Cross member motor mounts - liquid filled. Both?
Sep 10, 2010 | 01:45 PM
Are both front and rear cross member mounts liquid filled on the 6MT or just the front?
Sep 10, 2010 | 02:41 PM
Only the front on an AT is liquid filled.
Sep 10, 2010 | 03:29 PM
on my 5.5 Gen 6 speed, both were liquid filled when I installed the Energy Suspension motor mounts.
Sep 10, 2010 | 04:51 PM
Quote: Are both front and rear cross member mounts liquid filled on the 6MT or just the front?
Quote: Only the front on an AT is liquid filled.
Thanks ColtMax. What I needed to know
Sep 12, 2010 | 05:36 PM
Reizy is correct, only the front on the AT is liquid filled. 6spds do not have liquid filled mounts. Easy way to tell if you don't believe it is to check which mounts have a wire and connector coming out of it, if there is no wire/harness then it is not liquid filled.
Sep 12, 2010 | 06:04 PM
they are all liquid filled, 5 speed 6 speed, auto doesn't matter. Auto's are motorized to increase the pressure of the fluid to make them harder or softer. Even the LCA bushings are liquid filled.
Sep 12, 2010 | 06:12 PM
So, following the OPs questions, if I swap ES mounts into my AT, I will or won't have issues?
I'm desperately in need of motor mounts. My wheelhop is terrible.
Sep 12, 2010 | 06:24 PM
^^^ You won't have any issues, but you might feel a bit of vibration during idle.
Sep 12, 2010 | 10:23 PM
A little bit of vibration isn't gonna bother me. I've got coilovers on the front and mismatched springs/struts in the rear. Doesn't get much more turbulent than that.
