How do you rev a drive by wire from engine compartment???
Old Jul 12, 2010 | 11:36 PM
zhuleek's Avatar
This has been bothering me since I bought my 03max, is there ANY way to rev the car while in neutral from under the hood?
Old Jul 13, 2010 | 04:43 AM
nismopc's Avatar
No...
Old Jul 13, 2010 | 05:16 AM
Amave's Avatar
a helper? its virtually impossible to do by yourself
Old Jul 13, 2010 | 10:14 AM
Froggmann's Avatar
You don't. You will need an assistant.
Old Jul 13, 2010 | 10:44 AM
SoonerFan's Avatar
Cletus
cant be done
Old Jul 13, 2010 | 11:11 AM
NmexMAX's Avatar
dot dot dot ...
Somehow get all 4 sensors (TPS # 1 & 2, and APPS #1 & #2) at a very linear voltage to ~ 4.2volts, while keeping a global tolerance of about 0.1v to each sensor.
Old Jul 13, 2010 | 11:27 AM
SoonerFan's Avatar
Cletus
this
Old Jul 13, 2010 | 12:17 PM
Rydicule's Avatar
Don't you know who I am?
C.
Old Jul 13, 2010 | 12:51 PM
OOmaxSE's Avatar
This guy is a beast.
Old Jul 13, 2010 | 12:53 PM
bigleman's Avatar
Advocatus Diaboli
Tie a string to the gas pedal and fish it through the firewall.
Old Jul 13, 2010 | 01:12 PM
luvlexus101's Avatar
LOL!!
Old Jul 13, 2010 | 01:16 PM
Leo_Koneval's Avatar
Umm... the only serious answer I can give you is that on some Altimas I have seen there is a little black screw that is covered by a little black grommet thing where the TB is, and the grommet is like the cover that goes over the positive of the alternator bolt.
But some kid said he can rev a drive by wire, and pulled that grommet off and he revved the engine with a screw driver into that little black screw. But after he was done the car ran extremely rough, almost as if the timing got messed up somehow, there was a little popping at the exhaust a lot of engine shaking, and so he unhooked the battery and waited a few hours and then everything was good. And all this was on a 2005 Altima by the way.
Old Jul 13, 2010 | 01:20 PM
SoonerFan's Avatar
Cletus
thats a lot of work...and a bad idea
Old Jul 13, 2010 | 02:13 PM
NmexMAX's Avatar
dot dot dot ...
Leave in gear and don't use set e-brake & lean over the radiator
Old Jul 13, 2010 | 02:23 PM
Grand_hustle17's Avatar
LMAO!!! why is he so pressed to do this???
Old Jul 13, 2010 | 02:32 PM
SoonerFan's Avatar
Cletus
$10 says its so when he goes to ricer meets and stands around with his hood open, he can give it some throttle to show off the mAd tYtE sOuNd
Old Jul 13, 2010 | 02:37 PM
jowo9's Avatar
Tie a string to your gas pedal, drill a hole through your firewall, and run the string into the engine compartment. When you wanna rev it and show people, just don't let them see the string
EDIT::: Oh, wow, someone already suggested this! Ahahahaha yes!
Old Jul 13, 2010 | 06:44 PM
2 GO B4's Avatar
put a big bozo foot on a radio-controled mechanical actuator in front of the pedal to simulate your foot and rev away......vroom vroom....
Old Jul 13, 2010 | 07:11 PM
Mr. Brett's Avatar
Buy a Toyota.
Old Jul 13, 2010 | 07:13 PM
2 GO B4's Avatar
Originally Posted by SLCPunk267
Buy a Toyota.
HAAHAAHAAAAAAAAA!
Old Jul 13, 2010 | 09:15 PM
5 ltr. beater's Avatar
i think the toyota's are drive by wire too, no?
Old Jul 13, 2010 | 09:21 PM
Unklejoe's Avatar
I'll protect you from the fire.
You know how Toyota's had that random acceleration problem...
Old Jul 14, 2010 | 06:20 AM
NmexMAX's Avatar
dot dot dot ...
Pretty much every car made right now is, so ...
Old Jul 14, 2010 | 06:41 AM
rroderiques77's Avatar
Demodded and Forgotten
Buy a Toyota.
Or any other older Maxima.
Old Jul 14, 2010 | 06:51 AM
NmexMAX's Avatar
dot dot dot ...
That wasn't the point ..
Old Jul 14, 2010 | 09:00 AM
unrealii's Avatar
Kinda funny, I've always wondered this too.
Being able to rev the engine while under the hood makes it easier to diagnose noises, etc.
Old Jul 14, 2010 | 10:19 PM
zhuleek's Avatar
Hum, ok... Or may be it's because my engine made a distinct sound at 3500-4500 rpm, and I needed to know if its the engine or something just got loose. And if I told you that I found a way to do that, wouldn't you want to know how? I thought this was why the forum is here, to ask questions. And if you dont know the answer then dont reply. People just leaving stupid comments to get their post count up? Thats retarded... There should be a restriction 'read only rights for members with an IQ of a peanut'
Old Jul 14, 2010 | 10:25 PM
zhuleek's Avatar
Ok, I'm sorry... This is the stupidest I've heard. Once again, please refer to the post above for mentally challenged
Old Jul 14, 2010 | 10:29 PM
zhuleek's Avatar
Toyota's official comment on that was that its not caused by Drive By Wire and even if it was it could still happen with old school throttle control.
Old Jul 14, 2010 | 11:09 PM
zhuleek's Avatar
Oh, and BTW, there is only one APPS in a maxima. Though I heard John Deere uses two, one for throttle and the other for steer by wire's precision steering
Old Jul 15, 2010 | 06:38 AM
NmexMAX's Avatar
dot dot dot ...
And by the way, your question has been answered tenfold, you can't do it without help.
Old Jul 15, 2010 | 07:10 AM
Mr. Brett's Avatar
I was gonna say.
Don't mess with Nmex. He knows what he's talking about.
OP, the .org is a baptism by fire kind of forum. If you can't take the heat, stay out of the kitchen. Sure it may be frustrating, but it happens. Be persistent and you'll get your answer. And you did, although it may not seem like it. Picking fights with OGs is just going to get you in trouble.
Old Jul 15, 2010 | 07:56 AM
InfiniwhiptinitiII's Avatar
pwned^
Old Jul 15, 2010 | 07:57 AM
lol lol lol
Old Jul 15, 2010 | 08:08 AM
NmexMAX's Avatar
dot dot dot ...
The reason there are 2 of each sensor is so there is reference point since the ECU makes sure they're in check. If there is a small voltage spike, the tolerance goes away, and BAM, fail safe mode.
I learned this the hard way when I was wiring my wideband to read throttle position, kept going into fail safe...
Old Jul 15, 2010 | 09:10 AM
SoonerFan's Avatar
Cletus
i see someone got their feelings hurt
Old Jul 15, 2010 | 09:22 AM
1997MAXZ's Avatar
too funny!!!
Old Jul 15, 2010 | 09:24 AM
NmexMAX's Avatar
dot dot dot ...
Although I was off when I gave a tolerance of 0.1V .. just trying to give some advice.
Old Jul 15, 2010 | 09:53 AM
Deckdout2's Avatar
Play with my balls
+1 x 2
Old Jul 15, 2010 | 10:25 AM
zhuleek's Avatar
Not picking fights.... More like fighting fire with fire...
It was a legitimate question and it seems like drive by wire should have accommodated the need of people like me that need to diagnose a sound and people like ^*^*^ that want to show off that tight sound.
this is much better then this
