02 maxima:If you shift a 4speed auto, would the tranny break?
Old Jul 15, 2010 | 04:34 PM
killer00's Avatar
I was wondering, I have a 4 speed auto, If you are driving about 40mph and drop it to D2, would it screw up the transmission?
Old Jul 15, 2010 | 04:36 PM
2slow's Avatar
Totally.
Shouldn't hurt much...a little clutch action.
Old Jul 15, 2010 | 04:43 PM
SoonerFan's Avatar
Cletus
try it and find out
if you want to shift gears, get a car with a cluth
Old Jul 15, 2010 | 04:49 PM
denny_1986's Avatar
its not meant for it
driving with the OD off is way safer
Old Jul 15, 2010 | 05:56 PM
Froggmann's Avatar
If you rev match not so much, If you just dump it yea you may take some life out of it.
Edit: 40 is fine I forgot how tall 2nd is. You're good all the way up to 60.
Old Jul 15, 2010 | 06:03 PM
02max245's Avatar
Try doing in under 35mph what way ur revs match and you dont fell the trans catching hard. If u dump it into 1 at 40mph ur so ****ed so watch out!
Old Jul 15, 2010 | 06:35 PM
5 ltr. beater's Avatar
u guys are crazy! out of the 5 max's i've owned, 2 were auto's (a 94 SE and a 96 SE) and i used to manual shift the heck out of the RE4F02A all the time for over 70k + miles. never had a problem.
granted i used to maintain the tranny (external tranny cooler,frequent tranny flushes) , but nonetheless. i don't think the newer automatics are weaker than it's predecessor.
heck, Aaron92SE is the guy who suggested manual shifting my auto way back when.
Old Jul 15, 2010 | 09:01 PM
Z-Powered's Avatar
Doesn't 2nd go up to 80?
Old Jul 15, 2010 | 09:38 PM
Andypot1985's Avatar
well my max is an manual, but my work car (chevy hhr) is an automatic. Going down big hills i pull it down into lower gears to help it slow down and i have never had a problem with the trans. I mean the option is there on the shifter for a reason, i just wouldn't abuse it. The computer is programmed to give you the most power/torque with the position of the throttle.
Old Jul 15, 2010 | 10:06 PM
tookrzy4u192's Avatar
you shouldnt have a problem unless you do it a lot.. and i mean a lot
Old Jul 15, 2010 | 11:43 PM
Gemner's Avatar
...you can shift into 1st at 100mph if you want and it wont be a problem. The TCM refuses to shift into conditions that it doesnt agree with. this is also the reason that if you extend your rev limiter the TCM will have you shift at the same RPM as before. the computer knows whats up and wont let you overrev.
Old Jul 16, 2010 | 04:28 AM
Grand_hustle17's Avatar
Yet another pointless thread imo......... anyways if u do it daily then yes (clearly the car is an auto for a reason) I manual shift everytime I go down the track....................
Old Jul 16, 2010 | 07:14 AM
Scottwax's Avatar
That's Mr. Detail to you
Nissan gave us a gated shifter, so that tends to mean they understand that someone who buys a 222-255 hp sedan is probably someone who would at times like control over exactly when the transmission shifts-like holding it in a certain gear around a curve. The only real problem you can have with manually shifting an automatic is if you regularly downshift into 1st gear without simultaneously given it some gas, it can be hard on the clutch packs if you simply downshift into 1st gear, especially from higher speeds.
Old Jul 16, 2010 | 07:18 AM
NmexMAX's Avatar
dot dot dot ...
This is from my 4th gen, but they actually have similar gearing, actually nearly identical.
Top of 2nd w/ raised rev limit
Old Jul 16, 2010 | 07:32 AM
jeff5347's Avatar
i manually shift my auto 80% of the time. i regret not getting a manual. when i downshift i rev the engine a bit like you would in a manual to rev match and it does help from getting that trans thud from downshifting. it def feels better getting on the hiway in second and shifting into 3rd at 60 and so on. if i dont the car shifts to quick and feels sluggish. one thing i dont like but in an auto you cant fix without a shift kit is say you shift to 3rd and your in the gas hard the tranny will shift when it wants not always when you tell it to
Old Jul 16, 2010 | 10:46 AM
Froggmann's Avatar
Probably, but in talking about downshifting I wouldn't from over 60 MPH.
Old Jul 16, 2010 | 11:13 AM
jasonmax's Avatar
itll be fine.
Old Jul 16, 2010 | 12:09 PM
NmexMAX's Avatar
dot dot dot ...
It's obvious from my post that is incorrect.
Old Jul 16, 2010 | 12:51 PM
Old Jul 16, 2010 | 04:54 PM
ZGadson's Avatar
Are you really willing to play Risk with your transmission? They are some finicky creatures.
Old Jul 17, 2010 | 01:07 PM
NmexMAX's Avatar
dot dot dot ...
It wont do it, shat, I try it at 70 and no thank it says, I'll wait until I get to a reasonable/safe speed. It's in the owners manual.
Old Jul 30, 2010 | 08:57 PM
michaelm815's Avatar
it shouldnt do too much if any damage
Old Jul 30, 2010 | 10:51 PM
mendezrj03max's Avatar
All i can say is that i shifted the heck out of my auto trying to show off and be cool. Till one day i got the gears stuck. It wouldn't drive past 40 mph and it took a while to even get to 40! I couldn't even reverse. So sad, but live and learn. It was a nice $1500 bucks spent on a new tranny. Could have used that cash for something else on the max.
Old Jul 31, 2010 | 11:40 AM
SoonerFan's Avatar
Cletus
Old Jul 31, 2010 | 01:15 PM
Maxy91's Avatar
wouldnt recommend it, your car is either auto or m/t theres no in between paddle & gate shifting is just nonsense
Old Jul 31, 2010 | 05:27 PM
brisk's Avatar
Absolutely don't do it
Old Jul 31, 2010 | 09:22 PM
sixteenXnine's Avatar
I have two auto '00s (91k and 110k) and I manual shift when it makes sense. It's pretty easy to tell when it's ok to vs when it's not. Most often, I downshift into second out of non-OD [D] when coming down a steep hill, at about 45-35mph. It does so in a smooth fashion in both cars, and helps to not stress the brakes too much. I also manual shift on highway off and on ramps when it makes sense. ... so from my standpoint it's ok.
Old Aug 1, 2010 | 01:47 AM
03VIPMAX's Avatar
i down shift all the time either to help slow car down or to pass someone and my car runs like a champ! ask a33_ridah we raced the other day his car has less then 100k miles and mine has 160K and i spanked him by atleast 2 cars!
fx4five
Oct 18, 2015 06:57 PM
BobTX10
Oct 7, 2015 08:43 AM
hayne
Oct 5, 2015 11:53 AM
fx4five
Oct 1, 2015 04:58 AM
