Intake pipe questions
Old May 28, 2010 | 06:29 PM
NismoAce's Avatar
Anyone know the diameter of the maf housing as well as the throttle body inlet?
Old May 28, 2010 | 06:40 PM
Rochester's Avatar
This is weird, but I happen to have a MAF housing right here on my desk.
The inside diameter appears to be 2 and 3/4". The outside diameter seems to be 3 and 1/8". That's the TB side of the housing. The screen side is awkward to measure because of the flange.
Old May 28, 2010 | 06:42 PM
NismoAce's Avatar
lol thanks. That's funny. Any one measure the throttle body?
Old May 28, 2010 | 06:44 PM
NmexMAX's Avatar
dot dot dot ...
TB = 75mm
Need to measure those things from the rear.=, which gives a true value.
Even if all the ID's aren't the same, a 3" MAF housing still massively increases throttle response given the right software configuration.
Old May 28, 2010 | 06:45 PM
NismoAce's Avatar
Thanks pretty much the same size. most aftermarket intakes 3 or 4 inches?
Old May 28, 2010 | 06:49 PM
NmexMAX's Avatar
dot dot dot ...
2.75" ID.
It's a situation when you change the ID of the MAF housing.
Old May 28, 2010 | 06:58 PM
Rochester's Avatar
Originally Posted by NmexMAX
2.75" ID.
From what I've been reading and picking up around here, a larger inside diameter (big bore) is desirable, but requires a managed tune (piggyback).
That about right, NmexMAX?
Old May 28, 2010 | 07:13 PM
NmexMAX's Avatar
dot dot dot ...
Yes. I needed to ad + 27% on my SAFCII. I'm not going to get into this because the information is there, so to the OP, are your plans?
Old May 28, 2010 | 07:18 PM
jowo9's Avatar
What setting did you have to add 27% to? I'm planning on S/VAFC II soon enough, and just would like to know everything I can about it
Old May 28, 2010 | 07:25 PM
NmexMAX's Avatar
dot dot dot ...
It was + 27% until I changed the IN/OUT setting to the Q45 MAF, 1 IN / 17 OUT = no correction.
This thread is cool:
http://forums.maxima.org/all-motor/3...iming-mod.html
Old May 28, 2010 | 07:45 PM
NismoAce's Avatar
This is 3 inch here. Think it would be safe without a tune? and anybody ever use?
http://store.spectreperformance.com/...405/2231.0.1.1
They also allow you to build your own intake by piecing together the different bends and pipe then mark it and send it back to them for weld buff and polish.
Would make for a nice all in one unit I would say.
Old May 28, 2010 | 08:52 PM
NmexMAX's Avatar
dot dot dot ...
Anything greater than the OEM WRT to MAF housings = lean as siht.
Old May 30, 2010 | 10:21 AM
NismoAce's Avatar
If I went with the 3 inch maf housing would a vafc tuned work out well?
BkGreen97
Apr 2, 2016 05:47 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
Samedi
Sep 3, 2015 01:07 PM
