LEDs for gauge cluster
Old Jul 25, 2010 | 03:51 PM
Maxy91's Avatar
Hey guys im looking for blue LEDs for the gauges ive heard many different opinions of where to buy them from im just trying to avoid the hotspots ! if anyone has any links they can send me id grealy appreciate it !
Old Jul 25, 2010 | 04:22 PM
03VQMAX's Avatar
www.autolumintation.com, www.ebay.com, bulb #24/T6.5 Fits perfect but I've heard bulb #74 will work too.
Old Jul 25, 2010 | 04:27 PM
jowo9's Avatar
Whatever you do, get "high power" LEDs. Otherwise they'll be too dim.
V-LEDs.com is more expensive but they're the best.
Old Jul 25, 2010 | 04:42 PM
Maxy91's Avatar
http://www.v-leds.com/Interior-LED/G...orLanding/true
which one would i get and how many would i need ?
Old Jul 25, 2010 | 04:44 PM
Maxy91's Avatar
I got my interior LEDs from there but my friend had sent me the exact link so that i could just order them and then i installed them myself.. do you think you can provide me the link to exactly what i need to buy ? its so confusing for me
Old Jul 25, 2010 | 06:13 PM
03VQMAX's Avatar
http://cgi.ebay.com/ebaymotors/T6-5-...Q5fAccessories
Old Jul 25, 2010 | 06:39 PM
jowo9's Avatar
Well there are 4 number 74 bulbs lighting up the gauges and various others for signal lights etc. But just 4 for the gauge illumination. If you know how to solder, I'd recommend using some bigger 194 bulbs and using a dremel to bore out the holes a bit. Here's a link where someone did it with incandescent bulbs (which I don't recommend - too hot). But you do the same thing.
http://www.cardomain.com/ride/758364/2
This is what I'd do if I hadn't done my crazy 109 LED gauge conversion...
Or just try the #74's. They'd probably be ok. As long as they're high power... Like these for instance:
http://www.v-leds.com/Interior-LED/G...22390-1-2.html
Old Jul 25, 2010 | 06:44 PM
cjandura's Avatar
I'm going to give this product a try when I pick up a donor cluster. http://www.streetglow.com/SGULST19GR
Old Jul 26, 2010 | 05:09 AM
NissanMan97's Avatar
how many of those do you need? is it really that big of an improvement?
B
Old Jul 26, 2010 | 09:03 AM
Maxy91's Avatar
How many of these will i need to order ?
Old Jul 26, 2010 | 10:05 AM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
Stupid double post
Old Jul 26, 2010 | 10:06 AM
Chocolate_Boi_1Der
Bro I'm on my cell but you do a little looking around the 5th gen forum there's a really good write up on using both bulb styles. I recommend the larger led bulb if u can solder and have patience. There was also someone offering the service on 4th gen clusters and I think he can do these as well. It shows which style and the outcome for both installations. Takes a little soldering but appears to be well worth it.
Also check out the how to link in the top. Breaks down a lot of...mods? Upgrades? Projects? And keeps the old heads from blowing a gasket lol.
Old Jul 26, 2010 | 10:16 AM
Chocolate_Boi_1Der
dude that can mod cluster
Old Jul 26, 2010 | 10:20 AM
Chocolate_Boi_1Der
Jowo already gave u a link above to the write up I was talking about. It's on metals cardomain
Old Jul 26, 2010 | 03:29 PM
03VQMAX's Avatar
2 sets since they come in a pair, it takes 4 bulbs.
Old Jul 27, 2010 | 12:16 AM
a33_ridah's Avatar
i must say i got hyper white 3 smd #24 leds...and i am
disappointed. hot spots on the 40-60 mph and 3-4k rpm like a bish.
it looks allright in complete darkness..somehow the hotspots are less visible as compared partial light when hotspots are highly visible.
pics do not effectively capture how it looks in person. trust me. either do it proper with 80+ leds cuz i dont think the 4 #24 will satisfy most.
pics of hyper white smd
Old Jul 27, 2010 | 08:45 AM
jowo9's Avatar
Yeah, like I already told the OP, you MUST get "high power". Like at LEAST 0.5 watt or more.
Old Jul 27, 2010 | 08:51 AM
will you have hot spots with the high power one?
B
Old Jul 27, 2010 | 09:19 AM
jowo9's Avatar
B
Yes, but not as bad... There's no way to completely avoid hotspots w/ LEDs unless you do a full conversion like I did... but that was crazy.. took me 3 days. And you have to be good at soldering/fabricating stuff. (and I GUESS there are technically still minor hotspots, etc... but I love it)
Like this!
Oh, and here's a couple of my threads that have good info on them if you read through them (I think the 2nd one has the best info with regard to what you're looking for).
http://forums.maxima.org/5th-generat...-109-leds.html
http://forums.maxima.org/5th-generat...my-gauges.html
Old Jul 27, 2010 | 09:26 AM
you wanna do one for me? maybe not 109 though
B
Old Jul 27, 2010 | 09:46 AM
a33_ridah's Avatar
My LEDs
eBay search item #
200474824190
that's the high power Led I used. Same item same seller. Claims to be the brightest around. You see my results. Next if I retry will be concave LEDs. Widest range LEDs avail in high power to try to spread likght to avoid hotspots...??
Feedback.
Old Jul 27, 2010 | 09:49 AM
jowo9's Avatar
B
I would consider it, but in order for it to be worth my time, I'd have to charge you an arm and a leg.
Old Jul 27, 2010 | 04:55 PM
PM me and lets talk numbers
B
Old Jul 27, 2010 | 10:40 PM
tokomoto's Avatar
wow that is a really bright cluster. I'd love something like that.
Old Jul 28, 2010 | 05:14 AM
Rydicule's Avatar
Don't you know who I am?
http://autolumination.com/74.htm
You'll have to scroll down to the Tri-Power 3 LED bulbs. They look like this:
http://superlumination.com/images/au...24_ts_w_wm.jpg
I moved 5 different sets of LEDs into my guages on my 02 Max. These were far and away the best when it came to hotspots vs brightness. There are brighter bulbs... but they come with crazy hotspots. Likewise, there are more evenly spread bulbs... that are just too dim. These were the ones that seemed to be the best compromise.
A couple of thoughts for someone that hasn't done this before:
1.) Hotspots: LEDs are directional lighting, unlike incandescent bulbs. This means that any LED made to fit and replace the incandescent bulbs will show some hotspots. The ONLY way to avoid this is a custom setup with a backing densely littered with diodes... there are writeups on how to do this. However, if you are going to attempt that, you must have tremendous time, patience, and at least a basic knowledge of electrical mechanics. If you looking for a plug & play... those that I linked are the best.
2.) Don't get blue LEDs. Get white. This was a lesson I learned the hard way. Blue LEDs are a sharper blue, however, they are dimmer and have worse hotspots than the white. You will not be able to read your trip displays at night. White, on the other hand, is brighter with fewer hotspots and will still show your trip displays at night well. They will still appear blue on the guages because there is a blue film behind the guage (This is why with yellow incandescent backlight, the display appears green).
Old Jul 28, 2010 | 02:08 PM
Henryzx's Avatar
Hello everyone, newbie here, don't know why I couldn't start a new thread (?), so I have the use this one to ask a question.
Just got a 2k GLE, runs beautifully.... anyhow, the back lit of the AC controller went out, how do I replace the bulbs back there? please help ... thanks in advance
Henry
Old Jul 29, 2010 | 07:35 AM
Rydicule's Avatar
Henry
Hey Henry,
You couldn't start a new thread because all users must have at least 15 posts before they are able to start new threads. This helps cut back on spam.
As for your question, there is a thread at the top of this page for new people (less than 15 posts) to ask any 5th gen related questions they have, and it gets far more attention than this thread will. You'll probably have better luck posting your question there.
Old Jul 29, 2010 | 12:08 PM
Henryzx's Avatar
hey thanks Rydicule
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
