lexus beeper for my chirp (replaces the annoying honk confirmation) and wired it to the light flash wire down there - might do a write up for this later. Never thought of that.
Installation should be simple. The whole thing has 2 bolts, and the connectors are all different, so it will be ackward to get to the bolts up under there, but should be self explanitory.
Old Jun 8, 2010 | 07:40 AM
Okay, is there some way you can explain it to me where that pin is so I can check it and see if it is disconnected?
Old Jun 8, 2010 | 08:41 AM
a33_ridah's Avatar
This method is only designed to toggle between chirp on/off while locking and unlocking. Flashing lights are not to be affected by this. as with the chirp off flashing lights are your only indication....
Old Jun 8, 2010 | 02:40 PM
ZGadson's Avatar
Correct, BUT it does change when the lights flash. With the horn chrip on, they flash once when you lock and unlock the car. With the chirp off, they flash twice when you lock the car, but do nothing when unlocking.
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Noela
Sep 26, 2015 08:22 AM
