left side fron wheel(driver side )slips even when taking a turn at 10mph
Old Jul 12, 2010 | 02:52 PM
imported_D_Roc's Avatar
it burn out when gears shift sometimes and all the time when i take a left turn even at low speeds also wehen i turn left theres a squeaking sound but its been there for about an year now what could be wrong i know its not normal for just one whell to spin faster all the time
Old Jul 12, 2010 | 02:55 PM
SoonerFan's Avatar
Cletus
get new tires
Old Jul 12, 2010 | 02:58 PM
ZGadson's Avatar
ABS or speed sensor is going bad.
Old Jul 12, 2010 | 03:59 PM
Chris Gregg's Avatar
Get Off My Lawn
IMHO: I'd put my money on a bad ball joint. Tire is moving in ways it shouldn't which results in squeel you describe and lose of traction as well as what I imply from your post that the car feels like it is shifting.....which really it is.
Jack the car up and see if the wheel moves in/out at the bottom. Also see if there is escessive play left/right (tie rod) to check that. OR take to a good shop to diagnose.
Old Jul 12, 2010 | 06:53 PM
ball joinds are new, so are the abs sensors but i sprayed some MAF cleaner on that sensor but i doubt it can do any thing, could it be the CV joints
Old Jul 12, 2010 | 08:40 PM
Get Off My Lawn
Maybe I'm off base, just seems like something's moving. I know on older Gen Max's (ie 3rd gens) the upper strut bearing/assembly would wear and tear allowing upper strut movement. Again, what about tie rod ends?
CV joints are part of the axle and simply allow the axle to move with the constant variations in wheel turning (left/right) and suspension travel (up/down).
Old Aug 15, 2010 | 08:05 AM
Get Off My Lawn
Any update? ABS sensor still seems like a possibility.
HOKUSMAX
Nov 13, 2017 04:34 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
rtirbany
Sep 8, 2015 11:46 AM
BassAddictJ
Aug 4, 2015 11:38 AM
