blue some at high speeds
Old Jun 18, 2010 | 05:00 PM
Grand_hustle17's Avatar
Slight history for those who don't know, my car has been out of service for about 5 or 6 months due to a blown motor and slipping trans, I just recently got it back and what I notice is that after 100mph the car starts smoking, like a very noticeable trail of blue smoke, it doesn't feel like a loss of power or nothing wrong, if you were to never look back you wouldn't know that its smoking... I'm sure its some kind of oil issue, but what can it be?? What can I do to check?
Old Jun 18, 2010 | 05:37 PM
NmexMAX's Avatar
dot dot dot ...
Compression check. That is all. Smell funny too I bet?
Old Jun 18, 2010 | 06:51 PM
CraigSE's Avatar
Because you need to go 100mph all the time...
:P
Its probably just at higher RPMs in general, not just over 100mph..
Old Jun 18, 2010 | 07:13 PM
Naw not really any funny smell, smell of oil really... it doesn't smoke at high rpms as it starts in 3rd gear really... its crazy... do you guys think that when my last motor went the catalytic convertor went too?? I do have a stock cat on it
Old Jun 18, 2010 | 07:34 PM
byrdman164's Avatar
I guess it's possible that if the last motor was blowing oil it could've built up in the cat and sat there, maybe it's burning out now with the RPM's being high for a longer period of time? Just throwing it out there...Wouldn't hurt to do a compression check and a CLT just to be sure it's not currently burning oil
Old Jun 18, 2010 | 07:37 PM
denny_1986's Avatar
there's genie in the vq...you gotta rub it the right way
Old Jun 18, 2010 | 08:21 PM
I sure nuff will... ill just swing by the mechanic tomorrow when I get off and have them change my cat as I have a high flow cat just sitting in my trunk
Old Jun 18, 2010 | 08:37 PM
hot_wax_tree's Avatar
personally is sounds like maybe you got a few bad rings
Old Jun 18, 2010 | 09:47 PM
BIG C's Avatar
blue smoke... maybe head gaskets
Old Jun 18, 2010 | 09:52 PM
j23a45m9's Avatar
head gasket and or rings
Old Jun 19, 2010 | 01:59 AM
CMax03's Avatar
Is this a used engine?
Old Jun 19, 2010 | 03:51 PM
NmexMAX's Avatar
dot dot dot ...
HG wont do it (blue), but bad rings or oil seepage through the valve seats will.
Old Jun 19, 2010 | 04:07 PM
perkman87's Avatar
what the hell is it with your luck, but blue smoke is rings or head gasket...
Old Jun 19, 2010 | 04:09 PM
NmexMAX's Avatar
dot dot dot ...
HG wont blow blue smoke.
Old Jun 19, 2010 | 04:14 PM
MoncefA33's Avatar
HG will shoot a thicker white smoke, since coolant will leak into the combustion chamber.
It's probably the residue from your last engine in your stock cat. When I installed my test pipe/cat-back, we had to weld a wideband bung in, and a tiny bit of slag leaked in there, and it shot a fair bit of smoke out at high speed/WOT. It's gone now.
Old Jun 19, 2010 | 04:36 PM
Scottwax's Avatar
That's Mr. Detail to you
Blue smoke at high rpms is usually rings if it is coming out the exhaust. Bad valve guides usually show up as a puff of blue smoke when you start the car. You could also have a small oil leak somewhere that is landing on a part of the exhaust and at 100+ appears to be coming out of the tailpipe.
Old Jun 19, 2010 | 05:00 PM
Crusher103's Avatar
Yo **** got da AIDS man......
Old Jun 19, 2010 | 05:01 PM
Crusher103's Avatar
blue is some sort of oil burn off if its coming out the exhaust, unless u blew and axle seal and its some how getting on ur exhuast in 3rd gear only
Old Jun 19, 2010 | 05:07 PM
lolomon1010's Avatar
im on the gasket/ring train... cat is unlikely - if it is cat buildup though you would notice it start to go away in maybe a hundred miles at most...
Old Jun 19, 2010 | 05:30 PM
fpromax02's Avatar
if yr askin "what to check?" start with yr oil keep a constant eye on it to see if u burn more than a vq should lol...if not then oil could b built up in yr cat...if yes then yr engine is all done....if the engine was smoked then it should smoke at high rpms..not just at high speeds.
Old Jun 19, 2010 | 05:39 PM
Deckdout2's Avatar
Play with my balls
Seafoam will clear it right up.
Old Jun 19, 2010 | 07:16 PM
The car doesn't somoke at high rpms, I will redline 1st and 2nd and nothing happens.. as soon as I'm in 3rd then I can see it in the rearview... WOT in 1st and 2nd won't do anything, I only have a code for p0031 but I'm sure I wouldn't get a code for anything doing with this problem... I will be changing the cat this Monday and possibly do a compression test to see... ill go search on how to seafoam
Old Jun 19, 2010 | 07:19 PM
Yes
Old Jun 19, 2010 | 07:22 PM
My passenger side axle is fcuked.... I bought a new driver side axle thinking it was that side that was busted, forgot that it was the passenger side
Old Jun 20, 2010 | 07:26 AM
perkman87's Avatar
Weird... SO your saying its slower.....
Old Jun 20, 2010 | 11:03 PM
Well its slower thanks to no SSIM... anyways I just got off a highway from a female move.... downshifted to second and floored it, nothing happened, downshifted again to 2nd and floored it the shift to 3rd and sure nuff at about 5K rpms it started smoking, stops immediately after I lett off the gas pedal
Old Jun 21, 2010 | 07:35 AM
njmaxseltd's Avatar
I will redline 1st and 2nd and nothing happens.... WOT in 1st and 2nd won't do anything,
I think I've found the problem...
Old Jun 21, 2010 | 08:02 AM
o.k sooooooooooooooooooo???
Old Jun 21, 2010 | 08:04 AM
according to datdude20 he said he was smelling tires i do have the nismo wheels with 9.5 at the rear with 245/45/18... it does rub, could that really be???
Old Jun 21, 2010 | 08:11 AM
dont ask me how it rubs but it could be the slightest of bumps and it rubs
Old Jun 21, 2010 | 08:58 AM
rroderiques77's Avatar
Demodded and Forgotten
It's the Flux Capacitor for sure...
Old Jun 21, 2010 | 09:08 AM
Rood's Avatar
not from rubbing..... no way.
Old Jun 21, 2010 | 09:20 AM
car squats
Old Jun 21, 2010 | 09:38 AM
The6spdMax's Avatar
Roll your fenders.
Old Jun 21, 2010 | 10:14 AM
Rood's Avatar
car squats
Originally Posted by The6spdMax
Roll your fenders.
id put money on it that its not the tires rubbing... do you see any marks?
tires need to rub a lot inorder to get that much smoke to come out.. I know from experience. .
Old Jun 21, 2010 | 10:40 AM
amixamse's Avatar
a year ago the motor blew in my WS-6, i got a used motor from a friend(dont know how long the motor had been sitting) and when i would floor it with the new motor a slight blue smoke would come out.. it went on for abt 2 months then it went away.. must be something about a motor sitting.
Old Jun 21, 2010 | 01:33 PM
Same here, a slight blue smoke... I tried taking it to the shop and the mechanic was off today to my luck... ain't that suttn not surprising
Old Jun 21, 2010 | 01:38 PM
It definately isn't the tires as I just put on the 350Z AE wheels and it does the samething... I have to probebly wait until Thursday now smh... oh 350Z wheels up for trade
Old Jun 21, 2010 | 03:09 PM
Rhyno02's Avatar
Trade for a set off g35s? :P hehe.
Old Jun 21, 2010 | 03:27 PM
I'm looking to get some $$$... I'm more interested in the stock 17's
