seems like when it's hot performance sucks
Old Jul 4, 2010 | 10:13 PM
asma123's Avatar
so I've been having this lack of performance for a while. sometimes it works great awesome and sometimes it seems like it's restricted and it really pisses me off because I've had some close calls where i needed gas but it accelerated slowly.
I swapped my MAF already. I saw some improvement but still sucks (and my gas mileage decreased a little)
- Before swapping the MAF I was getting roughly 10.2L/100km but now it seems to be 11.3 ish. Perhaps because gas stations have changed their gas to summer? or perhaps my driving not sure. not too relevant I don't really care about this problem.
I've noticed that the longer I drive the vehicle (bring her to operating temp for a while) the performance starts to suck more. Where as when the vehicle has just been turned on to the point where it has just reached operating temp the car works great.
But as for the lack of performance, yes I do have the famous 3.5L rattle.
Should I replace the precats? if so, what should I tell my mechanic when I bring her in? and roughly how much would it cost?
could it be my precats that's been the problem all along?
Old Jul 4, 2010 | 10:24 PM
luvlexus101's Avatar
I have a similar issue, someone had blamed my knock sensor while someone else said that vq35s just slow down when hot
Old Jul 5, 2010 | 12:07 AM
Child_uv_KoRn's Avatar
Bad *** Newb
If it slows when it reaches operating temp then it's most likely knock sensor or at least some other sensor (but not maf).
I'm seeing a lot of these threads lately...
Old Jul 5, 2010 | 12:23 AM
SiathLinux's Avatar
How many miles on the car - could it be your catalytic converter?
Old Jul 5, 2010 | 11:31 AM
5 ltr. beater's Avatar
is the ECU throwing any codes at ya?
Old Jul 5, 2010 | 12:51 PM
asma123's Avatar
no codes. 63k miles.
Old Jul 5, 2010 | 12:54 PM
321VQ35MAX's Avatar
Welcome to Florida
Old Jul 5, 2010 | 01:01 PM
Rods03Max619's Avatar
With only 63k I wouldn't think the pre cats are bad maybe knock sensor but if it is the cats get some Cattman Headers instead!!
Old Jul 5, 2010 | 09:15 PM
a33_ridah's Avatar
should the 20-30 dollar ebay knock sensors do the job? like these
http://cgi.ebay.com/ebaymotors/ws/eB...m=130397695462
http://cgi.ebay.com/ebaymotors/99-00...Q5fAccessories
Old Jul 5, 2010 | 09:16 PM
Bad *** Newb
Originally Posted by a33_ridah
Do the resistor test 1st to see. I've posted it on about 5 threads, now.
Old Jul 5, 2010 | 09:20 PM
perkman87's Avatar
heat soak does diminish performance.
the solution
NWP SPACERS ..
Old Jul 5, 2010 | 09:34 PM
V2subzero's Avatar
Cold air runs better in engines try a cold air intake. Just easy but idk mite help
Old Jul 6, 2010 | 11:49 PM
BronxSleeperMax187's Avatar
^ what he said or go back to stock intake...it will help alot in the hot weather, because as you drive more like you said it gets worse as the heat builds up in the engine
Old Jul 7, 2010 | 12:11 AM
jowo9's Avatar
No. CAI is not the solution. SRIs provide better gains on our cars. NWP spacers ARE the solution! Especially if you have a 5.5 gen.
Old Jul 7, 2010 | 10:20 AM
MaximusTi's Avatar
Where do you notice the power loss? High RPM? Do you run premium?
If the car has more power initially and then losses it as you run it could well
be heat soak as others have mentioned. NWP ! ! !
Old Jul 7, 2010 | 10:29 AM
f.weezy.babii's Avatar
its hot so what do you expect lol im in dc and its 107 let your car cool down for a little ..
Old Jul 7, 2010 | 06:15 PM
e-subliminal-2's Avatar
the solution
NWP SPACERS ..
^ listen to the above. Cooler temps mix better with fuel..... Giving better performance.. However don't expect ridiculous difference, it's 100+ here.. Heat will kill power on cars, Especially our vq's from what I hear.
Old Jul 7, 2010 | 06:36 PM
sascuderi's Avatar
With temp 102 this week in jersey the old gal isn't as peppy as when it was 10 degrees out. But it's to be expected! Everything, man and machine, are moving slow in the excessive heat this week!!
Old Jul 7, 2010 | 06:50 PM
MaximusTi's Avatar
Bigtime heat here too...105+...Funny though, my car still chirps 2nd quite easily with the A/C on full and not revving it that hard at all...Could be my mods though...
Old Jul 8, 2010 | 06:40 AM
CraigSE's Avatar
No codes or no CEL?
There is a difference.
My P1800 VIAS code did not throw a CEL, but most definitely affects performance. (wonky VIAS)
Food for thought.
Old Jul 8, 2010 | 10:21 PM
Scottwax's Avatar
That's Mr. Detail to you
Hot air is less dense, therefore cars make less power in the heat.
Mahmuth
Aug 16, 2024 08:23 PM
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
Socalstillen
Sep 26, 2015 12:01 PM
