Attn 5 spd owners
Old Dec 16, 2001 | 08:25 AM
Y2KMaxGXE-R's Avatar
Attn 5 spd owners
Boyz, I have noticed a weird sound my car is making when taking off from the start and letting the clutch go slowly. It comes on when the engagement begins, and only in 1st gear from the start.
My friend who's driving a manual Sentra said it may be due to the weakened tension on the belts. I dont believe this **** is normal. My car has 20,600 miles on it.
Now rap to me, wazzup?
Old Dec 16, 2001 | 08:26 AM
RussMaxManiac
Re: Attn 5 spd owners
Weird sound, well gee, describe the sound maybe we could help and where its coming from.
Old Dec 16, 2001 | 08:28 AM
Sprint's Avatar
http://forums.maxima.org/showthread.php?threadid=84617
Old Dec 16, 2001 | 08:31 AM
I cant call it the really high-pitched sound...It is coming from powertrain, thats for sure, if not from the clutch. I ruled the clutch out, because this **** happening only in 1st gear from the take-off.
Thanks for that thread, Sprint. Anyone w/5th gen had the same problem? Yes, it is like a grinding noise, but not metall-w/metall. Ooh, I guess it is time to see the dealer.
Old Dec 16, 2001 | 08:35 AM
ArcticMax's Avatar
i have the same problem
it sounds like a chattering sound. Happens only in first gear on takeoffs.
Old Dec 16, 2001 | 08:40 AM
RussMaxManiac
Re: i have the same problem
Chattering would be your flywheel has hotspots on it from slipping it too much after time. Had that happen on my 98.
Sprint's Avatar
check that thread again..
Old Dec 16, 2001 | 10:26 AM
emax02's Avatar
Re: Re: i have the same problem
Clutch chatter does not make noise though, right? If the flywheel is warped the car will shake when changing gears. That's what happened to me anyway's.
Old Dec 16, 2001 | 10:34 AM
what I have is noway a chattering noise.
Old Jan 15, 2002 | 01:20 AM
klee215's Avatar
yeah i 've heard da noise..but everytime i take it to da dealer they have no f***ing clue and they send me on my way...My car is only a yr old to and only has 9000 miles..thought it was just my car so let me know what it is when u find out.......
thx
Old Jan 15, 2002 | 05:37 PM
Max_Gator's Avatar
thx
How many times do I have to tell you Klee - it is "dey" not they.
Old Jan 15, 2002 | 06:53 PM
My 4DSC
Sounds to me...
like an exhaust bearing.
Old Jan 15, 2002 | 09:41 PM
JimmyH's Avatar
I had clutch chatter on my old max (97 SE). It is from (I am told) not slipping the clutch enough (I dont know, several mechanics I know told me that) and that I was slapping the clutch too hard instead of slipping it more gently. After evaluating my driving style, I realized they were correct. I have a tendency of engaging the clutch very quickly at low rpms.
Anyway, that car had clutch groan from day one, and got worse as time went on (probably from the chatter.) Even after being replaced, the chatter was gone, but still had the moaning. I have read here actually that the groaning is actually a resonating sound caused by vibration in the drivetrain. Take that with a grain of salt.
Someone told me to get rid of the chatter (not the groaning) or at least diminish it, you should burnish the clutch. This consists of holding down the brake and gas at the same time, and gently and quickly partially engaging the clutch and quickly disengaging it. I know it sounds ridiculous, but it did seem to work a little. Take that with a grain of salt also.
Anyway, my current max (00 SE) has no moaning at all.
Old Jan 30, 2002 | 07:42 AM
Badaxxima's Avatar
Throw-out bearing. My brother got a BMW 325ic and about a month later his car made a godawful whacking noise, like the driveshaft (it's RWD don't forget) was off-balance and smacking the transmission tunnel. Only happened in first gear under hard acceleration then got worse and worse until he started to get it in third under half-throttle. Oh and my brother drives like a bat out of hell ALL THE TIME. He liked to chirp third just for fun and would race anyone, so if you drive REALLY hard, get this checked out. He also needed to replace the yoke that operates the T/O bearing.
doctorpullit
Oct 28, 2019 10:58 PM
mkaresh
Mar 12, 2018 06:48 PM
D Mason
Jun 21, 2016 04:43 AM
ef9
Oct 4, 2015 08:43 AM
bernyp
Oct 2, 2015 10:10 AM
