Is this True?
Old Dec 13, 2001 | 12:44 PM
bcannon's Avatar
Is this True?
"The U.S. Tire and Rim Association specifies that the minimum acceptable rim width for tire sizes 235/45R17 and 245/45R17 is 7.5". As a result, no tire manufacturer in the world will approve the use of 7.0" wide rims for those tire sizes. In every case WITHOUT EXCEPTION, manufacturer specifications that indicate otherwise are either in error or a misprint. Don't believe me? Call the manufacturers yourself. But if you want to save some time, don't bother. I already have.
You would be well advised to disregard statements to the contrary from a retail outlet or ANY MEMBER OF THIS FORUM. Keep in mind that just because a tire appears to fit properly on a rim, that doesn't mean it's safe."
Old Dec 13, 2001 | 12:50 PM
Jeff92se's Avatar
I'm needing a caw
Please for the love of everything you hold holy in this world, NO MORE!! hehe.
It's quote right? Where did you get it and it's up to you to believe the source that provided it.
Anyway, why chance it for a whooping 10mm of tread? You guys want to run 45 series tires that bad??
Old Dec 13, 2001 | 12:55 PM
adman's Avatar
I'd just go with 245/40/18 series instead...
ADMAN
Old Dec 13, 2001 | 01:01 PM
bcannon's Avatar
sorry, this is kind of confusing to me...I got it from a post from searching the previous threads...
Old Dec 13, 2001 | 01:21 PM
Blackgums100's Avatar
As Ja Rule said
"If you ain't rolling with 22's you ain't ****!!!!"
Old Dec 13, 2001 | 02:35 PM
2001SE's Avatar
A lot of people put 235/45/17 and they had absoulutley no problems since the day they put it on.
Mr. Burner will tell you...he has 235/45/17 of the Bridgestone RE950's
Old Dec 13, 2001 | 02:38 PM
Jeff92se's Avatar
I'm needing a caw
That's not quite the reasoning we would look to for a good recommendation.
I mean I could run only 4 lugs on my wheels and have no problems either.
Hey if you know the risk then it's your decesion I guess.
Old Dec 13, 2001 | 03:34 PM
Coldboot-SE's Avatar
Hey All,
No manufacturer is going to accept the liability on an established margin, I have no doubt that 7.5" wheel for a 235/45/17 tire is a conservative margin, as products manufactured to overengineered tolerances and a conservative limit within them is set.
I as others on this board can't reccommend a size of tire outside the manufacturer's limit. BUT like myself have chosen on my own accord to put a set of 235/45/17 (Dunlop SP 5000) on my SE rims, as I'm not an real aggressive driver I feel the assigned risk is far easier to bear than riding on those OEM POS Potenzas.
I've had the tires on my car for nearly a year without any alignment, wear, or handling abnormalities. If afforded the opportunity to up grade my wheels I would opt for a wider 7.5 or 8" but I'm happy with the choice I've made.
Dave
TallTom
57
Oct 14, 2025 05:16 PM
litch
123
Jan 4, 2024 07:01 PM
Gingerheadman
Oct 1, 2015 05:11 PM
Sep 27, 2015 08:37 AM
