Advice for Removing the Rear Oil Cooler Pipe
Old Jul 9, 2010 | 08:46 AM
Rochester's Avatar
There are 2 little coolant system pipes down near the lower oil pan. (I have no pics, but if you know what I'm referring to, then you don't need them.) Back in March, I had the front one replaced because it was turning into a nasty, flaky tube of rust. It was only $22, and my mechanic replaced it in no time as preventative maintenance.
However, we were looking at the rear pipe this morning. This one is a little more complicated, and snakes up to the engine, with a banjo bolt very near the exhaust manifold. We'd like to replace this one, too. However, that top bolt looks problematic for clearance because of the manifold. Before hacking at this job, I thought it would be a good idea to first ask advice on the Org.
Can anyone weigh in with experience and advice on this part replacement process?
Old Jul 9, 2010 | 09:03 PM
rroderiques77's Avatar
Demodded and Forgotten
Let me take a picture of what I think you're referring to and get back to you early next week. Unless you can beat me to it....
Old Jul 10, 2010 | 04:38 AM
Rochester's Avatar
Thanks, Roy. Crazy, but I can't find it in the FSM.
I guess maybe I should have taken pictures while it was on the lift.
Old Jul 10, 2010 | 05:24 AM
MaximusTi's Avatar
Call Cattman, Order headers...While your manifolds are off its easy to replace
Old Jul 10, 2010 | 05:50 AM
2slow's Avatar
Are you talking about #7?
Old Jul 10, 2010 | 05:57 AM
Rochester's Avatar
Um, no. My Cattman y-pipe is pushing 3 years old, and still looks as good as the day it was installed. Good materials. Good construction. Oddly enough, my Cattman cat-back is showing its age, even though the muffler/tips are still excellent.
Off-topic anyway, Markus. I need to figure out how difficult it is to remove the rear oil cooler pipe on the 5.5 6MT. It's a little pipe, about as thick as a pencil. And painted black when new. The paint is long since gone. What remains is a leprous, rusty piece of junk. I'd like to replace it as preventative maintenance, like the front pipe, before I start dumping coolant fluid.
Old Jul 10, 2010 | 06:01 AM
Rochester's Avatar
YES! Dude, you're amazing. I couldn't find that in the FSM. Part #10 is the pipe we replaced in March, for the same rusty reasons. Do you have a NISSAN part number for that.
My mechanic wasn't sure there was clearance to back it off because of the exhaust manifold, and suggested I look for advice here before hacking at it.
Old Jul 10, 2010 | 06:08 AM
2slow's Avatar
140538J100, alternate: 140538J11A
http://nissan4u.com/parts/maxima/us_...llustration_1/
Unfortunately I don't know any specifics regarding its removal. Perhaps try to remove it, and if unable then attack the manifold.
Old Jul 10, 2010 | 06:33 AM
Rochester's Avatar
Thanks, 2slow.
I'm thinking of taking your diagram to my dealership and asking their senior tech about the removal process.
In the meantime, I simply can't be the only Northeast driver who's Oil Cooler Water Pipes are rusting away. If anyone has any experience or advice on removal of Part #7 above, please share.
And here's the diagram over at Courtesy Parts:
http://www.courtesyparts.com/maxima-...1981_1986.html
Old Jul 10, 2010 | 06:57 AM
MaximusTi's Avatar
I had to replace that pipe when I did the headers/exhaust. It was so rusted that while being removed it started leaking on the spot as it was being touched.
In all seriousness it is a straightforward replacement, you just have to drain the coolant and refill when its done.
Old Jul 14, 2010 | 10:25 AM
Rochester's Avatar
Bump on this.
Anyone remove the upper oil cooler water pipe without messing with the exhaust manifold? Is there clearance?
Old Jul 24, 2010 | 02:09 PM
Rochester's Avatar
10 days later... bump bitty bump.
Does anyone know if you can remove the upper oil cooler water pipe without messing with the OEM exhaust manifold for clearance?
Old Jul 24, 2010 | 05:11 PM
5 ltr. beater's Avatar
what's an "upper oil cooler water pipe"? did a quick .org search and didnt find anything?
Old Jul 24, 2010 | 05:45 PM
SoonerFan's Avatar
Cletus
my car had 50K miles in MD/VA and still looked brand new
in that diagram it looks like it connects between the exhaust manifold and the intake manifold...hard to tell though...if its there, it shouldnt be too hard to do
Old Jul 24, 2010 | 05:51 PM
SteveB123's Avatar
Rear oil gallery (behind rear exhaust manifold) and oil cooler.
Old Jul 24, 2010 | 05:52 PM
SteveB123's Avatar
Post 7.
Old Jul 24, 2010 | 06:28 PM
P. Samson's Avatar
Having once removed the rear block coolant drain plug on my '00 which was an absolute ***** because of the difficult access (the frame/engine support/exhaust etc), this pipe on the VQ35 may be difficult for the same reason. The exhaust manifold was not the problem......it was just getting the socket on it, although with the banjo fitting arrangement it will at least be protruding further from the block. I ended up with about a two foot 1/2" drive extension and flex adaptor on the socket.
Old Jul 24, 2010 | 07:26 PM
Rochester's Avatar
Thanks for this reply, Samson. So if I'm reading this right, as long as you have the right tools, clearance isn't the issue... just access. Right?
Old Jul 24, 2010 | 08:06 PM
CMax03's Avatar
You should be able to remove it with a GEAR WRENCH, just make sure you replace the crush washers (2ea) at the banjo fitting....Seems to be more than enough room once you remove the air blast shields on the passenger side....
Old Jul 25, 2010 | 05:28 AM
Rochester's Avatar
Thanks for the advice, guys. I appreciate the helpful input.
Old Sep 2, 2010 | 05:36 AM
Rochester's Avatar
Some follow-up closure on this, in case anyone searches into it...
Turns out there was enough clearance to back off the bolt and remove the pipe without having to mess around for clearance.
Extremely tight design. But the new water pipe is on and it's all good.
Old Nov 13, 2010 | 08:17 PM
PaulfromOlney's Avatar
Do all fifth gens have them? I've never noticed it.
Thanks!
Old Nov 14, 2010 | 05:17 AM
Rochester's Avatar
Thanks!
Yes.
Old Oct 13, 2019 | 07:03 PM
Nuffstylez's Avatar
Rochester, I hope you're still here on the forums, I tried all day to get something on that bolt to loosen it. Please give me some advice on how you got that bolt removed.
Old Oct 14, 2019 | 05:07 AM
Rochester's Avatar
It was 10 years ago, and my old mechanic did all that work. Sorry.
JRod28
Dec 29, 2023 09:56 PM
Huttig2009
Sep 25, 2015 03:31 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
