Unanswered questions about DIY ambient footwell lighting w/ headlights.
I was looking in my foot well today, above gas/brake pedals, brainstorming on how to install some blue ambient lighting down there. I snapped this picture, and did my best to make it clear:
My question is this: does anybody know if any of the wires I have pictured are connected into the headlights, and are thus okay to tap into? It's a huge mess of wires, and I have no clue how to tell which is which.
What size resistor should I use (I've read different answers on this -- yes, I have searched, and quite a lot at that)?
On the bright side though, it appears that it would not be too difficult at all to install two blue LED's, hooked up to a simple toggle switch (in case I wanted them off with the headlights still on) in driver and passenger side.
Also, what size wire is that in there? looks like roughly 20 or 22 awg, but I didn't get a good enough look.
One more thing - not sure if I should use a squeeze connector like this or just wire nuts like these
Thanks a million guys
Well, you mentioned installing a toggle switch as well. It would be alot easier to just tap a fuse and use a simple toggle. By the way, the flashers, lights, etc, run through the wire harness at the lower left drivers side. Use the parking lamp wire if you need too. This way you can turn your LED's with the parking lamps only if you want. The parking lamp wire is red w/blue stripe that goes into your fuse block.
Is the wire harness I have pictured the one with the parking lamp and such?
I can't tell from you picture. But the harness for the parking lamps is to the left and slightly up from your left foot. I had to remove a bunch of electrical tape and crap to get to the actual wires. I'm trying to upload a pic...
Ok. The parking lamp wire is where that blue connector is. Obviously ignore the connector, my remote start uses that. It was a pain in the *** trying to take a pic of that area with my huge camera. Hopefully it helps, somewhat.
looks like it will be a huge help. I will take a look in my car when the sun comes out tomorrow
One more thing, I know you said which wire the positive was for the parking lamp, but which is the negative?
thanks again you are really helping me out here
5 ltr. beater, I am going to use blue led's to match the (somewhat) blue dash/gauges
edit: what size are the wires I'm tapping into/what size should I buy?
the entire metal body of the car is connected to the negative terminal of the battery, so you can connect the negative lead to any handy spot like VQPOWER said. Could someone tell me if dan.worts could connect the led's to the dash light wire circuit.
I don't see the point in tapping into anything other than headlights or parking lights, because footwell lighting can really only be noticeable at night, correct? Dash lights could work too, or anything that comes on with the headlights. That is, unless you want courtesy lights down there, which I may do with white LED's at a later date.
VQPower, I will take a look in my car in about an hour
this is the best I could do in getting a picture -- I found the red wire with a blue stripe going into the fuse block; it was a separate wiring harness from the one I originally pictured.
It seems like, as long as there is enough slack in that hot wire for a tap (which there has to be), it could be a very simple job. I could build the entire circuit outside of the car, then I could just secure all the LED's in place and connect the female and male ends of the t tap. I don't even think I will need a resistor if I use pre wired 12 volt LED's like these
VQPower, what kind of connector do you have on there?
paint wiring diagram ftw
They are called "T Connectors." Very simple and requires no cutting of the OEM wires. You simply squeeze the connector on with a pair of pliers and connect your lead wire with a normal connector like in my photo.
http://www.autozone.com/autozone/acc...mString=search
I would suggest always using a relay whenever tapping into something. It may work fine but you run the risk of killing a fuse or killing a wire that is not rated for what you throw at it. Possibly diodes and other electrical equipment as well.
VQPower, what gauge wire connecter did you use? 14 - 16 as you linked to? Cause I'm not sure what gauge wire to buy to use in my circuit.
If I use 18 gauge wire for my project here, will a connecter like this work with the two different size wires?
http://shop.advanceautoparts.com/web...A|GRP2020A____
Cell phone picture is the best I could do, and it came out bad lol. You get the idea, though. I will try to get up a nice digital camera picture soon if anyone wants me to.
It looks brighter in some places than in others, for whatever reason, but it looks perfect in real life
still need to install a switch
I've been following this thread hoping to read someone give advice on tapping into the courtesy lights, so this footwell lighting only comes on when the doors are open.
Love to see dan.worts' end-product pictures. (That cell phone photo is a total fail. Sorry, Dan.)
While waiting... does anyone have advice on that courtesy light idea? There's this thread here, but it never finished and specific info wasn't evident:
http://forums.maxima.org/5th-generat...ll-lights.html
Why footwell lighting? IDK. Why not?
Thought I'd play with it, is all. If I don't like it, then I don't keep it. It's not ricey because it would just be fore the driver, lit when the door opens.
Besides, lots of cars come with footwell lighting stock. The 6th gen does, I believe.
I used "Alpena HyperLED's" from AdvanceAuto. 4 to a box, 2 for drivers side and 2 for passenger side. I just mounted them on the lip before the footwell opens up to all the wiring/the glove box.
How long are the wires out of the box, please? Here's autozone's link.
Nevermind, found them listed at Walmart with a 1.0 meter spec. Hmm.
Page EL-97 in the 2003 FSM. This is the SECU with the wiring harnesses disconnected. For the courtesy lights, I need to tap into #32 for positive, and #43 for ground. (Thanks to knight_yyz.)
Haven't tried anything yet. Still gathering info and ideas.
Wise choice LEDs are. How can you not like LED work like mine??!
For your consideration:
http://forums.maxima.org/5th-generat...-led-mods.html
http://forums.maxima.org/5th-generat...-109-leds.html
There's something wrong with all you LED naysayers. LEDs look great and are cheap and fun to put in.
