Need help removing the ecm
Old Jun 27, 2010 | 12:47 PM
williamgd2's Avatar
Does anyone know how to loosen the front bracket screws on the ecm? I am having a B@tch of a time
Old Jun 27, 2010 | 01:26 PM
02nismaxlegnd94's Avatar
You can remove the ECM without taking out the bracket. If I remember right it's like two screws on each side. The screws are tight but with some torque they can be cracked it's just in a tight spot with not alot of elbow room.
Old Jun 27, 2010 | 02:09 PM
williamgd2's Avatar
Thank you I found the 4 screws but I need some kind of tool to get the 2 front 1s I will have to pick up a angle screwdriver unless someone has another way.
Old Jun 27, 2010 | 02:37 PM
It been about a year since I replaced mine, but don't the screws have a metric head on them with a phillips fitting in the middle. If that's the case use a ratcheting wrench 8-10mm to crack the screw.
Old Jun 27, 2010 | 07:29 PM
SurraTT's Avatar
HR Swap Pioneer
its 2, 8mm on each side. from drivers and passengers side.
Old Jun 29, 2010 | 07:41 AM
williamgd2's Avatar
Great Thank you Guys for your help.
Old Aug 31, 2010 | 04:23 PM
Progress's Avatar
It's business time.
Bumping this old thread. I'm having trouble removing the ECM.
I have the glovebox removed and kick panel and I removed the wire connector from the ECM but don't know how to take it off. I see screws all over the place.
Are the ones I'm looking for the brass/gold screws that lay horizontal along the front of it. Or are they the two 10 mm bolts with screw heads that bolts a bracket to the floor and lie vertical?
my03maxima
Jul 28, 2024 07:40 AM
aw11power
Oct 10, 2021 04:57 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
