Timing issue
Old Aug 3, 2010 | 10:34 PM
zero2sixtyZ's Avatar
You embarrass me.
Timing issue
So I was just reading from my OBDII and noticed my timing is off. Sitting at 12/13 at idle.
Car gets only 93, and has an occasional P0300 when sitting at a constant RPM (whether at idle or if I literally stay on the highway at the same speed for a long time).
Tried advancing it +2, and it stayed at 12/13.
Old Aug 3, 2010 | 10:41 PM
Unklejoe's Avatar
Maybe a bad knock sensor?
Old Aug 4, 2010 | 01:43 AM
knight_yyz's Avatar
Toolie
obd2 port is not the best way to check your timing. Look again in a day or two and it will probably be where you want it to be. I've had this happen quite often with autoenginuity
Old Aug 4, 2010 | 06:09 AM
NmexMAX's Avatar
dot dot dot ...
^^^ with the Cipher with me.
Old Aug 4, 2010 | 08:34 AM
You embarrass me.
Thank you. I'm using the Autoenginuity as well. I just reset the ECU the other day, so I will try again today and tomorrow after driving it a bit.
I'm also diving into this P0300 issue. Starting with the PCV, and going down the FSM listed things to check.
I'll report back guys.
Old Aug 4, 2010 | 08:42 AM
NmexMAX's Avatar
dot dot dot ...
Shouldn't the P0300 issue be DIRECTLY related to this?
Old Aug 4, 2010 | 08:56 AM
You embarrass me.
I would imagine if I'm misfiring, it's going to retard the timing. I'll check it again today and then go down the list. I almost hope its the clogged cat/precats. Serious excuse for some headers...
Old Aug 4, 2010 | 01:27 PM
P. Samson's Avatar
Assuming you mean 12/13 deg. BTDC as opposed to ATDC, your ignition timing is within the '02 FSM limit of 15 deg. +/- 5 deg. BTDC. This is for basically no loads at the warmed up correct idle speed of 625 +/- 50 RPM (for your MT). You cannot change the ignition timing with a standard OBDll scantool. Nissan's Consult ll is required. What's happened to the search links?
Old Aug 4, 2010 | 01:29 PM
You embarrass me.
You can do it with the Autoenginuity w/ Nissan Interface or the Cipher. It is within spec, but did not advance when I added +2.
Old Aug 4, 2010 | 04:20 PM
Prophecy99's Avatar
good luck, wish i could do sheet like this.
Old Aug 4, 2010 | 05:51 PM
You embarrass me.
Removed oil catch can setup, figured there might be a leak there...
and bam. Reset the code, let the car idle for a long time and no P0300. Checked timing, whether it was due to the P0300 loss or not, running at 17 BTDC.
Thanks guys.
Old Aug 5, 2010 | 06:17 AM
NmexMAX's Avatar
dot dot dot ...
Damn, maybe I should take mine off too ...
Old Aug 5, 2010 | 07:24 AM
You embarrass me.
Do you have a P0300?
Old Aug 5, 2010 | 07:49 AM
NmexMAX's Avatar
dot dot dot ...
No, but my base timing seems semi fubar'd too (13 ish).
Old Aug 5, 2010 | 08:20 AM
You embarrass me.
Yeah, even though it is within spec, they should be running at 15. Did you change your idle at all? I had mine set at +75 but after seeing that "spec" is +/-50, I reduced it to 50 just in case it tripped anything.
trasmadean
Jan 20, 2018 05:05 AM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
Finkle
Sep 27, 2015 09:53 PM
JoshG
21
Sep 4, 2015 09:04 PM
