Clutch Problem 01 Max
Old Jul 12, 2010 | 10:15 PM
robrie's Avatar
Was driving and all of a sudden the pedal got soft. Did research on here and started by changing the slave cylinder hose, bled the lines and still soft pedal until the mid-point. Theres also squeeking from the slave cylinder.
Could this be a bad slave or master cylinder or something else I'm missing?
Thanks in advance
Old Jul 24, 2010 | 04:49 PM
burtond06's Avatar
Thanks in advance
I had a similar problem in mine and took it to the shop. They replaced the entire assembly...
Old Jul 24, 2010 | 05:07 PM
5 ltr. beater's Avatar
pressure plate is on its way out. i have the same problem. im getting ready to fork out money for a whole new clutch.
..and im getting that "squeaking" sound too when i push the clutch in as well. cant complain though. its the original clutch from 2000 and my car has just hit 140k.
Old Jul 25, 2010 | 09:20 AM
maximadave's Avatar
detailerdaveb@gmail.com
140K on my 2K2 as well. at idle, I hear the squeaking noise and when I push the clutch in, the squeak goes away. It's been doing this for the last few years. I also have the original clutch and pressure plate.
Old Aug 19, 2010 | 10:01 AM
Berto210's Avatar
could that be a reason why i my clutch fluid is going fast??
Old Aug 19, 2010 | 10:54 AM
no. that means you're leaking somewhere.
my clutch fluid is perfectly level. oh and i just got a new clutch installed last week. the car accelerates alot better than it did. guess i was slipping that bad.
MAXSE5SPD
Sep 17, 2022 04:00 AM
HOKUSMAX
Nov 13, 2017 04:34 AM
intimidator
Sep 5, 2015 07:23 PM
Hailstatejig
Sep 2, 2015 06:52 AM
sc10692
Aug 9, 2015 09:37 AM
