HELP: back door wont open
Old Jun 22, 2010 | 07:18 AM
matt06's Avatar
so my dorrs were all working fine and dandy until sunday when i decide that i am going to give my car a full cleaning. as i am finishing up i close the drivers side rear door and it wont open from the outside. So first thing i looked at was my child safety lock and changed its position and then closed it to see if it would work... STUPID MISTAKE lol. now my door wont open at all... any ideas of what it could be... how can i pull the door off if it wont open at all?
thanks guys
Old Jun 22, 2010 | 08:32 AM
mandyfig's Avatar
Ok chill a bit. It was working before and should work again. Undo what you did.
It is your child safety button. Just play around with it.
Old Jun 22, 2010 | 08:46 AM
matt06's Avatar
chill? are you serious. what did i type that made you think i was overexcited.
please read before you post... how can i undo the child safety when you need to OPEN the door to change it
Old Jun 22, 2010 | 09:00 AM
mandyfig's Avatar
Use your key fob, will it not open it?
Old Jun 22, 2010 | 09:02 AM
mandyfig's Avatar
Do you have the Service Manual? I suggest you download it. It will help you a lot.
Nelsito65's Avatar
Keyfob would probably unlock the door but will not open it for him. Mandyfig, you are not awake yet?... you might need some coffee...
OP, there is somebody around who was having a similar problem and was wanting to find a way to open the door panel with the door closed. I'd search to see if he found a solution.
Old Jun 22, 2010 | 09:08 AM
mandyfig's Avatar
Once the door is unlocked, with the child safety on, you can unlock the door from the outside, eh?
Old Jun 22, 2010 | 09:09 AM
mandyfig's Avatar
Then you can disable the child safety lock.
Old Jun 22, 2010 | 09:10 AM
Nelsito65's Avatar
He couldn't open the door from the outside, to begin with, before he enabled the child lock. Looks like the outside handle is the problem, but now that he can't open it from the inside either, things are a bit more complicated.
Old Jun 22, 2010 | 09:12 AM
matt06's Avatar
please stop posting here
thanks
Old Jun 22, 2010 | 09:13 AM
matt06's Avatar
Originally Posted by Nelsito65
He couldn't open the door from the outside, to begin with, before he enabled the child lock. Looks like the outside handle is the problem, but now things are a bit more complicated.
thank you... this is exactly it
Old Jun 22, 2010 | 09:14 AM
matt06's Avatar
thanks alot... i did a quick search but found nothing
Old Jun 22, 2010 | 09:17 AM
Nelsito65's Avatar
Using the keywords: "rear door panel", I found this one among others:
http://forums.maxima.org/5th-generat...door-help.html
EDIT:
thanks
Not too cool, man. An effort was being made to help you out.
Old Jun 22, 2010 | 09:40 AM
2000_MAXIMA_KING's Avatar
mandyfig your drunk already man put that bottle down
Old Jun 22, 2010 | 09:56 AM
Qball's Avatar
This same thing happened to me on my wifes Passat.
I had to pick the lock from the inside. Open the passenger side rear door and look how it is possible to pick the lock with something. Warning, I scatched the fender well pretty bad so I wouldn't use a coat hanger.
Once you have the door open, then you'll have to take the panel off and figure out why it wont open from the out side.
Good luck.
JRod28
Dec 29, 2023 09:56 PM
vingodine
45
May 21, 2016 12:46 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
shaunkey1
Aug 18, 2015 10:09 PM
