Got fed up of klunking noises
Old Jun 26, 2010 | 07:25 PM
ColtMax's Avatar
Got fed up of clunking noises
Well, I finally decided to throw some money at the Max.
- ES suspension bushings all around
- Moog tie rods
- Moog Ball joints
- New inner tie rods
- Tokico Illumina
- Fuel filter
- Spark plugs
- Clutch Master and Slave
- In cabin Filter
- ES shifter bushings
- Half shaft support bearings
- Brake calipers overhaul
- A bit of body work to remove some rusted area
So here are a few pics, Ill update this thread as the work progress.
I pressed out all bushings from the original lower control arms, buffed them, repainted and applied a coat of rubber guard to the exposed area.
Here are interesting comparision between OEM and Moog
Old Jun 26, 2010 | 07:34 PM
CraigSE's Avatar
My dad was fed up with the front end clunk in his 2k as well.
I replaced the sway bar to frame bushings in his car today.. Noise was completely gone. Pretty happy about it for the few $ per side.
Let us know how it fares with noises/feel, etc.
Old Jun 27, 2010 | 06:19 AM
ColtMax's Avatar
As per my inspection of the removed part this is what i found:
- One ball joint shot
- One tie rod gone
- Sway bar bushings worned out
- One shock leaking
- Roll Engine mount cracked
So I guess the work I am doing now will get the car to feel a lot better.
Old Jun 27, 2010 | 07:58 PM
ColtMax's Avatar
Control Arms ready to go!
Old Jun 27, 2010 | 09:17 PM
CraigSE's Avatar
Those look awesome!
I may do something similar if I ever get my Saturn out of the garage
Old Jun 27, 2010 | 09:41 PM
CraigSE's Avatar
BTW, looks like the same Mastercraft Maximum impact set I just got
I have 3 cans of the same lube as well. haha. You can tell you're Canadian when.
Old Jun 28, 2010 | 12:20 PM
mist max2000's Avatar
wow great work! keep the pics up.. im watching wish i could do this...
Old Jun 28, 2010 | 05:05 PM
shadyonedeath's Avatar
What was the total cost of all the suspension/steering maintenance without the Tokico's?
(control arms, bushings, tie rods, etc..)
Old Jun 28, 2010 | 07:06 PM
ColtMax's Avatar
I have not changed the control arms, they are OEM and freshly repainted.
For the cost of suspension and steering parts, it was very reasonable. I bought everything from http://www.energysuspensionparts.com except for the inner tie rod that i got from http://www.conicelli.com for 50 bucks each:
Make your list
http://www.energysuspensionparts.com...n+Maxima+2002#
Excellent service by the way! Fast, accurate and good price.
Old Jun 28, 2010 | 10:31 PM
kiyakerz's Avatar
Nice job man, makes me look forward to when I do mine. Also keep up the good work with all the pictures too, that is probably the most helpful thing for many beginners.
Old Jun 29, 2010 | 04:09 AM
ColtMax's Avatar
Yesterday: Brake clean up
Old Jun 29, 2010 | 08:42 AM
Zack342's Avatar
Very nice! would you be able to list all the suspension component part #s?
Old Jun 29, 2010 | 09:10 AM
ColtMax's Avatar
everything is there:
Old Jun 30, 2010 | 08:29 PM
CMax03's Avatar
Nice job man! Nice work station else well!!!!
Old Aug 8, 2010 | 07:40 AM
ColtMax's Avatar
Ok, long overdue update!
Shocks are installed!
Old Aug 8, 2010 | 08:03 AM
Rochester's Avatar
Good thread, OP. Great photography.
Old Aug 8, 2010 | 08:50 AM
zero2sixtyZ's Avatar
You embarrass me.
Nice overhaul. +1 for energysuspensionparts.com.
Old Aug 8, 2010 | 03:08 PM
CraigSE's Avatar
Nice stuff ColtMax... Did the struts on one car in Jan.. Maybe I'll do the Nissan this fall. I love the feel of new struts. Feels like a new car!
Old Aug 8, 2010 | 03:30 PM
OOmaxSE's Avatar
Very nice!
Did you also put ES motor mount inserts? Any tips on how to remove the old mounts without going to a shop?
Old Aug 8, 2010 | 06:36 PM
ColtMax's Avatar
Both sides are back together
Old Aug 8, 2010 | 06:42 PM
ColtMax's Avatar
Originally Posted by OOmaxSE
Very nice!
Actually I did one of them today. The only things you'll need are a metal saw, a drill and something to cut the rubber.
It is messy because of the fluid inside the mount but it is fairly easy to do.
1- you have to cut the mout at two places until you reach the last metal layer.
2- empty the mount by punching, cutting, drilling into the rubber mount.
3- prying the inner sleeve near the cutted areas.
4- remove the sleev
(Ill take better pictures tomorrow when I do the other one.
Old Aug 8, 2010 | 07:15 PM
Rochester's Avatar
Did the control arm bushings come in full for $50+, or is it one box per side? It looks like the full set.
http://www.energysuspensionparts.com...sp?prod=7.3118
Old Aug 8, 2010 | 07:21 PM
ColtMax's Avatar
This kit includes both sides LH and RH.
Old Aug 8, 2010 | 07:28 PM
OOmaxSE's Avatar
Great pics and thanks for the info. If possible, can you snap pics of a COMPLETELY gutted mount before inserting the ES?
Old Aug 8, 2010 | 07:34 PM
ColtMax's Avatar
Ill try to shoot as many pic as possible for the complete mount replacement.
Old Aug 8, 2010 | 08:18 PM
geenowalker's Avatar
Sorry for hte ignorant, non mecanic education questiuon, but....are hte bushigs hard to install (plug and play) or do they take and educated understanding. how long should they take, and if I took to my mechanic, what should I expect to pay. I have been living with the front end klunk when I go over the bumps, had shocks replaced, but still ahve the noise.
thx
Old Aug 9, 2010 | 06:03 AM
ColtMax's Avatar
Your clunking might be caused by the Sway bar link kits or the sway bar bushings.
2 hours should be enough for any good mechanic to replace those parts.
30$ each side for the link kit and 20$ for both bushings.
For the control arms bushing, I would say a good 2-3 hours per side + 50$ for the bushings.
I am only doing mechanic for fun, so I can't really tell how long would take a professional.
Old Aug 9, 2010 | 06:10 AM
Rochester's Avatar
Thanks for the confirmation, Colt!
I'm having new lower ball joints (Moog) installed in a few weeks. (And those subframe collars, too, from here on the Org.) Seems a good time to replace these control arm bushings, would you agree?
Old Aug 9, 2010 | 06:27 AM
ColtMax's Avatar
Subframe collars? I am not sure what your are reffering to. Could you explain?
I can't tell if the ES control arms bushings are a good thing yet, but I can definately confirm that while your control arm is off to replace the lower ball joint, it is a perfect timing.
Old Aug 9, 2010 | 06:36 AM
Rochester's Avatar
Do a forum-wide search on the phrase "Subframe Collars".
Basically, increase the surface area in point-of-contact for the subframe, while at the same time introducing a shock absorbent material. The net result (purportedly) is a stiffer feel to the front end, while softening the shock of small bumps. I think that sums it up. People seem to love them.
All I know is when I discussed the idea with my mechanic, he was all for it, and since I had some work coming up (ball joints), I figured it was good timing. Same with these control arm bushings.
Old Aug 9, 2010 | 09:10 AM
ColtMax's Avatar
Thank you Rochester, you just created other needs... my GF is going to be pretty happy
After reading all of those positive review about the Subframe Collars, I will definately see with carnal_c30 if I can still get some.
Old Aug 9, 2010 | 10:12 AM
Rochester's Avatar
Glad to help. And if your GF needs some counseling on how to deal with you modding your Maxima, have her give my wife a ring.
Old Aug 9, 2010 | 10:19 AM
ColtMax's Avatar
Look at the other car in my signature.... If i start to go the same route as I went with the other one... She going to go nuts!
And we are waiting for baby to show up any day. Was due yesterday
Old Aug 9, 2010 | 10:33 AM
Rochester's Avatar
And we are waiting baby to arrive. Was due yesterday
Then slip whatever you can in while she's preoccupied and loopy on sedatives... because in 6 months you're going to be shopping for a Minivan. Guaranteed.
And the funny thing is, you're actually going to like having a Minivan.
Old Aug 9, 2010 | 10:55 AM
NissanMan97's Avatar
i need to install all my ES stuff. i just wish i knew how to do the **** myself
nice thread OP
B
Old Aug 9, 2010 | 10:56 AM
ColtMax's Avatar
A good old mitsu expo with a 4g63 head on the 64's bottom end. grab all the good stuff from the mirage and there you go! a 450hp minivan!
We want a smoke show! daddy! daddy! daddy
Old Aug 9, 2010 | 06:50 PM
galheit's Avatar
Hey all , ,checkin out the site . Ive had my 00 for about 4 years now and still runnin strong at 186,000 and lovin it . started to get a thunk in forward n reverse , just as i let my foot oof the pedal . got underneth ( while it was off) AND MOVED IT WHILE IN PARK . Seemed to be the lower ball joints . Scare the %*^! out of me at first , looked on ebay and found some really cheap . Just wonderin .... should'nt they have zerk fittings in them ? Its my first post so hope some one might be able to give a lil advise .lol Im a noobie , but ive been checkin out the site for a couple years now and it will take a while to get the 15 posts. Im i9n no big rush .lol.
Thanks for any in put
Old Aug 9, 2010 | 07:25 PM
ColtMax's Avatar
Ok, so here are the requested pics for the motor mount.
I had to cheat and use the press to get the rubber out, but it can be done by hand, just takes longer.
Old Aug 9, 2010 | 08:26 PM
Rochester's Avatar
That looks like a monumental effort. Did you consider burning them out? I've read threads where people have done that successfully.
Old Aug 10, 2010 | 06:06 AM
ColtMax's Avatar
Actually the more I think about it, the more I suggest you leave the rubber in. Just use the hole alrady in the mount to get the saw through and make 2 incisions. Using the hammer and the pry bar, you should be able to get it out easily.
Once it is cut, it is simple to get it out without the press.
