5.5 Gen with 183K
Old Sep 22, 2010 | 04:43 PM
6spd02's Avatar
5.5 Gen with 183K
i have a 2002 Maxima SE 6spd with 183k....just bought it not too long ago and i was wondering if there is anything i should pay close attention to or look out for???
Old Sep 22, 2010 | 04:47 PM
5 ltr. beater's Avatar
im quoting Rochester here:
...so you rapid fired your way through the .org today to satisfy the minimum 15 post count???
Old Sep 22, 2010 | 04:55 PM
Waxima's Avatar
Originally Posted by 6spd02
why not? should i have waited longer????
Not only that but to get those 15 posts you bumped, oh I don't know, probably ten if not more 7+ year old threads to do so.
Old Sep 22, 2010 | 04:56 PM
phatboislim's Avatar
you should have looked in the thread for this sort of thing...but, be weary of the manual transmissions as they are known for popping...@ 188k miles...the transmission was the only major issue i've had, although i had a time finding one...everything else was minor and regular maintenance and its running pretty stout
Old Sep 22, 2010 | 05:01 PM
2slow's Avatar
You're my hero...
Old Sep 22, 2010 | 05:04 PM
nsnrider's Avatar
in short...everything.
it all depends on how well it was maintained, if the oil changes were done on time, every time, etc.
if maintenance was not kept up then some of the things to think about are:
maf
coils
struts
o2 sensors
crank/cam sensors
valve cover gaskets
timing chain guides/ tensioner
water pump
tie rods
bearings
LCA
engine/tranny mounts
tranny slipping
engine burning oil
exhaust
pre-cat/main cat
fuel pump
injectors
etc, etc, etc....
you get the point.
good luck.
Search button is your friend, use it, you'll find a TON of useful info. This has been discussed hundreds of times.
don't bump 7+ year old threads, keep the org organized.
welcome to the forum.
Old Sep 22, 2010 | 05:57 PM
Rochester's Avatar
Hi, Beater! The OP is off to a great start, eh?
Old Sep 22, 2010 | 06:01 PM
Mr.A32ftw's Avatar
Why 2 threads?
Old Sep 22, 2010 | 06:17 PM
HotshotVQ35's Avatar
i only have 65k on mine, and im on engine 3, tranny 4, a dozen axles. 50 coils and 10 sets of rear brakes. this car is the biggest piece of crap i ever had............
Old Sep 22, 2010 | 06:29 PM
Rochester's Avatar
Thanks for the sig quote, Hotshot. That was priceless.
Old Sep 22, 2010 | 07:19 PM
ghostrider17's Avatar
That was good for a chuckle..... you silly boyz.
To the op:
This is a pretty good list.
maf
coils
struts
o2 sensors
crank/cam sensors
valve cover gaskets
water pump
tie rods
bearings
LCA
tranny slipping
engine burning oil
exhaust
pre-cat/main cat
fuel pump
injectors
You've got ALOT of miles on that Max - so sky's the limit on what to look for -- but this is a good start.
Go with the obvious, and cheapest things first, and work your way up!
Hopefully you got one that isn't an OilBurner, a tranny eater, an MAF *****, or a Coil consumer.
welcome aboard!
Old Sep 22, 2010 | 07:53 PM
zero2sixtyZ's Avatar
You embarrass me.
Correction, rapid fired the 15 worthlessly, and then posted in the "Thinking of buying a 5/5.5 thread" about the clutch (which you will burn off trying to adjust the catch point) instead of saving this thread. Win.
Old Sep 22, 2010 | 09:51 PM
j23a45m9's Avatar
Originally Posted by Doomztown
I think your car is one of the sexiest 5th gens ever
Kanye west is that you
Old Sep 22, 2010 | 10:31 PM
Scottwax's Avatar
That's Mr. Detail to you
I've got 183,600 or so miles on my '02 with a 4AT and so far, so good. In the last 12 months, I've replaced the precats (found a pair of used, low mileage ones from a .org member who put headers on his car) and the passenger side engine mount.
So far so good with the engine and transmission, struts will need replacing though.
Best advice is to change fluids regularly and take care of any problems immediately so they don't get worse.
Old Sep 23, 2010 | 04:50 AM
NissanMan97's Avatar
thats some funny **** right there
B
Old Sep 23, 2010 | 06:11 AM
NmexMAX's Avatar
dot dot dot ...
Ahhh .. Seriously, these are fairly worthless threads. Same as your 15 posts to get here.
You need to research more... Spend the time dong that vs bumping old threads for 15 posts, and then posting 3 or was it 4 useless threads.
MAXSE5SPD
Sep 17, 2022 04:00 AM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
imported_Nismo_max
Sep 21, 2015 07:24 PM
