Time/Accel Graph = WTF
Old Jul 8, 2010 | 01:20 PM
ZGadson's Avatar
Help?
Just made this QUICK, CRAPPY, POS MS PAINT DOOOOOOOOODDDLLEEEEEE to give an idea of what my car is doing. I do a lot of highway driving, but a few days ago when passing a car (going roughly 80 to pass) my engine had a very hard time getting up to 80 from 70 (see chart).
I've also posted several issues in the past about HP issues when the engine is warm - could this be related to that? If not, what on earth would cause jumpy acceleration like this?
Old Jul 8, 2010 | 01:21 PM
NmexMAX's Avatar
dot dot dot ...
How did you get the values for that chart?
Old Jul 8, 2010 | 01:22 PM
ZGadson's Avatar
I just made it with MS Paint to give an idea of what it would look like on a DYNO. Nothing is to scale.
Old Jul 8, 2010 | 02:26 PM
NmexMAX's Avatar
dot dot dot ...
On a dyno and real world, you wouldn't feel those spikes. A lot of my dynos have that and it's usually too much timing.
Ahh, so is it bucking or choppy, or just takes forever? 70-80 is not a real happy place for the 4AT in 3rd, at all.
It's only happy w/ 7100 rev cut and breathing mods (IM/MAF/I/H)
Old Jul 8, 2010 | 02:38 PM
ZGadson's Avatar
Its a very rough, choppy acceleration. And, it does take forever, so yes to both of those. Is this a normal issue for our cars then, or should I be worried?
Old Jul 8, 2010 | 02:44 PM
NmexMAX's Avatar
dot dot dot ...
Choppy isn't normal. By choppy is it bucking?
Old Jul 8, 2010 | 03:04 PM
ZGadson's Avatar
I guess both words pretty much work in this case. It doesn't ever decelerate with my foot on the gas I guess, but it definitely jumps up by a mph or two at a time. I don't remember the exact conditions, but my foot was to the floor, so I know the pedal wasn't moving when the car was bucking like that.
Old Jul 8, 2010 | 03:43 PM
NmexMAX's Avatar
dot dot dot ...
Surging is probably a better term rather than bucking, since bucking seems violent. My old 4th gen used to literally buck when low on fuel and getting on it, but I don't think this is the case. Misfire, you know I could throw out the common things, but yea weird.
Old Jul 8, 2010 | 04:03 PM
SteveB123's Avatar
I still don't understand the graph values.
Did you take a horsepower dyno curve and just change the values, from rpm and power to time and speed?
Old Jul 8, 2010 | 04:42 PM
Feldman's Avatar
how about just taking a video instead of a homemade time vs velocity graph?
Old Jul 8, 2010 | 06:51 PM
Rods03Max619's Avatar
Damn that sucks how many miles is on your ride? Never felt nothing like that but when my rear cat was done for on the freeway a little Scion with exhaust will be right there with me like WTF!!
Old Jul 8, 2010 | 06:53 PM
ZGadson's Avatar
You can only feel it. Gauges say nothing by watching them.
And again, the graph is only a visual attempt to show what the car does. It is by no means accurate.
Old Jul 8, 2010 | 07:41 PM
2slow's Avatar
Random ***'d guesses:
-MAF (an intermittent signal could cause unusual driveability; also the source of all Maxima problems)
-Cats (Meow; they be clogged? any cat efficiency or secondary oxygen sensor codes?)
-Misfire (spark plug or coil pack issue under load; does the problem occur at WOT at the same engine speeds in other gears?)
-Some weird automagical transmission issue (for which I am useless; never owned one)
Old Jul 8, 2010 | 08:39 PM
ZGadson's Avatar
All sound logical - I'm almost positive my cats are clogged (lack of power when @ operating temp), and the transmission slips. No SEL for anything though. Should look into those sooner rather than later I guess.
Old Jul 9, 2010 | 03:39 AM
2slow's Avatar
More I forgot about:
-Knock sensor (could also cause power loss, but I don't think the ECU the re-advance timing quick enough to cause a surging or bucking)
-VIAS opening and closing randomly (don't know about feasibility of this failure, but sudden changes in air flow will cause surging)
Old Jul 9, 2010 | 03:50 AM
sup_mario's Avatar
Where did you get the chart man? I don't really understand that. lol
Old Jul 9, 2010 | 10:47 AM
NmexMAX's Avatar
dot dot dot ...
Jesus he said it's just a quick freakin paint representation, qualitative, not quantitative!!!111one
Old Jul 9, 2010 | 11:24 AM
ZGadson's Avatar
ITS A FUKKING MS PAINT DOODLE! lmfao!
There. My new 1st post should fix any confusion.
Old Jul 9, 2010 | 12:55 PM
jasonmax's Avatar
the vtec kicks in yo
j/k, whats that ripple? rev limiter?
slow acceleration at high rpm could be MAF.
Old Jul 9, 2010 | 01:22 PM
Chris Gregg's Avatar
Get Off My Lawn
In my experience, this could be MAF, Knock sensor, or Coils. Although the vias is an interesting idea, not the first place I'd look, but you could easily examine whether there is a vacuum hose leak with the system or use a vaccuum tool to check if the valve is opening/moving and staying in position.
My experience though with this symptom points to coil pack(s). Have you pulled and inspected? Isn't there a way to ohm them out to determine if they are going bad?
Old Jul 9, 2010 | 02:45 PM
NmexMAX's Avatar
dot dot dot ...
That speed with the 4AT is not high RPM.
And if it is surging, I'm putting $$ on coils.
Get a dyno, seriously, or codes, or find a local if you know any with an OBDII logging system.
Old Jul 10, 2010 | 07:43 PM
dan.worts's Avatar
I severely doubt knock sensor, as that would not cause "surging" power, it would cause a lack of power
Old Jul 11, 2010 | 05:04 PM
ZGadson's Avatar
... which my car has. Going to check all this out when I'm off on Tuesday.
Appreciate the input guys.
Old Jul 11, 2010 | 06:45 PM
dan.worts's Avatar
Nobody can say for sure until we know which code (if any (which would definitely be surprising)) is pulled
Old Jul 12, 2010 | 11:16 AM
ZGadson's Avatar
That's been my problem since the whole thing started a few months ago with my lack of power. The car has absolutely no codes. A friend of mine who owns the repair shop I go to even ran a diagnostic test that pulls codes from the car when it's running, but that didn't come back with any codes either.
My goal here is to at least narrow down what my problem is because I've already thrown several thousand $$ at this car to fix stupid ****. I don't want to start blindly spending money on sensors, exhaust parts (especially the cat or precats - which certainly are not cheap), etc that may or may not fix my problem.
Old Jul 12, 2010 | 11:22 AM
NmexMAX's Avatar
dot dot dot ...
Get a dyno
Old Jul 12, 2010 | 11:23 AM
dan.worts's Avatar
did your friend use the scanner that runs only check engine codes, or did he use the full car code scanner that can run ABS, etc?
Old Jul 12, 2010 | 11:30 AM
ZGadson's Avatar
Second one - he used a tool that he said pulls "running diagnostic threads" as the car is running. That found nothing.
Old Jul 12, 2010 | 09:34 PM
perkman87's Avatar
in for vid
Quickgtp
Aug 27, 2015 02:13 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
vanebecker
Aug 17, 2015 08:24 PM
yongjun
Jan 20, 2001 08:42 PM
