VQ Swap 5.5 gen to 6th gen
OK, so the time is ticking, the 03 TE SE has been immobilized due to loose piston for 4 days now, and it seems like King Bear's Harjit will get the bid for the labor. Engine is still being located, but I decided to put 6th gen in the bay. Why? For those who don't know the 6th gen is almost identical to 5.5 but is 1) tuned to produce ten more horsies 2) there are no 02-03 engines out there with under 100k, and as far as the price, the 6th gen motor is actually cheaper. Only thing I still need to know, besides the intake manifold and knock sensor/crank position sensor anything else needs to be swapped. I'm still not clear on the oil pan issue, would that be the same going from auto to auto? BTW, the intake mani on the 6th gen has an EGR, exhaust gas recirculation <-- some new emission bill passed for all vehicles 04 and up. It doesn't decrease performance, it basically uses some of the exhaust gas for the intake so less exhaust comes out therefore keeping our planet GREENER...
Anyway, any ideas if I could just remove the EGR valve from the 6th gen mani instead of swapping? Also, I would think that its a good idea to replace all gaskets that will be coming off during the install. Anyone knows exactly what gaskets I would need? And another question, will the headers be plug and play or would I need aftermarkets? Anyone knows where to go for reliable engines?
www.car-part.com is where I'd go. A lot of stuff there so shop around.
Oh yeah ...
http://forums.maxima.org/5th-generat...o-5-5-gen.html
First link was broken, I fixed it. I quoted everything that has the answers he needs.
http://nycmaximas.org/showthread.php?t=53928
Glad you found someone to do the swap for you. I forgot to mention in your other thread that there is someone in the NYC area selling 2004+ Vq35's for 660 + tax. Not sure if you found one already, but just in case your still looking here is his thread:
I'm trying to find out exactly which gaskets, that is why I said "I would think that its a good idea to replace all gaskets that will be coming off during the install. Anyone knows exactly what gaskets I would need?" I want to have the gaskets on hand when I come in for the swap.
You can just purchase a complete HG set also and it should come with all gaskets from the heads on up. Just use silicone to reseal the timing cover if your gonna take the heads off too.
So the extra 10 horses come from a34 ECU? Anyone knows?
My Altima (2002) was rated the lowest of all the 3.5's at 240, but was always known in the Altima community as the fastest Altima made.
Any idea if I could reuse 6th gen engine mounts as well as the headers
(i know 6th gen has dual exhaust)? Any way to clean the original headers? I'm gonna start moving my car to the shop tomorrow and I dont really (actually, I really dont) have the money for the headers and the mounts. This way when I call the salvage yard tomorrow I can try to work out a deal for the engine to include them. And would that be a good idea to reuse?
Finally had Harjit do the swap. Few issues:
1) AC is NOT working. The air is coming out but not even remotely chilled. The AC compressor seems to make the on/off sound and from inside the car I hear something that sounds like a faint whining when AC compressor is on. As soon as I switch to fan the whining dies down. (I have .66 pounds out of 1.2 pounds of freon and the system was vacuumed)
2) There is a whining sound coming from timing side of the engine, it sounds like an old american-built (fords in particular) with a bad power steering pump. It gets louder at higher RPM but turning the steering wheel has no effect on the sound-only engine speed. Same in drive as in neutral.
3) The engine fan seems to be working overtime. It doesn't turn on immediately when the vehicle is started, otherwise I would lean towards the lack of a thermostat, but it doesn't shut off after the initial engine warm-up. Just keeps working, and working faster(louder) then usual. It also smells like antifreeze around the engine compartment.
Is it possible all those are related? Anyone with feedback is welcome.
PS HAHAHA <- this is me laughing in advance at all silly remarks, such as 'roll down your windows, you don't need AC or make the music louder and you wont hear the whining' etc... I'm serious, need to get this car in shape for durability. It sux spending 12-13 hun to find out I need to replace the whole car.
Oh, and the engine feels much stronger at higher rpm the the old one...
2: check your new engine's belt tensioner pulley, perhaps the bearing is on its way out.
3: my fans were also so active at my initial startup that I couldn't get the engine to come up to temp at idle, I had to sit in the car and hold the rpm up a while so I could top off my radiator. That antifreeze smell could simply be residual burning off from the work performed- there will always be oil and coolant on various surfaces after a job like you're talking about that needs to burn off as the engine gets up to temp.
And I'd be surprised if you get any "roll the windows down" remarks, the entire country's pushing triple digits, I know down here it almost hurts to breathe. Let someone else turn their radio up to drown out engine noises and see what their VQ's do to them
