projector foglights with stock brackets
Old Jun 10, 2010 | 11:28 PM
rayac88's Avatar
I have a set of 6k hids in my fogs right now with the oem knockoff foglight assembly. i want a better output cuz as of now the light only goes out instead of in front of the car basically being pointless.
i want to put the xenon projectors inside the housing if possible. im just not sure how well it will work as far as bolting up plastic and actually staying without immense amounts of glue. has anyone tried to retrofit fog lights on a maxima before?
these are the ones i have: http://www.amazon.com/2000-2001-Niss...6237462&sr=8-8
minus the actual bulb sheild
i want to use the existing black plastic and then retrofit the front part of the projector shroud on and then cuz the existing clear plastic back over so that the projector is covered.
i hope im being clear on what my mission is. ive searched and ive only seen headlight retrofits.
i did have some ebay cheapies on my previous car and it helped alot
Old Jun 10, 2010 | 11:31 PM
j23a45m9's Avatar
fog lights arnt made to see far ahead of you from the start. its a short distance in front and spread out wide to the sides.
but g/l if you wanna do the retro
Old Jun 11, 2010 | 09:07 PM
rayac88's Avatar
well now the kinda go up in the air and everywhere. they do go to the side but its very little compared to where the headlights stop. i want a wider beam that is more controlled.
Old Jun 11, 2010 | 09:22 PM
luvlexus101's Avatar
they're probably aimed too high
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
jaydot901
Sep 29, 2015 01:18 PM
