how low can you go ?
Old May 31, 2010 | 10:29 PM
knight_yyz's Avatar
Toolie
Just wondering how low we can set the timing on a 5.5 gen. Trying to pass emissions. Last time I retarded down to ten degrees, but wondering how low I can go before the car will run like crap. I know spec is 15-20 but it will only be for about five minutes.
Old Jun 1, 2010 | 10:03 AM
NmexMAX's Avatar
dot dot dot ...
IIRC factory spec is 10-20, (15 +/- 5)
Old Jun 1, 2010 | 05:13 PM
knight_yyz's Avatar
Toolie
what would happen if I went lower than 10?
And you are right manny, i remember now it is 15 +/- 5
Old Jun 1, 2010 | 05:17 PM
NmexMAX's Avatar
dot dot dot ...
I'd say it would idle like poop. But other than that if only for 5 mins it should be fine. Would this be using the emanage blue?
Old Jun 1, 2010 | 09:18 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Running lean doesn't work?
I'm curious, even though I'll never have to do emissions
Old Jun 2, 2010 | 12:11 AM
a33_ridah's Avatar
never have to run through emissions...you must not be in cali. toughest of them all
Old Jun 2, 2010 | 05:15 AM
knight_yyz's Avatar
Toolie
Lean makes emissions worse, too much NoX. Lean runs hot and running hot equals more Nox. But too much un-ignited fuel will cause a fail as well assuming it is too rich.
Well, think I am going to change the plugs to one step colder, run 94 octane, get the air filter cleaned and see if that helps.
BTY Manny, I'll be using autoenginuity. Then I have to figure how to get the ecu back to 15 so I can bump it back to 17 with autoenginuity.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
sliptap
Sep 30, 2015 05:57 AM
