What is this thing on my 5th Gen?
Old Sep 19, 2010 | 04:42 PM
  #81
Rochester's Avatar
Originally Posted by findingnismo
So in reality if i put on an intake, i can trash it all?
Yes. But don't throw it out. Stick it in the attic, or sell it in the FS forum to someone who's going back to stock.
Old Sep 19, 2010 | 05:28 PM
  #82
knight_yyz's Avatar
Toolie
that's why I said 00-01
Old Sep 21, 2010 | 06:13 AM
  #83
Rochester's Avatar
Here are 2 more harness connectors, on the transmission side of the engine. One is a sensor on the water pipe... coolant temp? IDK.
Bump
Old Sep 30, 2010 | 06:01 AM
  #84
NissanMan97's Avatar
what this?
B
Old Sep 30, 2010 | 07:24 AM
  #85
sontakke's Avatar
Where is the brass bolt which always breaks when replacing the alternator? I heard it was part of the tensioner.
Old Sep 30, 2010 | 10:34 AM
  #86
Froggmann's Avatar
Originally Posted by NissanMan97
what this?
B
That would be the main belt tensioner. To change out your belt you would have to back off the nut on the tensioner pulley itself then turn that to increase/decrease tension on the belt.
Oh and you also have to hope the guy before you didn't over-tighten the pulley nut. There isn't much for the wrench to bite on and the nut doesn't have that much hardness to it.
Old Sep 30, 2010 | 10:45 AM
  #87
Froggmann's Avatar
Bump
What color are the wires?
Ok I just looked, The one that goes into the water pipe is the Coolant temp sensor, the red one goes to the motor mount (mine goes to nothing?), and the one that clips to the metal thing goes to the Knock Sensor.
FSM pages EL-464/465 Connectors F8, F9, F22
Old Oct 5, 2010 | 09:17 AM
  #88
Eirik's Avatar
(from Rochester's tucking thread)
What does that "EVAP canister purge volume control solenoid valve" plug actually do? I disassembled my intake and stuff one day and then forgot to plug that back in after reassembly. It dropped my fuel economy from 21 to 13 MPG.
I'm not really understanding what change that causes. The evap lines were still connected, so it's not like fuel vapor was dumping into the engine bay? What kind of measurement is that plug taking?
@NissanMan97: Good luck with those nuts. Mine had been overtightened. Then rusted. I think, all told, it took my friend and I SIX HOURS to change the accessory belt.
Old Oct 5, 2010 | 09:25 AM
  #89
Rochester's Avatar
Thanks, Froggy!
Identified by Froggmann as Coolant Temperature Sensor, and the other end of the Knock Sensor Harness -- pages EL-464/465 in the FSM.
Old Oct 5, 2010 | 09:33 AM
  #90
alcala87's Avatar
The solenoid doesnt take readings, it just opens and closes based on certain driving conditions. With it not plugged in, it will stay closed and the car wont burn any fuel vapors causing economy to go down. Thats a big drop in economy! Ill make sure to remember to plug that in when i do intake work.
Old Oct 14, 2010 | 03:45 PM
  #91
trooplewis's Avatar
ba-da bump!
This thread is extremely cool, and should be stickied!
Old Oct 21, 2010 | 04:12 PM
  #92
deathmagic's Avatar
hi I was wondering anybody know where the fuel filters in a 2000 nissan maxima's located at. my cars been sluggish lately. not sure if its the fuel filter being clogged (92K miles)
Old Oct 21, 2010 | 04:23 PM
  #93
Rochester's Avatar
Questions like that go here.
There's a theme in this thread which is like 180 opposite your question.
Answers to your question are all over this and other forums. All you have to do is search for them.
You can do some of your own research with either the Field Service Manual, CoutesyParts.com, or by calling your local dealership.
And finally -- if it's like my 2003, it's an integral part of the fuel pump, accessed through the floor under the back seat.
Click on the baby for a how-to write-up. Go ahead. Click on the baby. It's probably the best write-up on this topic.
Old Oct 21, 2010 | 04:38 PM
  #94
rroderiques77's Avatar
Demodded and Forgotten
Old Nov 20, 2010 | 10:24 AM
  #95
trooplewis's Avatar
Another bump because this thread is getting buried and deserves to be up front!
Old Nov 21, 2010 | 04:21 PM
  #96
tonyc994's Avatar
ahhh that one helped
Old Apr 10, 2011 | 08:08 AM
  #97
Montego Murph's Avatar
OK -- I'm going to recycle someone else's photo because I can't take a good photo of mine with everything reinstalled:
OK -- looking at this photo, I believe the front of the car is to the right. (that is to say, this photo was taken from the perspective of standing at the right front fender.)
The coolant temp sensor (lower left hand circle) and mounted into the coolant tube. On my 01 i30, there is a smaller sensor with a single wire coming from it maybe an inch away towards the front on the same coolant tube. In this photo it would appear almost right below where the coolant pigtail comes out of the harness.
What is that sensor?
I just answered my own question in another thread, and thought I'd post it here so others can learn:
Both are coolant temp sensors. The first one is for the gauge in the car the second one, closest to the engine, is for the ECU. The ECU controls the fans based on the coolant temperature, vehicle speed and A/C compressor.
Old Jun 15, 2011 | 01:43 PM
  #98
QT1 5MT AE's Avatar
Gram Lights addict
too lazy to go to the garage and take a decent pic but i have yet to have someone explain to me what this little tab is?
Old Jun 15, 2011 | 01:50 PM
  #99
Rochester's Avatar
Good question.
If I had to make an educated guess, it's to insure the window stays in position when going up, so that it doesn't shift to the wrong side and shatter under the stress.
Old Jun 15, 2011 | 02:07 PM
  #100
QT1 5MT AE's Avatar
Gram Lights addict
I've heard this before but it doesn't make any sense to me for two reasons:
A) its on the outside, windows are on a rail and enclosed within the door, how would they pop out?
B) 4th gens didnt have this and neither do most cars. why the 5th gen?
Old Jun 15, 2011 | 02:24 PM
  #101
8000watts's Avatar
I came outside to see this hanging from my exhaust. I'm assuming it's just a cover. But what is it good for?
EDIT: QT1 5MT AE said it was the "cat shield" and T.One verified that it shields it from harder things such as rocks and scraping when you're low to the ground... BAM! lol
Old Jun 15, 2011 | 02:28 PM
  #102
QT1 5MT AE's Avatar
Gram Lights addict
thats your cat shield...
Old Jun 15, 2011 | 02:35 PM
  #103
8000watts's Avatar
And what exactly is it shielding it from? The harder things like rocks?
Old Jun 15, 2011 | 02:40 PM
  #104
T.One's Avatar
Pretty much exactly what you said but add from skidding if you are low so it doesnt rip open as easily
Old Jun 15, 2011 | 02:48 PM
  #105
8000watts's Avatar
Ah! Thanks to you both. If i was to get an aftermarket exhaust, would it also come with one? Or is that depending on the company?
Old Jun 15, 2011 | 02:49 PM
  #106
DennisMik's Avatar
That is to guide the glass into the track when the window is being rolled up when travelling at highway speeds. The venturi effect sucks the window out at higher speeds, so a guide is needed.
Old Jun 15, 2011 | 02:56 PM
  #107
Rochester's Avatar
That makes a lot of sense.
You get a cookie.
Old Jun 15, 2011 | 03:13 PM
  #108
Froggmann's Avatar
http://i739.photobucket.com/albums/xx33/8000watts/rustedcover.jpg[/IMG]
It's not so much a physical shield it's more of heat shield. It's to prevent the cat from igniting grass and other combustibles underneath the vehicle.
Old Aug 13, 2011 | 08:04 PM
  #109
ProW649's Avatar
This is now my 2nd fav thread
Old Aug 14, 2011 | 08:24 AM
  #110
After about 6-8 years on the car its only purpose is to create resonant vibration at specific RPM's as the spot welds break off.
I've removed every rattling heat shield on my cars and never had a problem. Then again, the manufacturer puts safety equipment there for a reason, and I do not condone anyone removing anything. I'm just saying what *I* do.
Old Oct 24, 2011 | 04:33 PM
  #111
mrjamaica98mx's Avatar
this wire seems to be burning what is it? ty
Old Oct 24, 2011 | 04:39 PM
  #112
Flanker84's Avatar
At first I think that it was the coolant temp sensor but that sensor it's behind. Maybe it's the coolant pressure sensor or something similar.
Also, yesterday I was taking some photos of the engine bay and I saw this
Anyone knows what is this?
Old Oct 24, 2011 | 06:24 PM
  #113
Scroll up and look at post #97. Months ago I predicted that you would want to know, so I posted it there but forgot to tell you! :-)
Old Oct 25, 2011 | 02:18 PM
  #114
#97 seen that mine is a 01 i didn't notice until i re read it
Old Oct 27, 2011 | 09:05 PM
  #115
luvlexus101's Avatar
Old Oct 27, 2011 | 09:22 PM
  #116
T_Behr904's Avatar
Originally Posted by luvlexus101
Never seen that one before. It doesn't say anything in the owner's manual what that light is for?
Old Oct 27, 2011 | 09:32 PM
  #117
Mr. Brett's Avatar
Only two conclusions I can draw:
1) It's to tell you that one or both of your tail lights are blown...
or
2) If you have a Canadian car (for whatever reason), to let you know that one of your DRLs are out?
Old Oct 27, 2011 | 09:38 PM
  #118
03VQMAX's Avatar
You have a brake bulb out or If you have leds, it will also show.
Old Oct 27, 2011 | 09:40 PM
  #119
T_Behr904's Avatar
Hmmm... I'll have to pull a brake bulb out tomorrow on my 5th gen and see if it does that.
Old Oct 27, 2011 | 09:45 PM
  #120
03VQMAX's Avatar
Happened to me not that long ago, that's how I found out .
