You guys are not going to believe this
I decided to change my transmission fluid in my 01 5spd. I jacked the car up, unbolted the drain plug and nothing came out! I refilled it with 4 liters of gl4 fluid and noticed I have a massive leak from the drivers side axle.. Basically I have been driving without transmission fluid for months. How is this car still driving?
The tranny still shifts great but there is a slight whine in 1st and 2nd under heavy acceleration.
Little chance of driving for an extended time with an empty trans. And seals aren't made to provide a complete seal from top to bottom. So overfilling would cause most of the 4 liters to drain out. Of the top of the shaft opening.
Which means it still probably full if not overfull.
But overfilling is bad. It may also drain through the input shaft onto your clutch and pressure plate.
So find the correct plug and get the unit drained entirely and refilled.
I tried one bolt at first and it was the wrong one. The next one I tried was about an inch long and had a bit of fluid around it but nothing came out. Could it be because the car wasn't completely flat?
Does anyone have a good diagram that shows the drain plug so I can confirm?
Yes I was expecting it to start overflowing but it never did. It's the 5spd LSD tranny that comes with the anniversary edition. What are the chances that the axle is making the whining sound and not the bearings or gears?
When my 5 speed ran low on gear oil, I was literally locked out of 1st and second gear. I had to drive using only 3rd, 4th, and 5th. My clutch didnt like that very much.
Can you take a picture of the transmission and show where you filled it, where it was leaking from, etc?
No matter if you were right or wrong, someone somewhere can learn from this -- possibly even me.
Thank you very much for that^ There shouldnt be any confusion at all now.
And for those who are confused about what to use to remove the plug, you use a half inch ratchet. Yes just the ratchet..
Just this. No socket, no nothing on the end. Just use the 1/2" nub on the end. The plug has no "head" on it unlike a normal bolt. You will just see a recessed square that the ratchet can fit into. And you will see external threads.
wow.....thats sum luck.......one time i was about to head out to da gym and i almost fell.....i looked down and theres big puddle of oil on the ground....then i found out it was leakin from my car......sum how the bolt on the oil tank got loose.....when i took it off nothin came out.....it completely drained......if theres any explanation please let me know?
the garage just called. They want 2 hours of labour at $80 per hour to replace the axle seal and $50 for the seal and then another 2 hours to replace the front wheel bearing which they think might be making the sound. Man I hate garages. Pure ripoff and Im going to be without my car till Monday/Tuesday.
It's a pure rip off. The first other garage I called (which is known to be expensive) was $60 less. I'm pretty pissed. I thought I could trust these guys. I should have done it myself. I'm not the quickest at it but I'm sure it wouldn't take me a whole week either.
I would consider yourself lucky!
Max139617
Sep 6, 2015 06:02 PM
Bust your own knuckles or pay someone what they ask for them to bust theirs.
