What do you do to make your engine look pretty? :)
Old Nov 19, 2010 | 04:40 AM
  #721
Rochester's Avatar
I'd to see how your NWP Torque Link looks now that it's been powdercoated black.
Old Nov 19, 2010 | 08:56 AM
  #722
Rochester's Avatar
I'm pretty much done with the hole-plug thing now. Aside from that annoying oblong hole on the passenger side of the front support beam, which I left alone, I'm pretty happy with the results. Here's a picture of the driver's side:
Old Nov 19, 2010 | 10:17 AM
  #723
vball_max's Avatar
Nice John......you engine bay is damn sweet looking now......great work.
BTW.....would you like to trade cars?
Old Nov 19, 2010 | 10:20 AM
  #724
rroderiques77's Avatar
Demodded and Forgotten
Actually, the torque link is greay metallic. I didn't want to do it in black.
Old Nov 19, 2010 | 10:31 AM
  #725
Rochester's Avatar
Thanks, Kevin. Um... no to the trade.
Originally Posted by rroderiques77
Actually, the torque link is grey metallic. I didn't want to do it in black.
Good. I thought black was an odd choice for that.
Still want to see it, though.
Old Nov 19, 2010 | 10:40 AM
  #726
Well. They had to re-do it actually. I asked for polished the second time. We'll see what happens.
Old Nov 19, 2010 | 10:42 AM
  #727
Rochester's Avatar
I'm guessing they sand-blasted it first, right? There's some kind of brass-like plating on the bar.
Old Nov 19, 2010 | 10:52 AM
  #728
I double checked on the coolant pipes. The oven in which the items are baked in heat the finish to temperatures up to 500 degrees. Hot coolant will not be a problem.
Old Nov 20, 2010 | 07:24 PM
  #729
Rochester's Avatar
I had TroopleWis zap the pipes with his nifty little infrared tool... it seems a little hotter than I expected.
Originally Posted by trooplewis
LOL, well I was wrong on the 180 degree bet.
After a 30 mile drive in the rain at outside temps of 58°, I shot the temp on the top front waterpipe with the car idling in my driveway. 230° was the readout I got, supposed margin of error is 4%
My temp gauge always looks like it is on the low side, now I am really curious what temperature the coolant runs at.
Old Nov 21, 2010 | 09:12 AM
  #730
zero2sixtyZ's Avatar
You embarrass me.
rroderiques77, the FSTB and coolant pipes look amazing.
Just for reference, how much are you guys spending on powdercoating these pieces? When I have my motor out soon, I want to get some of this stuff done.
Old Nov 21, 2010 | 09:13 AM
  #731
What I finally decided to do with it is take it down to bare metal, smooth it, and clear it. It should give it a stainless look.
Old Nov 21, 2010 | 09:16 AM
  #732
A lot. Plan on spending a few hundred. Unless of course you know somebody in the business. I sure don't.
Old Nov 21, 2010 | 09:18 AM
  #733
Your temp gauge registers whatever temp the coolant temp sensor registers. The coolant pipes, being made out of metal probably run hotter than the actual coolant itself.
Old Nov 21, 2010 | 09:49 AM
  #734
You embarrass me.
I do have a couple places recommended by other forums, so I'll see what they quote me. Have yet to have anything powdercoated though.
Old Nov 21, 2010 | 07:49 PM
  #735
Did you do the same for the holes under the cowl? Too bad we can't so the same for the smaller ones.
Old Nov 22, 2010 | 05:30 AM
  #736
Rochester's Avatar
What are you talking about?
Old Nov 22, 2010 | 04:20 PM
  #737
trooplewis's Avatar
How hard is it to take off the front heat shield that covers the stock exhaust manifold?
Mine looks almost as corroded as Rochester's old horns.
Old Nov 22, 2010 | 04:45 PM
  #738
The ones on the outside of the firewall.
Old Nov 22, 2010 | 04:48 PM
  #739
Rochester's Avatar
You know, I think you started something about this a few posts back. But I'm still having trouble placing what it is you're referring to.
Pics, maybe?
Old Nov 22, 2010 | 04:51 PM
  #740
Pics, maybe?
I will take some. Don't have any right now.
Old Nov 24, 2010 | 03:23 PM
  #741
Pics, maybe?
Cell phone pics FTW!!!
Old Nov 24, 2010 | 03:56 PM
  #742
So here is the torque link.
Sanded it down and cleared. Came out excellent. Going to do the same thing for the timing cover.
And no Rochester, the most amount of turns by hand I could get out of the damn thing was two. That third one, ouch!!!
Old Nov 24, 2010 | 04:30 PM
  #743
Rochester's Avatar
OH! Are you suggesting I remove them and replace them with the silver plugs? That's a fine idea, but I don't know the diameter of the holes... without removing one. Catch-22.
Old Nov 24, 2010 | 04:35 PM
  #744
Rochester's Avatar
That.... looks.... AWESOME!!!
I'm doubly psyched now to get mine powdercoated in the same "black chrome" as my FSTB brackets. Very well done, Roy.
I'll be taking mine off for the winter tomorrow, and will experiment with the hand-cranking technique. Remember, I keep my Torque Link on 24/7, but locked down in the at-rest position. In other words, I don't put the engine weight on the brace... I just use it to keep it from twisting under load. That's probably the difference between how we have it configured.
Old Nov 24, 2010 | 08:17 PM
  #745
Water outlet pipes will also be done in the same finish. I am debating on dp as well. It would match the UIM.
Old Nov 25, 2010 | 07:06 AM
  #746
Rochester's Avatar
What's "DP", Roy? What are you referring to, please?
Also, you see that green lettering on your PS hose? (I think that's your PS hose to your new tank, right?) Anyway, that lettering can come off with some fine steel wool, making for a uniformly black hose.
Old Nov 25, 2010 | 08:18 AM
  #747
jowo9's Avatar
I believe Mr. Turbo man is referring to his downpipe
Old Nov 25, 2010 | 08:49 AM
  #748
Rochester's Avatar
I just removed my Torque Link for the Winter, and you're absolutely right. You can only get maybe two full turns by hand before you need to use a wrench.
5 months of daily driving seems to have weathered that steel bar somewhat. Glad I removed it to get refinished. I think I'll replace the retaining nuts while I'm at it. This time in chrome or stainless steel... No, wait. Titanium. That would be nice.
Know what I'm talking about, Roy?
Oh. I'm totally turbo-dumb.
Old Nov 26, 2010 | 07:04 AM
  #749
I remember you saying something about that. Thanks for reminding me.
Are those bolts stainless already? I guess they aren't... Hmmmm
Old Nov 26, 2010 | 07:11 AM
  #750
Rochester's Avatar
The 4 bolts holding the frame-piece are SS hex-heads. Replacing them with Ti-bolt buttonheads from DressUpBolts.com has been on my mind.
Old Nov 29, 2010 | 05:54 PM
  #751
Rochester's Avatar
Well, this thing is kind of interesting. It seems smaller than I thought it would be, which suits me better. Still not sure if I'm going to mount it anywhere in the engine bay yet... but it's kind of unique looking all the same.
Old Nov 29, 2010 | 06:00 PM
  #752
scarface4522's Avatar
What is that off of Rochester? I like it. Whats the back look like?
Old Nov 29, 2010 | 06:08 PM
  #753
Rochester's Avatar
A Nissan Bluebird... don't know what year. Don't even know what a "bluebird" is.
The back is just whatever is leftover from thick, rubber adhesive.
Bought it off eBay, shipped from Thailand.
Old Nov 29, 2010 | 06:24 PM
  #754
Ghost_54's Avatar
Now if you had some form of aftermarket mesh grill John that would look pretty sweet instead of the over-sized Nissan Hamburger
Old Nov 29, 2010 | 06:44 PM
  #755
Rochester's Avatar
I'd never thought of that. I suppose there are other NISSAN emblems that could fit the bill just fine in an aftermarket grill. Good idea, Ghost.
Not for me, personally, but good idea none-the-less. If I mount this little bling anywhere, it will be under the hood. I'm thinking in the middle, on the hood-latch plate.
Whatever I do, if anything, I'll take pictures for sure.
Old Nov 29, 2010 | 10:23 PM
  #756
What about somewhere on the firewall?
Old Nov 30, 2010 | 05:17 AM
  #757
Sowfpaw's Avatar
looks sick
Old Nov 30, 2010 | 07:01 AM
  #758
Rochester's Avatar
I looked at that idea this morning before heading out, and no, there really isn't anywhere on the firewall that would work.
There are 3 places I'm considering:
  1. On the flat panel above the hood latch. This is a perfect fit, actually. Although I rather like the little Energy Suspension decal there right now.
  2. On the battery, replacing the little bling NISSAN emblem I put there last year. Ghost_54 gave me that little emblem, and while it's nice and all, this NISSAN Bluebird badge is a more significant design.
  3. On the top of the UIM. Which is kind of an interesting look. Not sure how well things would stick to the aluminum, however.
I've circled the options in red here. Anybody have any opinions?
Old Nov 30, 2010 | 07:06 AM
  #759
Rhyno02's Avatar
Hey Rochester, what about on the FSTB? I dunno if you'd have clearnace issues or if itd fit but, I think it's worth consideration.
My vote though is for where you have the energy suspension sticker. I think it'd look kinda silly on the intake manifold.
Old Nov 30, 2010 | 07:18 AM
  #760
Rochester's Avatar
I know that the FSTB rubs against the fabric panel under the hood, because I can see the fine scratches that have occurred in the last couple years. That doesn't mean it wouldn't work there, but I didn't consider it because of the rubbing. Maybe I should just try it out and see if it works, because it would look pretty good there... assuming it the bar width could support it.
Good idea, Rhyno.
