Clunk in passenger front wheel.
Alright so I can't figure out what this problem could be. My front passenger wheel makes a clunk when I hit a hard bump. I'm on nex coilovers also. I've already double checked all bolts and made sure everything is tight including the coilover. About a month ago I also replaced the lower control arm with the ball joint and also the tie rod ends. I thought it was the coilover but I replaced it with the other side and the noise was still in the same wheel. Thanks in advance.
or get a friend to check it. put the ebrake up and give it gas in d and R. if there is significant movement thats your culprit.
Sometimes things look okay, but are broken. I just had a wheel bearing go and it looked fine and there was no play, replaced it and problem stopped.....
